Dead Hello Kitty Karaoke Sanrio machine
  • selldoor
    replied
    Re: Dead Hello Kitty Karaoke Sanrio machine
    Originally posted by Welchs101
    hi selldoor, sorry that. Hey, i was going to try and make the measurements you requested this morning but i could not find the picture you marked up.
    I get worse - forgot to load the pic!! - sorry.
  • Welchs101
    replied
    i tried to take some better pictures........if there is a specific part of the board you would ike me to shoot.......just let me know.
  • Welchs101
    replied
  • selldoor
    replied
    Its no good giving us one half of two tests. You need to apply some logic to what you are doing.
    I am going to test a switch - what do I need to know?
    When the switch is on what is the resistance going to be?
    When the switch is off what is the resistance going to be?
    When the switch is on what is the voltage going to be?
    When the switch is off what is the voltage going to be?
    You then match what the answer should be, with what you get when you do the test.
    That switch might also have more than one set of poles(contacts)
    Anyway we will be here all year at this rate so just do the following.
    In your picture I have marked places to test. The board is marked Gnd=Ground an 9v+ so with your meter on 20vdc
    put the black probe on Gnd then with the red probe test
    1:2;3;4;5;6 then do it again with the switch in the other position If all zero just say "all zero"
    We could do with a "straight on" in focus pictire of the whole of the back of this board and of the front in the same orientation.
  • Welchs101
    replied
    ok....in my previous post i got "1" and "2" mixed up..........backwards.....
  • Welchs101
    replied
    ok....i measured the voltages across the switch......
    see enclosed pics
    One of the pics show a yellow square around the main power switch
    The other pic shows the backside of the switch ...... in this pic notice the nodes labeled "1" and "2". When the switch is in the "on" position the resistance between nodes "1" and "2" is about 0.4ohms.....
    when i connect the batteries.........i measure 9.5V on node 2 and when switch is in the "on" position i measure 9.5V on node "1"........when the switch is in the off position i measure 9.39V at node "1".....
    note: how i measured voltages is with my black lead from volt meter at the "neg" side of the battery.......
  • Welchs101
    replied
    ok, so using the suggestion in post#13...........and the picture of the red and black wire.
    With batteries connected.......i place the black lead of the volt-meter to the "neg" terminal of the battery..........then i placed the red probe of the volt-meter to the black wire and red wire.
    Black-wire voltage measurement: 9.39V
    Red-wire voltage measurement: 9.5V
    i guess the next step is to measure the switch......i will do this next.
  • vinceroger69
    replied
    Originally posted by opamp
    Look at the picture provided by user selldoor at 9:49am today (there's an arrow indicating where). Check if there's voltage coming into the big board. Leave neg- prove on the batteries and then put pos+ prove on the red wire. If voltage is coming in to the board, your next step will be to check the on/off switch for voltage.
    pic in post number 13
    that should tell us if voltage is getting to the switch board.
  • opamp
    replied
  • Welchs101
    replied
    opamp,
    not sure what to test.......can you tell me again.
  • vinceroger69
    replied
    Originally posted by selldoor
    Asked - post 13 answered post14 - nil.
    Welches101 - hope your meter is working.
    my fault did not read all the posts lol just wrote what i would of tested myself next
  • opamp
    replied
    Ok so they are not open now check voltage where user "selldoor" tells you at 9:49 Am today. Keep neg- prove on the negative side of the batteries and place pos+ prove on the red wire.
  • Welchs101
    replied
    on the diode check:
    I connected my meter (measuring DC voltages) ....black lead to the negative side of the battery and then my red lead to the "vertical-grey" line on the diodes.........both diodes measured 9.5Volts DC.
  • selldoor
    replied
    your second picture first post the red and black wire by the switch on the left circuit board (not the one you are holding) is there 9 volts when you test between these 2 wires?
  • opamp
    replied
    On the diodes lets check for voltage. Place neg- probe on the neg- side of the batteries then place the pos+ probe on the cathode side of the diode. The cathode side of the diode has a gray band on it.
  • vinceroger69
    replied
  • Welchs101
    replied
    the voltage difference between the black and red wire in the picture you sent in the last post.......is 0Volts. This red and black wire come from the small board that i was holding.
    according to the manual the two connections on that small board are as follows:
    1-DC input jack
    2-Phone jacks
    not sure but maybe it is head-phone jack ............
  • selldoor
    replied
    Yes I think we got that - no volts on the end of the board.
    So is the other socket a headphone socket? microphone socket.
    I am thinking the two ends of the board are not really related-
    not connected on that board.
    What I really asked originally was what is the voltage reading on the socket on the big board - see attached
    If it is nil then it is either a problem with the switch inside the power adapter socket that probably switches the battery power off when it is inserted and allows the battery power when the adapter is removed or the diodes.
  • Welchs101
    replied
    hi i am enclosing some additional pictures
    just a quick note....in my previous post ......i had indicated that there were essentially no "voltages" measured....i hope i did not confuse you .......did you get that?
  • kc8adu
    replied
    if your 9.x is getting to the board i would check the switch in the jack next.
  • double_DD
    Transformer replacement for a dead coffee machine
    by double_DD
    Hi guys,
    I have a dead coffee machine, and it seems that the culprit (no 1, at least) is a dead trafo - primary coil seems to be blown open (type shown on the picture below).
    Now, I'm unable to find direct replacement anywhere on ebay or aliexpress, and all similar that I' was able to find are rated too low (<1A).
    If someone knows a shop to buy replacement (EU/CH), that would of course be my 1st option.
    My other ideas:
    - to buy 220/20Vac trafo with 30VA, and to "manually" create secondary 12V output just via resistor
    - to buy...
    06-23-2025, 05:43 AM
  • carrzkiss
    Cyberpower cps1500avr not charging batteries
    by carrzkiss
    Hello, all.
    Cyberpower Battery Backup Unit.
    I bought two new ML18-12 batteries through Amazon (They have already refunded my money for the two batteries as we thought the batteries might have been bad.)
    When I got them in, they were not fully charged. I connected them to the UPS and waited 24 hours before connecting any networking equipment.
    In parallel, they read 24v, but within 24 hours, the meter on the front of the unit dropped from 4 to 3 bars on the battery charge indicator.
    Checking the voltage, it was down to 22v.
    I quickly removed everything...
    06-15-2024, 02:10 PM
    ALIENWARE Steam Machine R2 i7-6700T Specification for Upgrade or Repair
    This specification for the ALIENWARE Steam Machine R2 can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the Steam Machine R2 boardview and Steam Machine R2 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download...
    09-12-2024, 03:28 PM
  • ivtec
    Wash machine dead help.
    by ivtec
    Hi good folks;hope you all had a great new year entrance;afamily member asked me to look at their wash machine Maytag MVWC465HW that is dead no leds turn on , i already took out main board but it's hard to troubleshoot due to the amount of wax covering all the board both sides,all fuses to the rectifier and filtering are good, tried to order it but no boards available and cost more than a new wash machine,so i'm trying to repair it at component level,i would appreciate if you could lid me the way any tip that will help me to fix the main board,there is no parts available for this mod# so it seems,power...
    01-09-2020, 12:26 PM
  • CG2
    Janome DC3050 Sewing Machine Pedal Resistance
    by CG2
    OK, this is a long shot. I got this sewing machine cheap because it's end of line, ex-display, and had no pedal. The genuine pedal costs £60, while Ebay knock-offs go for around £15. So I went for the knock-off, it doesn't work, and I'm not sure whether it's the pedal or the sewing machine that has the problem.
    Now this is an electronic machine, unlike the old fashioned sort where the pedal was a big resistor in series with the power to the motor. Here, the pedal is just (I think) a variable resistor fed with a 5 volt supply, and limited to a current of 5 milliamps. Assuming that...
    04-14-2023, 07:53 AM
