CAP ID and what to replace?
    Re: CAP ID and what to replace?
    Sorry to hear that.
    Pin1 of this U703 is tied to Ground which is correct so your reading is right, nothing wrong with that reading.
    • Mad_Professor
      A Mech Warrior
      • Feb 2011
      • 1587
      Originally posted by budm
      Sorry to hear that.
      but it also goes to 3.3v pins on the panel connector.
      I'm a bit confused.
        OK, we now know the followings:
        Pin 1 is Ground (I can see it in your picture in post 10).
        Pin 2 (output pin, middle pin/big tab on top) has 95 Ohms to ground.
        So pin 3 (input pin) what do you have?
        • Mad_Professor
          A Mech Warrior
          • Feb 2011
          • 1587
          pin 3 to ground no reading, goes to c749 which is a 10v 470uf cap also c750, but I don't know where it goes after that.
          • Mad_Professor
            A Mech Warrior
            • Feb 2011
            • 1587
            I removed the cap c702 just to be sure it wasn't a shorted cap, and this is going to be a very difficult board to recap since I had to break the cap off and heat from both sides with two irons to remove the legs from the holes. No damage to the trace except for breaking the plastic edge of a inductor coil L701 near by.
            I need to be precise on what to replace.
            I went back and decided to to trace the PS PIN to see what components control it.
            I traced PS pin from the main connector on the board to a IC BA9713 or BA9T13 or BA9113, forth digit is not stamp well. I'm looking for a datasheet but I can't find any. On the board it's Q703 and the top right pin might be pin 4 from the marker, it seems to control Q704 *H1A, but I don't know what the pin lay outs are for Q703 and what sends the signal to trigger the PS to full on.
            Pin 1-3 seems to go to the 5vSB pin on the main connector and all the other pins on the left of the marker I don't know what they do at the moment since I haven't gotten that far. Getting a data sheet on Q703 would be helpful so I can figure out what they do and where to go from there.
            if I can't fix it, I will have to buy a new board that's 100$
            • Mad_Professor
              A Mech Warrior
              • Feb 2011
              • 1587
              #26
              I did a full recap of the board, getting 1.1v on ir/menu panel needs to be 3.3v but not enough to bring the the tv to life. I don't know if this is result of damage done by me, since I had a hell of a time recapping the board, solder was different from left to right, some pop out with ease, others I had keep the iron on or break the cap off and double up on irons. I did alot of damage and burn myself several times in the process, burn quite bit of copper tracks but does not seem to have any continuity issues.
              I've notice two 10uf/25v caps near the a/v inputs have no ground but I don't know where they go.
              edit:
              also ps_on to PSU now has 1.1v.
              • Mad_Professor
                A Mech Warrior
                • Feb 2011
                • 1587
                #27
                Well I tested u703 with live voltage from left to right
                pin 1 = 0.00v
                Tab/pin 2 = 3.3v
                Pin 3 = 4.9v consistent with 5v coming from the PSU.
                So now I'm going to trace the 3.3v to the next component and go from there, there is a shorted transistor somewhere or a broken ceramic cap and I'm going to find it.
                  master hoarder
                  • May 2008
                  • 12160
                  • Bulgaria
                  #28
                  Could also be an open resistor or open transistor (rare).
                  • Mad_Professor
                    A Mech Warrior
                    • Feb 2011
                    • 1587
                    #29
                    Yeah but if it was open why would I only be getting 1.1v on the 3.3v rail at the ir/menu panel? this doesn't make sense. I'm getting 1.1v on 3.3v, PWR and IN pins and 1.1v on the ps_on to the psu so something is just sending volts everywhere, what controls the ps_on?
                    I get 95 ohms on the pin2/tab of u703 to ground.
                    I really could use some help here since I am way over my head here, because I can't read the mess on this board and figure out what goes to what.
                      master hoarder
                      • May 2008
                      • 12160
                      • Bulgaria
                      #30
                      Leakage current through other components is one possibility. It's rare but I've seen it.
                      I know you included some pictures on page 1, but to have someone help you trace stuff through the board, you will need many high-resolution pictures of the entire board, front and back. In the key areas near the plug, even the smallest traces will have to be visible.
                      • Mad_Professor
                        A Mech Warrior
                        • Feb 2011
                        • 1587
                        #31
                        Is this good enough? Otherwise I will have to contact one of my friends and use their nikon.
                          master hoarder
                          • May 2008
                          • 12160
                          • Bulgaria
                          #32
                          Yes, these are pretty good. Sorry for the no reply. Was sick for the past week and a half and didn't log-in BCN before that.
                          Anyways, I'll probably look at it in more detail next week since I have a big project this week and not much time to complete it.
                          In the mean time, check all of the diodes and zener diodes near the connector (like ZD701, ZD702, D701, and D703). Ceramic cap C767 looks a bit dark. Maybe it's the light, IDK, but check for short circuit.
                          There's also a transistor that looks slightly darker, but again, I'm not sure if it's the lighting that's causing this. Cant see a designator for it, but it's right next to one of those small electrolytic caps C709 by the connector. The "transistor" I'm referring to is in a SOT-23 package.
                          • Mad_Professor
                            A Mech Warrior
                            • Feb 2011
                            • 1587
                            #33
                            I was going to post earlier today but got distracted, also I'm not feeling well, runny nose, cat is sick also.
                            When I get a chance I'll check those components.
                              LCD LED TV Service Menu Codes
                              ALL LCD LED TV SERVICE MENU CODES
                              Service Menu Code with Board Name
                              China Universal Board / Jumper Board Service Menu Code
                              Changhong Ruba Service Menu Code
                              Ecostar LED TV Service Menu Code
                              Orient LED TV Service Menu Code
                              Haier LED TV Service Menu Code
                              TCL LED TV Service Menu Code
                              Samsung LED TV Service Menu Code
                              LG LED TV Service Menu Code
                              Videocon LED TV Service Menu Code
                              Supra LED TV Service Menu Code
                              Toshiba LED TV Service Menu Code
                              Symphony LED TV Service Menu Code
                              Veste/ LED TV Service Menu Code...
                              10-31-2024, 03:58 AM
                            • vf fa
                              EIZO CX270 - No signal but Backlight and Panel works, logo works, admin menu works. OSD doesn't. What?!
                              by vf fa
                              Hi, so i guess Iยดll have to make a new topic here, as i browsed through hundreds of other threads but couldn't find a solution to my problem yet.
                              I got a EIZO CX270 from a friend. He said it doesn't work anymore and wont display any signal or take any OSD inputs. Well, as an aspiring photographer I couldn't say no, could I? Thought it was an easy game, replace a bad cap and have a working monitor. But nooope, it wasn't supposed to be this easy.
                              So let me start with the problem description. I'll try my best not to skip anything so this might get rather long.
                              01-31-2024, 01:40 PM
                            • dicky96
                              Samsung UE39F5700AW - resets when pressing Menu
                              by dicky96
                              Hi guys I have this Samsung UE39F5700AW
                              It powers on, says Smart TV then goes to page sayiing No Signal (as I have no antenna or video source attached)
                              If i press MENU on the remote, or push the little joystick switch on the back, a large blue square scrolls on screen (like it is going to display a menu) then it goes blank, and restarts, saying Smart TV then saying No Signal
                              What causes this? Does in need the BIOS/Eprom flashing or something?
                              04-27-2021, 05:34 AM
                            • Retro140
                              Unnlock Menu for 2007 DU-27FB32C comerrcial CRT TV
                              by Retro140
                              So I was referred here when I made this poste over on AVForums: https://www.avsforum.com/threads/loc...lg-tv.3257234/
                              To summarize, this is a commercial TV and I can't get a menu of any kind. I know the overlay is working because when I change channel, adjust volume, turn on sleep timer I do see text. But I have not ever seen the user menu nor the installers menu. I've tried a bunch of remotes(more info on the AVF post) and tried every button...
                              06-18-2023, 06:13 PM
                            • Ierwin
                              Philips 58PUS7805 Menu working but no/weird picture from video sources
                              by Ierwin
                              I got a 58pus7805 that shows some weird behavior.
                              The menu and remote work fine and the picture is looking crisp and flawless while navigating the menu.
                              However, when a video source is displayed the screen either goes solid green (HDMI), solid black (SAT TV) or shows some fragments on mostly green background (AVI Playback from USB).
                              I tried to reinstall the firmware through the menu which was rejected saying it already had the latest version.
                              I managed to install the latest official firmware by holding the control button while plugging...
                              03-10-2024, 12:50 PM
