Drilling DVI port holes
  • spleenharvester
    • Mar 2010
    • 902
    Is there any easy way of doing this?
    I have an X223HQ, wonderful monitor but held back by the naff VGA port. Sick of auto-adjusting the thing.
    I also have a pair of Iiyama E1706S monitors which are missing stands, hanging around doing nothing. So I dismantled one for the fun of it.
    The controller port board appears to be the DVI version of the board in the X223HQ. So I was thinking I could maybe turn it into an X213H? Just need to drill a hole somehow.
    All I really have is a drill with a milling bit from the JML screw extractor set.
    Dell E7450 | i5-5300U | 16GB DDR3 | 256GB SSD
  • spleenharvester
    • Mar 2010
    • 902
    Re: Drilling DVI port holes
    Okay so I've connected the controller without drilling the whole just as a test. Got the problem I thought I may, it sees it as an E1706S with 1280x1024 resolution. The display is bloody good but is, of course, tiled. Is there any way of reprogramming it?
    • mariushm
      • May 2011
      • 3799
      Only if you can read the eeprom chips (if there are any), understand what each byte in it means and modify that, then maybe.
      • spleenharvester
        • Mar 2010
        • 902
        Hmm. Only other thing I can think of is swapping the EEPROM chips. But then the main controller chip is completely different on the other board. :/
        I tried forcing 1920x1080 on it but all it does is flash "out of range".
        • Th3_uN1Qu3
          Believe in
          • Jul 2010
          • 6031
          The display processor in that 17" monitor only supports 1280x1024 max. No way around it i'm afraid.
          A working TV? How boring!
          • spleenharvester
            • Mar 2010
            • 902
            Odd, the info sheet for it seemed to suggest it could do 1080p 60hz. Ah well I've given up anyway lol.
            Shame really cause it looked pretty amazing on DVI.
            Cheers
            • spleenharvester
              • Mar 2010
              • 902
              Bump to this. Is there any chance it's possible?
              The exact same board that could only output 1280x1024 is being used in monitors up to 23". So surely it's being limited by the EDID chips?
              Reason I ask is I have a W1907V that I'd like to upgrade to DVI. The board it has is a PTB-1769, which there is a DVI version of, but costs £30 :/
              Is there no way at all of transplanting the EEPROM chips (24C02WP on both boards)?
              • cheapie
                null
                • Jul 2010
                • 849
                I'd say just try it and see what happens.
                • fredyjbi
                  please help, friend, thinkpad L480 NM-B461 rev 1.0 JDOCK1 type C port 5volt only, thank you
                  by fredyjbi
                  I have a thinkpad L480 NM-B461 rev 1.0 laptop functioning normally with Type 1 port (JUSBC1)
                  if you use port type C 2 (JDOCK1) with a usb type meter it only displays 5v, thank you
                  I tried to look at the schematic diagram USBC_VBUS20, which is the port path from JusBC 1 to U4701 then goes to the system2 charging IC, why is there no system2 path leading to the charging IC on the TYPEC_VBUS20 port which is JDOCK1, thank you for your help.
                  if you look at the power sequence there must be 2 types of port type C a (JUSBC1) via U4701 and port type C b (JDOCK1)
                  On the type...
                  07-09-2024, 11:28 PM
                  by momaka
                  03-15-2023, 10:17 PM
                • televizora
                  Drilling holes laptop bottom
                  by televizora
                  I wonder if drilling a few holes in the laptop case, on the bottom below the fan will actually help and decrease the CPU/GPU temps. I have one spare not so new laptop with first gen core i5, but the main issue is that while the cooling systen is clean, it runs rather hot - youtube tends to bring the laptop to about 60-64 degrees, even if power plan with 60% power limit restriction is used and the cpu itself does not go above 1.2-1.4GHz. It has integrated graphics, this is true, but the temps seem a little bit high... Even the SSD runs above 55-60 degrees, while it isnt actually intensively used......
                  08-04-2021, 09:49 AM
                • Scarfycake
                  ASUS proart Studiobook h7600ZW; Had DC in port replaced and all the sudden it isn't charging but is the charging sign is on!
                  by Scarfycake
                  I sent my ProArt Studiobook 16 OLED (H7600, 12th Gen Intel) to the local repair guys to have a very simple DC in port replaced. I sourced the part myself on accessoires-asus (french company) after struggling to find the right part in the UK. It looked completely the same to the installed part from what I can tell. Originally the only issue with the laptop was a bad / loose DC connection, and so the computer and battery acted completely normal aside from a very poor connection that would fail at certain angles. After the repair was completed I brought it home and used it for...
                  05-21-2024, 08:16 AM
                • GlenBrim
                  1070 GPU. DVI port removed, wire in its place, why? Stuck on low clocks too.
                  by GlenBrim
                  I got this recently as-is. Gigabyte 1070 video card.
                  DVI port is removed. I don't know why.
                  A wire is soldered across two spots where it looks like the DVI port was. I don't know why.
                  I've read of people simply ripping out DVI ports and the rest of the cards still working fine. Never read anything about soldering a wire in there for some reason.
                  The card seems to work fine, except it's stuck in low clock speeds. While starting a game or benchmarking, the clocks may momentarily increase to around where they should be, then goes way back down and stays...
                  02-14-2024, 02:08 AM
