Faraday Flashlight? what capacitor it uses?
  • supersabre
    • Feb 2006
    • 45
    Anyone know what type of capacitor is used in Faraday flashlight?
  • Fatal0E
    • Jan 2004
    • 252
    Re: Faraday Flashlight? what capacitor it uses?
    I have the smaller one that someone gave to me. It has no capacitors, it has the thingy that shakes up and down, a bunch of wire wrapped around the center that has each end soldered to a circuit board, really thin wire that looks useless. It then has 2 3.3v CR2032 coin batteries slid into it, the contacts are soldered onto the circuit board also. This flashlight worked for a while, then went dead, can shake till your arm falls off and no light. Put new batteries in it and it works fine again.
    Maybe I got a ripoff version.
    Looking closely it appears as though one end of the wrapped wire solders to the negative battery contact, the other side seems to be soldered on top of the pcb between 2 holes, the holes are wide open, no wire or solder.
    Whipped out the scredriver and took out the pcb, the postive side of the battery contact is wired straight to the LED, the negative side is wired to the springy peice of metal that the on button pushes down to contact another piece of metal and turn on the led. The second end of the coiled wire from the shake contraption is just stuck out of the way and does not contact any of the electrical workings.
    • MD Willington
      • Sep 2004
      • 702
      lol... you mean the stroke it like you mean it flash light.. lol
      Ya'll think us folk from the country's real funny-like, dontcha?
      The opinions expressed above do not represent those of BADCAPS.NET or any of their affiliates.
      • supersabre
        • Feb 2006
        • 45
        I heard that the expensive one has the capacitor and cheap one has the battery.
        • arneson
          • Sep 2005
          • 1267
          I was on a yacht yesterday and needed a light to look in at the rudders.
          Opened a back cabinet and found this jumbo sized shake em light.
          It looked exactly like a big dildo, whacked it about twenty times and it did the trick.
          Jim
          • whiz
            • Aug 2006
            • 48
            this thing works with a coil and a magnet...by shaking it produces electricity and it charges a capacitor...why you yours uses batteries?!
            • arneson
              • Sep 2005
              • 1267
              Every type I have uses button rechargeable batteries that charge from the coil magnet and keep it lit for a short period of time.
              That time is getting shorter as these get older.The smallest one has two batteries, the medium three, I didn't see how many were in the super dildo size.
              Jim
              • linuxguru
                • Apr 2005
                • 1564
                There are allegedly two kinds - one with a super capacitor and no batteries, and the other with no capacitor and lithium button cells instead (this is the el-cheapo knockoff). The second one does not charge the cells, but has a switch to select the power source - the lithium cells or the flywheel/solenoid. This is the only kind I have seen commonly available.
                • gonzo0815
                  • Feb 2006
                  • 1600
                  Anything else than the ones with supper caps are IMHO a rippof.
                  • arneson
                    • Sep 2005
                    • 1267
                    I can't believe I'm taking these cheapo things apart but I have found a Matsushita cap
                    5.5 volts sitting on top of two 2023 button cells and a bridge connected across the charge coil. It looks like .1uf and has brown oozing out.
                    I reassembled it and will now run it over with the truck.
                    Jim
                    • gonzo0815
                      • Feb 2006
                      • 1600
                      May be those CR2030 are sued to give some start magnetic flux, wich would save some bucks for an solid magnetic metall.
                      • 999999999
                        • Sep 2006
                        • 774
                        2023 or 2030 is only a battery size, there are rechargeables in this size too. The ideal would be to have BOTH a supercap and button cells, so that the lower impedance of the supercap results in it building a charge faster, and the higher the voltage rises, the more that rise works to overcome the impedance of the button cells to charge them at a higher rate, but only higher relative to their prior rate, always the supercap charging to peak voltage fastest.
                        They are not premium flashlights though, so you get one or the other, battery or cap. In the former, you should have longer runtime but less efficient charging and shorter lifespan... a tradeoff that might be better for some people or worse for others.
                        • flashdix
                          • Apr 2009
                          I think those cheaper faraday flashlight might have no capacitor.. and the expensive one has a capacitor inside...
                          _________________
                          Flashlightz
                          • Krankshaft
                            • Jan 2007
                            • 2328
                            I say to hell with those cheapo flashlights if you want a rechargeable flashlight.
                            Just use a crank generator like those portable radios have and have it charge a NIMH cell like cordless phones use.
                            • NxB
                              • Feb 2009
                              • 1595
                              My friend has one that you crank up like a portable radio. It works better than the dildo shakers. The ultimate would be crank + solar charging. Never go without light again.
                              • Wizard
                                • Mar 2008
                                • 2296
                                Geniune shake flashlights uses rare earth pellets in both ends with free floating pellet so you aren't feeling that free-moving magnet striking and use super caps.
                                The ones that use rechargeable battery and rubber stops aren't original. It's copycat.
                                Cheers, Wizard
                                • MORETTIGIAN
                                  by MORETTIGIAN
                                  Title:
                                  Description:
                                  Procedure performed:
                                  - Removed backplate
                                  - Reapplied thermal compound
                                  - Reassembled card
                                  09-18-2025, 12:14 PM
                                • Prolog
                                  by Prolog
                                  12-01-2024, 08:27 PM
                                • Agent24
                                  Dick Smith Q-1760 linear power supply filter capacitor question
                                  by Agent24
                                  I have acquired a used Dick Smith Q-1760 power supply - although the OEM is Manson Industrial
                                  It has at least one problem.
                                  The voltage control potentiometer VR2, 50K is faulty - going high resistance / open circuit in the CCW end and leading to the output voltage jumping around.
                                  I have already ordered a replacement potentiometer, so that's not an issue.
                                  Now, I want to replace all three electrolytics on the PCB as they are CapXon and I don't trust them so much, I will replace them with something better while I've got the thing apart anyway.
                                  All are CapXon...
                                  10-21-2025, 05:39 PM
                                • chth96
                                  by chth96
                                  12-22-2023, 04:34 AM
                                • chth96
                                  by chth96
                                  06-02-2024, 07:31 PM
