controlling circuits with an actual clock.
  • JonathanAnon
    • Jul 2012
    • 457
    • Ireland
    Hi guys, I'm working on something that I want to trigger at a particular time.. I was gonna just open a clock and tap off a part of the alarm to trigger a transistor/relay .. but what do people normally do?
    I want to just have a relay click on at 8am which kicks my kettle on.
    Re: controlling circuits with an actual clock.
    Using something like this?
    http://growace.com/24-hour-programma...FUQ6QgodC0QA8A
    http://www.amazon.com/s/?ie=UTF8&key...l_10hetq9muz_b
    • JonathanAnon
      • Jul 2012
      • 457
      • Ireland
      Hey Bud, I have a circuit built at the moment based on a 555 timer. I have this triggering a transistor which triggers a 240V (Ireland AC) relay. So I'm toying with ideas of what I could do with a mains voltage devices using a circuit based on a realtime clock (not the oscillation that the 555 provides).
      I put a search in my provider's site and I get a load of ICs...
      http://radionics.rs-online.com/web/c...view-type=List
      Could I use one of these chips, and attach some sort of display? How does it work?
      • Rob Northen
        • Jan 2010
        • 137
        • Denmark
        I have used the Dallas DS3231 chip in a few projects, and it is really keeps precise time, even over longer period
        • JonathanAnon
          • Jul 2012
          • 457
          • Ireland
          I'll check it out, thanks Rob..
          • ben7
            Capaholic
            • Jan 2011
            • 4059
            I believe there are some RTC chips that have a programmable timer output. You'd have to use an arduino or the like to write to the registers in the RTC chip.
            Or else you can use a programmable divider chip, and use a crystal as the main clock source. For example, dividing a 10Hz wave by two will give you a 5Hz wave. Some digital clocks that plug in to the wall use the mains frequency as a timebase, it actually works fairly well - divide the 50Hz by 50 and you get 1Hz, or once per second
            Muh-soggy-knee
            • JoeyJoe
              • Sep 2012
              • 76
              • United Kingdom
              You should defiantly get an Arduino. So much fun if your into electronics. Get a RTC module too (or the parts to make one).
              • eccerr0r
                Solder Sloth
                • Nov 2012
                • 8701
                Is this what's wanted?
                heh. Sorry, that's what I thought when people post a topic like this...
                • JonathanAnon
                  • Jul 2012
                  • 457
                  • Ireland
                  Yeah it's hard not to just ask for the above, as it's probably the best description of the function of the circuit I'm looking for... But I didnt want red flags popping up all over the place though, and the GardaĆ­ arriving at my house with a SWAT team..
                  • CoinCoin88
                    Garage door RX unit (Cardin S38C) does not short relay to send opening signal
                    by CoinCoin88
                    I'm turning to the Badcaps community to help me troubleshoot the radio Rx card from my (old) garage door opener. While I could just ditch that card and replace the whole system, I first would like to understand "why" it suddenly stopped working, because that's just how I am wired...!
                    Some basics: the receiver works on a 30.875 Mhz frequency. Yes, I'm aware this is not in use anymore in a looot of places. It does not use any rolling code, it's just a regular dip-switch code that you have to set up on both the receiver and transmitter. The receiver...
                    09-15-2025, 03:36 AM
                  • shelby5041
                    clock radio / radio lifespan?
                    by shelby5041
                    hi
                    ive got a modern digital clock radio approx 15yrs old
                    my question is how long can a clock radio or a simple radio last ss farcas operating hours?
                    since elec components have limited hour lifecspan i would imagine the radio or clock radio would eventually fail.
                    the reason i ask is because i have my clock radio on radio function 24/7 for the past 7 years and its still working fine....i leave the radio on ..never turn off past 7years...thats approx 60000 hours
                    it uses very little power just a few watts i would imagine that may have something...
                    09-14-2024, 03:30 AM
                  • jm1234
                    9V relay temperature 40C
                    by jm1234
                    Hi, I'm seeing one 9V relay having temperature 40C on its 9V (primary) side. Does that seem right? I switched 2 relays on that board and the temperature was the same (on the same position), so I'm sure it's not a faulty relay. I measured voltage on that relay and it was 9.5V DC, so that looks good. I don't see any other relay on that board having that kind of temperature and they have 9V on them too.
                    I thought maybe the transistor that is switching this relay keeps switching on/off, so I also checked for AC and there was almost none: 0.3V using mV range. No steady frequency was shown, but...
                    05-09-2024, 03:03 AM
                  • edugimeno
                    Biomass Boiler not driving cleaner motor relay. ENERTRES BIOMASA BI-650
                    by edugimeno
                    Hi everyone!
                    I have this board that suddenly stopped supplying power to an output that drives an interchanger cleaner motor.
                    I checked while the board was in place with all wires attached and there's no AC voltage on the corresponding plug X5
                    This X5 is driven by fuse F8 (tested OK) which comes from the second orange relay
                    To make sure there are no charcoaled contacts inside the relay, I got a 24VDC power supply and got it ready to manually power up the coil side of these relays.
                    I respected the polarity, positive to cathode of protecting diode
                    So provided all...
                    04-18-2024, 01:15 PM
                    Mitsubishi CNC switching power supply board dead / relay board bad diode failure
                    by sam_sam_sam
                    I was working on this CNC machine today found no keyboard functioning no control relay powering on
                    The screen powered on and was giving an operation error but the manual was not very clear about what the error exactly was but with a little bit of troubleshooting and finding out that the control relays not powering on and no keyboard functions we narrowed down to this one switching power supply which of course does not have any indicator LED light they are on the keyboard interface/relay controller board
                    Found shorted diodes on main controller relays there are 3 of them that...
                    01-07-2023, 05:43 PM
