What is this part?
  • goodpsusearch
    • Oct 2009
    • 2850
    • Greece
    What is this part?
    Is this a diode?
    What do the markings mean?
  • mariushm
    • May 2011
    • 3799
    Re: What is this part?
    That's a Tantalum capacitor. The Bar at the top says that's the POSITIVE end (it's the opposite of electrolytic capacitors, where - says negative).
    107 is short for 100uF if I'm not screwing it up.
    6K ... K is the tolerance, probably , 6 may be the rated voltage but I'm not sure, it could be that 018 is the voltage code, it could be that "6k" together is the code for a voltage rating.
    ps. If you really have to replace it, you must be careful about the voltage rating, tantalum capacitors burn or explode if you put more voltage than the rating so it's very important to not use a capacitor with too small voltage rating.
    You can follow the traces and if they go to that chip above, then that chip is a MC34063 switching regulator, so you can most likely determine the output voltage of that regulator by the resistors on the feedback. Datasheet explains how to determine that. It's not hard.
      Does it test out as shorted? Typical failure mode for Tantalum cap.
      • goodpsusearch
        • Oct 2009
        • 2850
        • Greece
        Diode mode of the multimeter shows open when testing the cap.
        This security camera failed due to lightning. I tested every diode and transistor on both sides of the PCB but I found nothing shorted or open. So, I can assume the failed part is one of the ICs..
          Voltage testing will be one of the first test to see if the board is getting any voltage feeding it. You should be able to red DC voltage across that cap. Lighting can take out may components.
          • goodpsusearch
            • Oct 2009
            • 2850
            • Greece
            List of ICs:
            Sharp LR38627 Digital Signal Processing LSI for CCD
            Sharp LR36B03 Low power consumption [81 mW (TYP.)], high-speed S/H circuit, high-gain PGA circuit,
            12-bit ADC (25 MHz), mechanical iris control function, 12-bit digital output
            Ai1003 A1 PROs Vertical Clock Driver for Camera System
            24C16N ATMEL Two-wire Serial EEPROM
            MC34063A SMPS Controller
            The infrared illuminators light when it is dark, so it gets voltage.
            The Sharp LR38627 gets warm.
            There is no video output though.
              No sound out put either? There must be op-amp for the Electret micro phone and out put some where on the board. So no dc on any one of the Tantalum caps? The two tantalum caps and the inductor between them is buck converter switching supply circuit, you should have voltage on those two caps.
              • Kiriakos GR
                Banned
                • May 2012
                • 940
                • Greece
                I would try to reflow it with hot air, the soldering looks terrible.
                Lighting can load on it static electricity which it is deadly.
                • goodpsusearch
                  • Oct 2009
                  • 2850
                  • Greece
                  The tantalum cap of the 1st picture has 0.5V
                    Does this thing run on 12V power supply? Can we see on how these board are connected to the outside world so we can see the DC jack, video, audio out, etc? I see two white headers, the two-pin one is for powering the IR) on the boards. Also the pictures of the bottom side of the boards. It must have these connections: Audio, video, B+, Ground, Control line to turn the IR lamps on/off (unless it has auto-on circuit to detect no day light condition) which may explain why it has 4-PIN connector for the 4 signals.
                    • goodpsusearch
                      • Oct 2009
                      • 2850
                      • Greece
                      It gets 12V DC. The output is RCA. The audio out was not used.
                      4 pin header: +12V, GND, VIDEO OUT, AUDIO OUT
                        "4 pin header: +12V, GND, VIDEO OUT, AUDIO OUT" OK, just as I thought. Tracing out the board on how the 12V is applied to the circuit will be the next step, not going be easy task. By the way, the board has many CMOS devices that can easily be damaged by static/spikes/high voltage.
                        • quickname
                          Cyberpower 1500AVR UPS repair
                          by quickname
                          I'd like to start out by thanking this forum for providing the info to be able to repair my 15 year old CP1500AVRLCD UPS. Here is all the info I gathered during my trouble-shooting and re-capping.
                          Like clockwork, I've had to replace the SLA batteries every 4 years. It was about that time and the UPS was acting like it needed new batteries... randomly shutting off with AC present, not being able to charge fully, and poor runtime when AC was removed. So, I replaced the batteries but noticed that it was not charging properly.
                          I decided to verify that the batteries were...
                          11-12-2023, 09:57 AM
                        • G-Sting
                          iPad Pro A1876 SHORT Part Identify Help Needed
                          by G-Sting
                          So My iPad was not charging and booting up . i went to a local technician and he checked with thermal and this Part marked in 1st Photo is Short.
                          So then i went on to boardview and downloaded the schematics and identified this part in 2nd Photo. Now i am confused what exactly is the part called ? where should i get this from ?
                          i contacted my technician and he sent me his BoardVIew screenshot in 3rd Photo. In his Boardview the part is called X2826.... Something
                          SO My main concern is what part should i order what should i search the name for ?
                          on Ipad...
                          05-15-2025, 09:30 AM
                        • Antonynl
                          Capacitance and voltage of tantalum?
                          by Antonynl
                          I have a tantalum capacitors with indicators EB 21 that measures only 22pF. See attached picture.
                          Since this is a windmeter that is normally in a very high mast I would like to get the correct replacement capacitor.
                          Is there somebody that can tell me what the capacitance and voltage of this capacitor are?
                          I don't feel confident that I can figure this out myself after searching around
                          Cheers!!
                          04-14-2024, 03:19 PM
                        • rddube
                          Lenovo L490 Ram voltage circuit malfunction
                          by rddube
                          Hello friends,
                          Looking for some guidance here. The RAM voltage circuit on this motherboard keeps burning out PU301 which is a RT8231AGQW. Copy of the board with the burnt chip attached with some voltage measurements and copy of the schematics also included.
                          I think I've checked almost every component in the circuit, but when I change the RT8231, the laptop starts I have 1.2V on the inductor for about 10 seconds and then the RT8231 goes south and no more voltage on the inductor. All other voltages on the laptop are good, this is the only one conking out for a reason I...
                          07-15-2025, 04:41 PM
