Need to find a battery
  • spleenharvester
    • Mar 2010
    • 899
    Got a GoGear ViBE 8GB here. Was a complete brick until the battery was pulled, and now it works on USB. So I'm guessing the battery went dead short or something.
    Only info I can find is on this site http://bydit.com/doce/products/Li-EnergyProducts/
    Any ideas?
    Thanks!
    EDIT: The Vibe's battery is apparently interchangeable with the SA3285 and MyVu glasses which use a SL422436. But I can't find that either.
    Dell E7450 | i5-5300U | 16GB DDR3 | 256GB SSD
  • kc8adu
    • Nov 2003
    • 8832
    • U.S.A!
    Re: Need to find a battery
    look at hobby dealers.
    you may be able to get a raw cell and move your protection board to it.
    • SuperDuty
      • Mar 2011
      • 299
      • France
      I had a similar battery in a cheapo mp4 player, it worked fine but I wanted to try a Samsung cell phone battery I had laying around, also a 3.7V battery. Soldered two wires to the top connections, and it works perfectly. It charges fines and stays on much longer than with the original battery.
      If you have an old cell phone, you should give it a try.
      EDIT : okay just googled the GoGear Vibe, it seems smaller than the cell phone battery...
      • twbranch
        Mad Nerd
        • Oct 2012
        • 153
        If you have Batteries Plus in your town, they recell batteries. It is kind of expensive but I have had a few done myself and they work well.
        • spleenharvester
          • Mar 2010
          • 899
          Indeed matey that's the problem, the Gogear is absolutely tiny
          Good point about the protection board though - just pulled the tape off, it looks fairly easy to replace, I'm just worried about blowing the thing up with the soldering iron.
          I'm also worried an el cheapo Chinese cell may blow up or something when charging. Would the protection board be a good workaround?
          Cheers
          • spleenharvester
            • Mar 2010
            • 899
            Bit of a development. Turns out it's actually the protection circuit at fault - the thermistor wire stops it booting when connected. Works fine with only Vin and Ground. Is it safe doing it this way?
              Depends if it is using that signal. That is a warning to the battery charger that the battery has overheated.
              • spleenharvester
                • Mar 2010
                • 899
                Odd, resoldered the old battery completely and all works fine now.
                So it went from being completely dead with a whining noise, to back to normal, just by removing and readding the battery.
                Ah well, here's hoping it doesn't do it again
                • Bowline
                  by Bowline
                  06-11-2025, 10:13 AM
                  NVDC charger configuration...
                  11-05-2024, 03:28 PM
                • ferah831208
                  by ferah831208
                  03-18-2025, 01:18 AM
                • huzo
                  HP ELITE X2 1013 G3 weird battery issue
                  by huzo
                  Hi, so the old battery was getting error stated it's capacity is starting too get low and should be replaced, so the customer bought a new one and replaced it, but the new battery was also getting this notice that it's capacity is getting low and should be replaced, so i took the laptop for testing and the battery is charging at the terminal at 8.03V , the voltage of the battery is 7.7V, and drawing around 600mA when charger is put and the laptop is off...so that should be ok... but the bios system test doesn't recognize the battery and can't do the battery test and so is the hp battery manager,...
                  01-31-2025, 12:09 AM
                • trepachka
                  iPad Air A1475 Boot loops after replacing battery
                  by trepachka
                  This iPad was working fine except the battery was not holding charge for more than 40 minutes. I replaced it with a new battery. I haven't glued the battery yet, just inserted it into the slot and held it with battery screw.
                  The iPad was powered on with the new battery and I am getting white screen with Apple logo for about 10 seconds, then the screen turns dark. It then cycles like this forever.
                  I know the battery is working because the iPad continues to boot loop without the charger until it depletes to 0% and the message displays I need to plug in the charger.
                  11-08-2024, 03:17 PM
