Need to find a battery
  • spleenharvester
    • Mar 2010
    • 913
    Got a GoGear ViBE 8GB here. Was a complete brick until the battery was pulled, and now it works on USB. So I'm guessing the battery went dead short or something.
    Only info I can find is on this site http://bydit.com/doce/products/Li-EnergyProducts/
    Any ideas?
    Thanks!
    EDIT: The Vibe's battery is apparently interchangeable with the SA3285 and MyVu glasses which use a SL422436. But I can't find that either.
    Dell E7450 | i5-5300U | 16GB DDR3 | 256GB SSD
  • kc8adu
    • Nov 2003
    • 8832
    • U.S.A!
    Re: Need to find a battery
    look at hobby dealers.
    you may be able to get a raw cell and move your protection board to it.
    • SuperDuty
      • Mar 2011
      • 299
      • France
      I had a similar battery in a cheapo mp4 player, it worked fine but I wanted to try a Samsung cell phone battery I had laying around, also a 3.7V battery. Soldered two wires to the top connections, and it works perfectly. It charges fines and stays on much longer than with the original battery.
      If you have an old cell phone, you should give it a try.
      EDIT : okay just googled the GoGear Vibe, it seems smaller than the cell phone battery...
      • twbranch
        Mad Nerd
        • Oct 2012
        • 153
        If you have Batteries Plus in your town, they recell batteries. It is kind of expensive but I have had a few done myself and they work well.
        • spleenharvester
          • Mar 2010
          • 913
          Indeed matey that's the problem, the Gogear is absolutely tiny
          Good point about the protection board though - just pulled the tape off, it looks fairly easy to replace, I'm just worried about blowing the thing up with the soldering iron.
          I'm also worried an el cheapo Chinese cell may blow up or something when charging. Would the protection board be a good workaround?
          Cheers
          • spleenharvester
            • Mar 2010
            • 913
            Bit of a development. Turns out it's actually the protection circuit at fault - the thermistor wire stops it booting when connected. Works fine with only Vin and Ground. Is it safe doing it this way?
              Depends if it is using that signal. That is a warning to the battery charger that the battery has overheated.
              • spleenharvester
                • Mar 2010
                • 913
                Odd, resoldered the old battery completely and all works fine now.
                So it went from being completely dead with a whining noise, to back to normal, just by removing and readding the battery.
                Ah well, here's hoping it doesn't do it again
                • Bowline
                  by Bowline
                  06-11-2025, 10:13 AM
                • mkdj
                  ASUS X571 no power : battery issue?
                  by mkdj
                  Mark and model: ASUS X571
                  Symptoms: not turning on. There is only the LED battery indicator working. The owner of the laptop told me this problem arrived one week after having changed the battery. He then managed to power on the laptop only once, and then it never powered on again.
                  Tests already made:
                  - Battery is charging when laptop is plugged in. The LED battery indicator turns white after a couple of hours of charge, indicating that battery is fully charged. However, laptop won't turn on anyway, with or without AC plug.
                  - I have removed...
                  07-14-2025, 09:16 AM
                  NVDC charger configuration...
                  11-05-2024, 03:28 PM
                • ferah831208
                  Strange battery present behaviour in Lenovo Legion 5-15ARH05 mb model nm-d041
                  by ferah831208
                  Hello guys, i need help with this problem, I have a NM-D041 mobo, it came with low impedance in 3v linear regulator rail, the cause was a damaged EC controller ITE8227e-192. I ordered a new one and replaced it. This laptop have a different chip for keyboard management and it8227e pins for programming ITE chips are not accesible through keyboard interface, I flashed it using i2c interface pins with vertyanov programmer because laptop was dead and SPI flash didn't have power (only 3v EC) so it couldn't access firmware stored in SPI memory. I read SPI and extracted it8227 firmware from original BIOS...
                  03-18-2025, 01:18 AM
                • huzo
                  HP ELITE X2 1013 G3 weird battery issue
                  by huzo
                  Hi, so the old battery was getting error stated it's capacity is starting too get low and should be replaced, so the customer bought a new one and replaced it, but the new battery was also getting this notice that it's capacity is getting low and should be replaced, so i took the laptop for testing and the battery is charging at the terminal at 8.03V , the voltage of the battery is 7.7V, and drawing around 600mA when charger is put and the laptop is off...so that should be ok... but the bios system test doesn't recognize the battery and can't do the battery test and so is the hp battery manager,...
                  01-31-2025, 12:09 AM
