How do I test this power IC?
  • mattpd
    • Oct 2012
    • 302
    I am trying to repair a SMPS and have checked almost every other components except the power IC because I don't know how... Any tips?
    https://cdn.badcaps-static.com/pdfs/...003d10a613.pdf
    Also, this part:
    https://cdn.badcaps-static.com/pdfs/...391078abcb.pdf
    is on the secondary side. Should I test it too? How?
    Re: How do I test this power IC?
    You can do static Ohm test on the SMPS IC to see if it has an internal short which is all you can do.
    Check pin 7 (GATE drive) and pin 6 Ground
    Pin 7 and pin 8 VCC
    pin 1, 2, 3, 4, 5 and the pin 6 Ground to see if any obne of these pins are shorted to ground.
    By the way, make and model of the unit you are workig on?
    • mattpd
      • Oct 2012
      • 302
      Th42pd5u Panasonic plasma. Also right after I posted that I found a bad diode. D504 if my memory serves me right. I don't have the board in front of me now.
      Can I check the power ic in a similar fashion?
      • mattpd
        • Oct 2012
        • 302
        Sorry its Th42pd50u
