smoothing out voltage spikes and dips?
+ More Options
Posts
  • scampo77
    • 233
    #101
    Re: smoothing out voltage spikes and dips?
    yes
      Good, we are almost done then.
        By the way, in the final product, you should install 1/2 fuse, and may be a transient protection device rated at about 35~50V after the fuse.
        • scampo77
          • 233
          #104
          I am just finishing up trying to find out where bottom is and my rheostat in the tank opened. Is this cause I need a resistor larger than 200 ohm. I don't know if this happened from age or from bad circuit design. This happened when I was operating less then 7 ohm.
          Other then that it seems to be working beautifully.
          • ben7
            Capaholic
            • Jan 2011
            • 4059
            It likely burnt out.
            Muh-soggy-knee
              There is 200 Ohms resistor in series with the sensor, at worst case with lowest resistance on the sensor, the maximum current will be only 50mA (10V/ 200 = 50mA). Can you get the spec of the sensor? It has to be able to pass enough current to heat up the heating coil of the meter.
              http://auto.howstuffworks.com/fuel-gauge1.htm
              http://www.aa1car.com/library/fuel_gauge_diagnosis.htm
              • ben7
                Capaholic
                • Jan 2011
                • 4059
                50mA at 10V is half a watt, so it could have fried it, if it was only 1/4w or 1/8w rated!
                Muh-soggy-knee
                • scampo77
                  • 233
                  #108
                  when i pulled everything apart to fix the tank rheostat, where the failure was it was all blue and discoloured. it looked like a heat failure.
                  i am getting ready to make a regular board to mount everything to. i bought a circuit board that is just a sheet of copper with no holes in it. is there a chemical i can use to dissolve the copper or can i use a dremel tool to just dig away at parts of copper i dont need? i was just going to draw with a felt pen and then just start digging with a dremel, but i figured i would ask first.
                    "50mA at 10V is half a watt" that if the the sensor is at 0 Ohm, the 200 Ohms is spec in at 1 Watt. You will not 1/2 W of power on the sensor.
                    Simple Ohms laws applied here:
                    Do not forget that 200 Ohms will be in series with the sensor at 7 Ohms, so total resistance will be at 207 Ohms: then current will be 10V/207 Ohms = 48mA.
                    So you will have 48mA flowing through 7 Ohms, then the power on the sensor at 7 Ohms = 0.016 Watt.
                    When sensor at 100 Ohms, the current will be 10V/300 Ohms = 30mA.
                    So you will have 30mA flowing through 100 Ohms, then power on the sensor will be = 0.09 Watt.
                    1/8 Watt = 0.125 Watt.
                    My question is: Did you make sure that the 200 Ohms that I have in series is still correctly hooked up per diagram?
                    You can make even less current flow through the sensor by increassing the 200 Ohms, then just have calculate the max voltage will be fed into the IC, then adjust the Vref High to match that number.
                    I can also add constant current source to feed the sensor.
                    • scampo77
                      • 233
                      #110
                      yes the 200 ohm is inline it seems to measure 200-290ohm.
                      what should i do next? i am torn between moving forward with board design or redesigning the circuit.
                      do you think 48mA is enought to melt a thin wire like in a rheostat?
                        "So you will have 48mA flowing through 7 Ohms, then the power on the sensor at 7 Ohms = 0.016 Watt" As I indicated, when the sensor is at its lowest resistance, he power on that 7 Ohms section is only 0.016 Watt.
                        Can you get another sensor? if you can:
                        1) hook it up outside the tank that way you can read the voltage on the sensor when you move the viper from minimum resistance to maximum resistance.
                        2) Add another 200 Ohms in series with the original 200 Ohms, this will limit the maximum current to 20mA (10V/ (200+200+100) = .020A.
                        This will make the highest voltage to the input of the IC to be about 2V, you will have to change R3 from 1500 Ohms to be 500 Ohms to allow you to adjust the Vref HI to around 2V for #10 LED to be on (full tank).
                        • scampo77
                          • 233
                          #112
                          yes i have another sensor and i have also fixed the old sensor. i can pull it out to measure voltage. i will do this tmrw and report back.
                          i need to be more clear so i am understood. i was trying to find bottom on my tank so i was peeling around with the wiper at 2-10ohm for days. it failed but where it failed was at the top near 89 ohms, this is past the range of my gauge anyway. i took the top 10% of the rheostat, unwound it and put it tn the garbage and took the bootm 90% and just shorted it out to the top. it DID cook due to a heat failure but it did not physcially open at the 7 ohm spot. the rheostat seems to be working just fine i just dont want to blow it up a second time, next time i may not be as lucky.
                          the other sensor is in the second tank has been unused this whole time and in future use will be almost always sitting at 0-3 ohms. that tank is almost always empty.
                          when i am testing voltage on the wiper i just jab it anywhere on the wire? then move the wiper up and down? if this is true i will try it with the resistors i have in place already.
                          i wanted to see if it was getting warm so i hooked it up outside the tank and put the wiper at 0 ohm and it didnt get hot. i guess i had it backwards i will try the same thing tmrw with the wiper in the full position. and report back
                            When the sensor is at its minimum resistance, that when you will have the most current flowing through the 200 Ohms and the sensor, the 200 Ohms will be dissipating most of the power which does not make sense why the sensor is damage, and when the sensor is at 98 Ohms, the current flowing to the 200 Ohms and the sensor will be even less, at a bout 0.03A ) or 30mA.
                            So something is not making sense here.
                            What you can do also is to try using 10 Ohm 1/4W in place of the sensor and see how hot it gets. I have a feelings some thing is not connected right.
                            How many wires are there from the sensor, it should have only 1 wire since on end of the sensor will be already tied to the metal housing of the sensor assembly, any pictures of the sensor unit?
                              "yes the 200 ohm is inline it seems to measure 200-290ohm." What do mean by that? it is 200 Ohms or it is not.
                                So what did you find so far?
                                • scampo77
                                  • 233
                                  #116
                                  so this is how i have wired up this circuit. im not sure if its wrong or not. i am trying to figure out how to draw these circuit boards. so i dont have to use mspaint anymore.
                                    The left leg of the cap has to go to ground, see post78.
                                    • scampo77
                                      • 233
                                      #118
                                      Ooops my mspaint has failed me again. The cap goes from pin5 to ground
                                      Is my 200 ohm resistor in the correct parking spot?
                                        Yes, it still does not explain why the sensro failed with only 30mA flowing throug it.
                                        • scampo77
                                          • 233
                                          #120
                                          well i am willing to chaulk it up as it must have been an old sensor. also i am hoping that once i get off a breadboard and onto a PCB it will eliminate any rogue wires that may have touched down or possibly shorted out the sensor.
                                          now that the LED display seems to work, atleast in prototype. can i ask about the second part of this circuit or should i start a new thread?
                                          in brief i need a comparitor window to activate a 555 timer to engage a pump to transfer liquid. i can explain more here or i can start a new thread.
                                          • harp
                                            high voltage high resistance marking resistor
                                            by harp
                                            Is there any reason why high voltage high resistance resistor use weird marking and value on it? Standard nomenclature, EIA value not used?...
                                            08-26-2024, 01:42 PM
                                          • jinu_j
                                            by jinu_j
                                            Hi
                                            05-03-2025, 10:51 PM
                                          • mikey5791
                                            Need help to replace burned resistor in 350w atx psu
                                            by mikey5791
                                            Hi to all forum members,
                                            Got this faulty 350 watt atx psu dirt cheap from a local online seller as i am keen to use it as a learning tool to repair faulty power supply.
                                            The faulty part is quite obvious from the burn area near the 16pin KA7500 BD pwm. The fuse is still intact with good continuity.
                                            Upon power on ac, there is 5vdc standby power on cathode of diode D14 and about 10vdc on cathode of diode D13.(This should be the aux power to generate the 12v and 5v rail.)
                                            Initially i replace the two burned resistors near my marked red arrow to 200 ohm resistor...
                                            12-26-2024, 04:55 AM
                                          • rddube
                                            Lenovo L490 Ram voltage circuit malfunction
                                            by rddube
                                            Hello friends,
                                            Looking for some guidance here. The RAM voltage circuit on this motherboard keeps burning out PU301 which is a RT8231AGQW. Copy of the board with the burnt chip attached with some voltage measurements and copy of the schematics also included.
                                            I think I've checked almost every component in the circuit, but when I change the RT8231, the laptop starts I have 1.2V on the inductor for about 10 seconds and then the RT8231 goes south and no more voltage on the inductor. All other voltages on the laptop are good, this is the only one conking out for a reason I...
                                            07-15-2025, 04:41 PM
                                          • Fernon@Repair
                                            Gigabyte Z490 Gaming X Motherboard No VCORE Voltage
                                            by Fernon@Repair
                                            i have Gigabyte Z490 Gaming X Motherboard .it has a power on no display fault .. no vcore voltage and debug led stuck CPU LED .
                                            VCCIO voltage ok
                                            VCCSA Voltage OK
                                            VCCPLL Voltage OK
                                            Ram Voltage ok
                                            RamVTT OK
                                            VPP 2.5 OK
                                            But No Core Voltage
                                            and i want to this vrm ic datasheet or pinout (ISL69269)
                                            anyone have this ic pinout voltages?...
                                            06-25-2025, 07:19 AM
