Wash machine dead help.
  • ivtec
    • Dec 2008
    • 1967
    Re: Wash machine dead help.
    TR9 dont look good
    THanks guys; machine is not mine ,it's a familiar and they told me it was washing and went dead and there was water licking in the water input hose where it enter the hot water pump,i they called me and went there to tight the hose and then went to turn on machine then i found out it was dead i guess in the middle of washing it had water in the tank,i also suspect TR9 , the issue it has no marks of part # on the top,i think this is a N_mosfet ,you think this or similar will do?
    i tested TR9 in and out of circuit with fluke 87 on Diode mode and G to source it, 0.160 either sise
    • petehall347
      • Jan 2015
      • 4426
      • United Kingdom
      did you try and clean it ?
      • R_J
        • 9535
        Originally posted by ivtec
        Only voltage on the input 120v ac, no DC volts across the 2 marked rectifiers no v on U4, no volts across CR8 or anywhere in the board , with it connected to the load ,can i test board on the other side without being connected to the machine assembly without load?
        You have NO DC being provided by the main diodes. How can the board work if there is NO voltage being produced by the power supply main diodes.
        • kaboom
          "Oh, Grouchy!"
          • Jan 2011
          • 2507
          TR9 dont look good
          Covered in lacquer- they all look like that to some degree.
          TR9 is a triac, hence the "TR" designator. Your readings indicate it's good.
          You were checking gate to one of MT terminals.
          Do not sub with a MOSFET- you'll blow the board up!
          TR9 switches the drain pump. Has nothing to do with the SMPS.
          "pokemon go... to hell!"
          EOL it...
          All style and no substance.
          guilty,guilty,guilty,guilty!
          guilty of being cheap-made!
          • petehall347
            • Jan 2015
            • 4426
            • United Kingdom
            something blew the fuse or whatever .
            • R_J
              • 9535
              He said he checked the fuse and it was GOOD.
              from post #1
              i already took out main board but it's hard to troubleshoot due to the amount of wax covering all the board both sides,all fuses to the rectifier and filtering are good
              • kaboom
                "Oh, Grouchy!"
                • Jan 2011
                • 2507
                from post #1
                At this point, I'd solder long-ish jumpers onto C70/71 and observe with a voltmeter. Should be rectified line voltage, 160-170V.
                Also jumpers onto that small cap, 22-100u/16v (I replace with 68-100u/16v), looking for 12v.
                And jumpers on C75, looking for 5v.
                Note I did not indicate polarity WRT common; the outputs are stacked and are referenced to neutral in such a way as to easily directly drive the triacs. Best to measure across each cap individually if you're unfamiliar.
                We're interested in voltages across certain capacitors...
                I'm quoting this again to ask some more questions.
                Did you unplug the machine, work on it, then plug it back in?
                If so, there's the possibility of a marginal cap completely failing when voltage was removed; it's then no longer "good enough" to allow the SMPS to start.
                Was the hose loose on the HW valve, or was the valve itself cracked and leaking inside the control panel?
                As I mentioned in my PM to you, these machines do weird things when the caps start to go. The control locking up midcycle is pretty common. Also restarting the currently selected cycle, as soon as a few mins in to almost near the end.
                If there were an issue with TR9, the drain pump would run anytime the interlock relay is closed.
                EOL it...
                  • 31031
                  some coatings will melt with white spirit.
                    I do not know why we are not getting the reports for the Voltage on C70, 71 as requested and why looking at the TR9.
                      Originally posted by r_j
                      you have no dc being provided by the main diodes. How can the board work if there is no voltage being produced by the power supply main diodes.
                      +10
                      • ivtec
                        • Dec 2008
                        • 1967
                        Originally posted by budm
                        +10
                        Thanks Budm i will check voltages on those caps per your instruction as soon i put the board back on the machine this week ,and report finding ,i also think TR9 may not be bad and the cause may lay somewhere else ?
                        thanks
                        • ivtec
                          • Dec 2008
                          • 1967
                          hi it's me again i was able to scrape wax off Tr9 and got some info; AGTT4(S) or (5) in the middle 800 (A) or other maybe Amps,then PjM1747c4, it could be a triac,not sure and can be good! no info about it on the web,
                          https://www.digikey.com/products/en/...cs/300?k=triac
                          • petehall347
                            • Jan 2015
                            • 4426
                            • United Kingdom
                            #33
                            any luck with voltages ?
                            • ivtec
                              • Dec 2008
                              • 1967
                              THanks petehall347, i will try again per Budm instruction monday.
                              • ivtec
                                • Dec 2008
                                • 1967
                                thanks guys;
                                i gave up on it; since the machine owner decided to get another wash machine this time they got another similar second hand whirlpool for 350 bucks ,they did not want to shell out 200 for a control board and went and bought another second hand for 350,now they got this;wish them good luck with thi crappy machine; https://www.whirlpool.com/laundry/wa...tate=pg:2/ct:r
                                • petehall347
                                  • Jan 2015
                                  • 4426
                                  • United Kingdom
                                  #36
                                  looks good to me .
                                  • ajshoe
                                    ajshoe
                                    • Dec 2012
                                    • 477
                                    • usa
                                    #37
                                    I know this post is old. I've worked on a lot of these Whirlpool boards. You can diagnose these on you r bench - just apply 120V to input connector. Green LED should come on solid after boot up. 5V and 13V is the voltage that the board needs to light up the green LED. If the green LED is lit - the whirlpool proprietary chip can still be bad. What usually happens when no sign of power is the drain pump shorts out and then fries the control board. I'm sure there has been many repairmen that replace the control board without checking the drain pump and fries another control board. This washer (VMW) is JUNK in my opinion as I have spent way too many hours diagnosing VMW Whirlpool, Maytag, Amana, etc. washers. If its not the control board - then its the gearbox or transmission - whatever you want to call it (I call it JUNK).
                                    • Soulzink
                                      Samsug washing machine. Power supply DC41-00189a board issue
                                      by Soulzink
                                      I am trying to fix a samsung washinmachine power supply main board.
                                      I already replaced it with another one to fix the machine but i want to try understand the issue with the old board.
                                      Therefore i hope to be able to get some help to explain what to check in order to troubleshoot.
                                      The power supply board reference is the following: DC41-00189a
                                      I have followed one thread (https://www.badcaps.net/forum/troubl...ingmachine-rel...
                                      04-19-2025, 06:26 AM
                                    • k370
                                      Yoga3 Pro-1370 Board NM-A321 DEAD no power at all
                                      by k370
                                      I have a NM-A321 board that is dead, with no power at all.
                                      When I received the laptop, the +5VPMIC line was shorted. Removing the PU3 (ISL95905) solved the short, so I ordered and replaced the ISL.
                                      With the new ISL, the short is gone, but still no voltages at all. I measured the following rails:
                                      • +3VALW
                                      • +5VAUX
                                      • 1.2VSUS_PWRGD
                                      • 3VALW_PGD
                                      • 1.05VAUX_PWRGD
                                      Additionally, the ISL95906 (PU3) is not getting any voltage on the VIN rail.
                                      The only place on the board where I find any voltage is on the first MOSFETs, specifically:...
                                      09-23-2024, 11:57 AM
                                    • howardc64
                                      by howardc64
                                      07-24-2025, 05:17 PM
                                    • Fam787
                                      HELP! A1398 Dead,
                                      by Fam787
                                      I bought a second hand Mid 2014 A1398 MacBook Pro when I lived in Australia. I'd bought it as a back-up machine because I had a Mid 2014 MacBook Pro, and realising it might one day fail, I wanted a backup machine because I don't like change.
                                      Two weeks after buying MBP2, the seller called me to check if everything was OK with the unit, which I thought was odd. At that stage I might have turned it on a couple of times, but I'd not used it when he'd called. Over the last few years I used the machine seldomly because my original mac has been pretty OK. Every 3-6 months I'd charge it...
                                      12-27-2024, 05:19 PM
