Triac for motorized gate controller
  • Behemot
    • 4845
    • CZ
    I got this board from motorized gate control unit with the issue of powering motor only in one direction. One of two triacs is blown which seems to be the one and only problem.
    There is BTB24-800BW triac, that is 25A, 800V, 50 mA gate treshold. I can get similar triac but also another one with 35mA treshold, for less than 1/5 the price. Since I am not familiar yet with it and can only conclude based on transistors, I can asume lower gate treshold current is not a problem?
    Re: Triac for motorized gate controller
    35ma is just the more sensitive Gate version, so that is find.
    • larrymoencurly
      • Oct 2004
      • 960
      I had a motor control that specified a triac with a 50mA gate, and a 25mA part worked fine but a 3mA part always stayed turned on 100%.
      • Behemot
        • 4845
        • CZ
        Oh man, 3 mA, that's less than 1/15th, no wonder it was doing that
        • Longbow
          • Jun 2011
          • 623
          Not enough information. What kind of circuit? What kind of motor? Speed controlled, or just on/off? A standard AC induction motor only runs in one direction - is there a gear change box or solenoid to switch directions?
          The difference between 35 ma and 50 ma gate is not the issue. That amount of current is the threshold of the average part. You would never design a triac circuit based on the threshold rating. First, I would want to make a good guess at why the one part failed.
          Is it plugged in?
          • Behemot
            • 4845
            • CZ
            I'd say that each triac is for one direction, that would be consistent with the fact the gate only operates in one way.
            I don't have any other informations, I only got the board, not the whole system. It may blow for no apparent reason, that happenes sometimes.
            • Longbow
              • Jun 2011
              • 623
              It would be consistent if the gate used 2 motors. A motorized gate would not generally require premium technology components. Simple single phase AC motors only run in one direction.
              It sounds like you were asked to repair the board without knowing what it really does. Yes, failures happen for no reason. I would say in general that parts fail for a specific reason. In this case I'll bet the real problem is still mounted on the gate.
              Is it plugged in?
              • Behemot
                • 4845
                • CZ
                We'll see after all…BTW, servicing center offered replacement board for quite some money. As nobody asked for anything else, most likely they are aware of this failure which only supports my theory it's nothing more in that.
                There is no simple motor but assynchronnous single-phase motor, in that case it's enough to change the phase difference if I am not mistaken so you can just select the right input by opening first or second triac.
                  Can we see the pictures of the board, and any info on the motor (labeling on the motor)?
                  • Behemot
                    • 4845
                    • CZ
                    Been told there's 1uF cap on the motor, that's all. I am giving the board back today so we'll see by tomorrow if it works or not.
                    EDIT: enjoy
                    • Behemot
                      • 4845
                      • CZ
                      I am idiot, I forgot I've been told the serviceman has already tried new working board and the gate operated normally. Customer has reminded that to me again while he was taking the board.
                      As I have not found any other problem on the board, it again only indicates the triac was the only problem. They have supposedly replaced the motor half a year before this incident so it may have somewhat damaged the triac which ultiamtely blown after some time.
                      • Behemot
                        • 4845
                        • CZ
                        I have been informed that the gate is running fine.
                        • master3112
                          ASUS ROG Strix- G513IH-HN008, G513-6050A3249301- MB-A04 (A4) damaged Embedded Controller
                          by master3112
                          I have an ASUS ROG Strix- G513IH-HN008, motherboard G513-6050A3249301- MB-A04 (A4)
                          When I received the device, the device has no function. After an investigation, I found that the PWM CONTROLLER RT6575B (U6100) is getting warm and there is a short circuit at the 3V3 output. This normally supplies 3V3 for the embedded controller IT5571E-128 (U301). When measuring and analyzing with a thermal imaging camera, I found that some components are damaged: SLG4E42553VTR (U8500), IT5571E-128 (U301), LAN RTL8111H (U450), LOGIC 74LVC1G08GW (U1900), RT6575B (U6100) All these components are on...
                          10-29-2024, 09:32 PM
                          Tankless hot water heater controller board not powering up when power is applied
                          by sam_sam_sam
                          I recently bought a used tankless hot water heater and the controller board is completely dead no power up when power is applied the display board works however the main controller board does not work correctly at all the fuse is good
                          I bought a used replacement controller board that also had issues that I was able to fix and now the tankless water heater works correctly now
                          However I would like to know if I could figure what happened to this controller board if possible
                          Tomorrow I will take some better pictures of both side of both boards
                          The...
                          12-09-2022, 09:14 PM
                        • ronnygracias
                          Help with freemotion incline trainer with controller comm error
                          by ronnygracias
                          The treadmill was working fine, one day the belt snapped and after checking the unit I also noticed that the display is now showing the Controller comm error. So I opened it up and the treadmill had two boards. One is a power supply board and the other is the motor controller. I noticed there was a mouse nest, so I took power supply board out, cleaned it up, replaced the big capacitor and that did nothing. Then I took apart the motor controller and cleaned that up, and when I plugged it in, it started right up. I thought I fixed it. But when the belt arrived, I installed it and tried to power...
                          11-04-2024, 01:32 PM
                          Lift Master Garage Door wall switch display / motion sensor controller display disappeared no back light
                          by sam_sam_sam
                          This happened last Saturday and today I finally had time this morning before I went to work to replace two non brand capacitors
                          I will let you be the judge weather or not these are bad or not according to the blue ESR meter that I am using
                          I am comparing them to a brand new one that I installed
                          The display came back on and the programming was not lost which I was surprised by I would have thought that when the display went blank that so did the memory as well
                          I going to let it run for several days before I remount back on the wall next to the...
                          09-05-2024, 06:48 PM
                        • Lvsitano
                          Asus X532FL 3.2V at source and gate
                          by Lvsitano
                          I am having some trouble with troubleshooting a Asus X532FL rev 2.0 motherboard, which does not power on. So at the first MOSFET, I am getting 19V at the drain, and then 3.2V on both gate and source (compared with ground). Of course, the 2nd MOSFET's source will have 3.2v at source.
                          First MOSFET is a QM3056M6 and 2nd MOSFET is a QM0930M3
                          I already checked first MOSFET and source and gate are not shorted (drain with source not shorted either). Also I have 1.7V at the LDO rail (measured at the keyboard connector, as the power button is on the keyboard).
                          First...
                          06-26-2024, 02:13 PM
