AMD Durons and fans
  • luke10050
    • Mar 2013
    • 209
    AMD Durons and fans
    hey, so i have this AMD duron with ddr/pc133 ram and it has this rediculously annoying coolermaster rifle bearing fan, is there any easy to refill the resivor in these or alternatively stop it from being so damn noisy? or does it even need the fan at all?
  • RJARRRPCGP
    • Jul 2004
    • 6304
    Re: AMD Durons and fans
    Use a drop of motor oil.
    ASRock B550 PG Velocita
    Ryzen 9 "Vermeer" 5900X
    Arc A770 16 GB
    eVGA Supernova G3 750W
    Alienware AW3423DWF OLED
    • luke10050
      • Mar 2013
      • 209
      it doesnt really have a hole in the back, can i drill it?
      • ben7
        Capaholic
        • Jan 2011
        • 4059
        Replace the fan! The noise is from the bearing, (obviously) and when it is worn, it does that. All bearings make strange sounds when they are worn.
        Replace it with a good brand fan, NMB, Delta, Panasonic, Nidec, just to name a few.
        Muh-soggy-knee
        • luke10050
          • Mar 2013
          • 209
          now i have a good point to bring up, what can i use such an old pc for?
          • Evil Lurker
            Warranty Voider
            • Feb 2011
            • 454
            Hate to say it but I think its time to retire that dinosaur.
            • goontron
              5000!
              • Dec 2011
              • 4108
              • US
              no, it would work fine with linux if the duron is a morgan or an applebred, but most people are way too scared (at least from what i see at my work) to try linux, yea evil lurker is right if you want to run a microscam OS that will be supported next year, upgrade the hardware
              Follow the white rabbit.
              • Heihachi_73
                • Jun 2012
                • 713
                Word processor, web server, Quake/Doom/other period-era FPSes/DOS games, freeware GTA1/GTA2... I can't think of much else to do with a Duron from 1999 or so, it's about as powerful as an Xbox 1 (or a four cylinder Commodore). Also, if it's PC133, it's most likely going to be plain old SDRAM rather than DDR.
                Personally though, I'd retire it unless it has sentimental values or you collect PCs.
                If it's a generic desktop tower case where the sides are separate pieces (e.g. not a one-piece shell like an old 486 AT case)...
                Why not make a fire bin out of it:
                1. Remove the sides.
                2. Remove the internals - mainboard, drives, power supply, cables (PC speaker doesn't matter, if it has one). Keep the screws or board mounts if you need them.
                3. Remove the front bezel, if not done already when you removed the sides.
                4. Take off the top part (you might have to drill out the rivets if it has those instead of screws, or simply just break off the end that's riveted).
                5. Screw both sides back on and you're set.
                Of course, if you want carnage and a bit of black smoke, feel free to skip step 2 and leave everything intact. Being Australia though, in that we have Carbon Tax instead of Al Gore, "don't tell Julia Gillard".
                • RJARRRPCGP
                  • Jul 2004
                  • 6304
                  Even those cheap chipset fans are possible to fix with a drop of motor oil!
                  The noise is probably from the original stuff getting depleted.
                  Arc A770 16 GB
                  • Uranium-235
                    Comrade Glimmer
                    • Aug 2007
                    • 5042
                    • US
                    is it noisy from high rpm or like another kind of sound. I knew some AMD HSF's just ran at high RPM
                    You can find a quieter heatsink, or a fan speed control knob. But the best thing to do would be to save your money and get something new. Intels HSF's with ivy bridge celerons are dead quiet
                      master hoarder
                      • May 2008
                      • 12175
                      Yes.
                      I've done this several times with sealed fans. The most recent one was a Sunon KD1208PTS1 sealed fan. It wasn't stuck but didn't spin as freely as it should. Since the back was sealed with a metal cap, I drilled two small holes near the shaft through the front of the fan (on the rotor, that is) and droped 6 to 7 drops of oil in there, making sure to get the oil on the shaft. After some spinning, pulling, and moving the rotor by hand in different directions, the oil must have gotten to the bearing because the fan was spinning much easier afterwards.
                      So yes, you can drill fans.
                      Remember, it's already broken so it doesn't hurt to try these things .
                      As far as the Duron, I suspect it's a Morgan core since it uses PC133 RAM. Probably not very useful, other than for testing software and/or using it as a torrent box.
                      If it was an Applebred, you could always try the L2 cache mods and all of that.
                      • RJARRRPCGP
                        • Jul 2004
                        • 6304
                        Originally posted by momaka
                        Yes.
                        Actually, it looks like most, if not all socket 462 SDR boards support PC133, even when the usual FSB is only 100 Mhz. KT133 don't support 133 Mhz FSB but is fine with the RAM at 133 Mhz.
                        Only "KT133A" had proper support. Even full T-birds were often only 100 Mhz FSB.
                        I had a 1.3 Ghz 100 Mhz FSB variant, because of the board I had.
                        Arc A770 16 GB
                        • larrymoencurly
                          • Oct 2004
                          • 960
                          I once ran MemTest86 with a 1.6 GHz Applebred Duron (130nm) but forgot to plug in the heatsink fan for 20 minutes. It didn't reach even 70C because the BIOS was configured to shut down at that temperature. This was with the mobo outside the case, in a 25C room. So I think that CPU barely needed a fan, and you should be able to get away with a really slow one. My heatsink was about 3" x 2.5" x 2":
                            master hoarder
                            • May 2008
                            • 12175
                            Interesting.
                            That CPU has a 48W/57W typical/maximum power dissipation. I'm surprised it stayed that cool.
                            I have a 1.4 GHz Applebred in a computer with a bigger heat sink than yours and a 80 mm fan going on full blast, but the CPU temp is usually in the 30-40C range (idle and under load respectively). Initially when I built that computer way back, the CPU fan was almost completely blocked and there was very little airflow. With that, the CPU temperatures never went above 52C under full load for hours. So I guess those CPUs aren't as power hungry as CPUWorld makes them appear.
                            • emil_t
                              RTX3090 working fine but fans not spinning
                              by emil_t
                              Hello guys. I have a problem with a PNY XLR8 GAMING RTX3090 graphics card. The problem is that it displays and works fine, but the fans don't spin at all. The problem occurred when someone else removed the fans in order to clean it and broke one of the fan connectors. He replaced it himself and after that, it wasn't working anymore. I guess he damaged something else in the process. What i have done so far: I found 2 capacitors next to the connector that were in a bad shape, he must have touched them with his tools - they weren't shorted, but i replaced them with similar ones from a similar card....
                              04-12-2024, 06:54 AM
                            • b-slayer
                              Asus Strix-G15-G513RM fans don't work
                              by b-slayer
                              I have an Asus Strix-G15-G513RM, who starts normally, but as the fans don't work, it stops and is really really hot,
                              The Bios was the latest one, (327), but I managed to downgrade it to version 325 to see if it changed something,
                              (as I read somewhere that a corrupted bios can explane my problem), but nothing, it just went full blow during the downgrade,
                              (so now, i can say that the fans are fonctionnal), but as it restarted, the fans won't turn at all again.
                              ah, and in the Bios, even when the temperature is really hot, the fan are a 0 rpm,...
                              09-04-2025, 04:58 AM
                            • JayPoorJay
                              Hot Water Rad - A Few ECU Fans and a Timer Switch
                              by JayPoorJay
                              Good Afternoon, Good People.
                              I know this will be an elementary little project for most if not all of you, but I thought I would write a post and get put on track, rather than bumbling my way through it with all kinds of trials and errors.
                              I REALLY would appreciate y'alls help.
                              This is the problem - My wife and I purchased a big ol Victorian/Colonial House in NYC two years ago. The kitchen is surrounded on 3 sides by exterior walls, there is also a 1/4 of the kitchen floor (ceramic tiles) that has a crawl space underneath, and the kitchen gets FREEZING cold...
                              10-29-2024, 12:54 PM
                            • sda sad
                              my Xiaomi Notebook Pro X laptop fans work like crazy for no reason
                              by sda sad
                              Hope this is the right place, someone can help me.
                              My laptop started having a really strange problem....
                              When I turn it on the fans start working at a crazy rate and with random breaks...
                              They can work for say 10 seconds and stop for 2 seconds and then turn on again for 5 etc...
                              And it's from 0 to 100%. I tried to install AIDA and did the processor chip test and the graphics did not exceed 70 degrees and the fans were not even close to working at the power they work randomly.
                              The model of the computer:
                              Xiaomi Notebook Pro X 15 OLED (A30)
                              04-23-2024, 09:55 AM
                            • joesmoe91
                              Dell Precision 5530 15" died to blown chip. Replaced chip and now only get momentary fans, lights, no screen or boot
                              by joesmoe91
                              My Dell Precision 5530 turned off suddenly when I was running Matlab and wouldn't turn on, show any lights, fans, and/or any signs of activity at all. I opened the case, removed the battery and looked at the board with a thermal camera while the AC adapter was connected. I saw that PU1252 was >120C so figured the chip had died on me Got the part number off the attached schematic (see Mouser link below) and replaced the chip. After replacing the chip the board (connected to AC adapter) was able to briefly power on, spin the fans a little bit, and turn on the front led lights....
                              02-22-2024, 07:38 PM
