Ok to use 125v 8ah fuse in place of 250v?
  • toddrs93
    • Jan 2012
    no power to my 42inch plasma panasonic. found 2 separate 8amp 250v fuses just on the other side of the power supply. One is blown. the local electronics store says it will work fine with an 8ah 125v fuse. Is this correct?
    Re: Ok to use 125v 8ah fuse in place of 250v?
    If it is pn the primary side and supplied by 120V, then it is OK. If they are in the secodary side circuits and they are used in the circuits with voltage higher than 125 Volt then you need to use the 250V rating fuse, the voltage rating is made to insure that the current will not flow through the open fuse when the fuse blown, higher voltage can jump the gap of the blown fuse link inside the fuse. Be safe and use same rating.
    • selldoor
      Slow Learner
      • Dec 2010
      • 7870
      As above - it may work in that it would enable the set to come on but it is when it blows that the problem will occur - most boards have a message near the fuse saying you must replace with like for like same amps same volts same characteristics fast blow slow blow etc.
      Please update your profile with country and mains voltage ( Important for this type of question )
      • SmartVision
        • Jun 2011
        • 58
        I agree, why to take chances and risk when you can be sure. Bad fuse can make you a lot of damage to your plasma. So take a 250V rating fuse and sleep with a clear conscience.
        • 999999999
          • Sep 2006
          • 774
          Exactly where is it in the circuit?
          Have you found a fault and repaired that? If not, it's generally not a good idea to swap in a new fuse until the reason why it blew is determined. Putting in a fuse & powering on while the fault remains can cause further damage.
          Now a bit of speculation (guessing based on odds) The odds are the fuse only had to handle AC mains input voltage, that their design specified the 250V so it would handle operation in parts of the world where the voltage isn't 120VAC. Come to think of it you didn't tell us in your member profile where you are located so we don't know whether your power grid supplies 120VAC or higher.
          • Gadjet
            Looking for a Fuse T4AL/250V
            by Gadjet
            I've got a Monitor that's not showing any video, and I found this blown Fuse. As you can see from the photos, the board location has T4AL / 250V. Any assistance is greatly appreciated. Thanks!...
            06-15-2025, 09:16 AM
          • corrize
            A funny fuse story – Lumix LX100 II
            by corrize
            Hello, I disassembled this dead camera, and found this WTF… Two fuses soldered one above the other !
            I was pretty sure nobody touched it before, but that can't be from factory. There is flux, and capacitor is probably missing.
            The other weird thing : the fuses are « G » fuse : (0.75A – 8V), seems very low. The original fuse should be « O » : (32V 2,5A).
            There is « O » mark beside. All fuses have the same mark letter on main board. So, I can deduce it's a « O » fuse.
            And this correspond to the issus I saw : when I plug the battery, I measure the voltage dropping...
            10-19-2023, 09:58 AM
            Surface Mount Fuses Fundamentals Datasheet
            TE Circuit Protection offers the widest selection of surface-mount fuses available for addressing a broad range of overcurrent protection applications. Helping to prevent costly damage and promote a safe environment for electronic and electrical equipment, our single-use chip fuses provide performance stability to support applications with current ratings from .5A up to 20A.
            TE Circuit Protection also offers the telecom FT600 fuse for telecommunications applications. This telecom fuse helps comply with North American overcurrent protection requirements, including Telcordia, GR-1089,...
            10-07-2024, 06:07 AM
          • samtron786
            Thermal fuse AUPO P3-5A-F 250V testing
            by samtron786
            Hello everyone, how can you test a thermal fuse?
            I don't have a sign of life as an ohm or diode
            Thank you​
            11-28-2023, 08:39 AM
          • jesterace
            Samsung UE46ES8000 Blown fuse but no other signs of short
            by jesterace
            Hi I wonder if anyone might be able to steer me in the right direction. I have this Samsung UE46ES8000 TV and it went bang during use. The main fuse on the PSU board is open. I've checked every diode/mosfet/transistor I can see and nothing appears to be short to cause the fuse to go. The DC output of the bridge rectifier is not short either. I've seen online that some of these models are known for having their PFC mosfet or other mosfets shorting and blowing the fuse but i'm not seeing that here. If anyone aware of these models having any issues to cause this? I'm reluctant to just replace the...
            09-11-2024, 03:14 PM
