Raplace same rate - not same size
  • kids
    • Oct 2005
    • 13
    What's happen if we raplace badcaps with good same rate but not same size? I want to replace 11 badcaps 1500uF-6.3V- 8mm by 1500uF-6.3V but ony 6mm. It run OK after it's replaced but it 's OK for long time? It can be broke again?
  • Shroomie
    • Apr 2006
    • 356
    Re: Raplace same rate - not same size
    If you're replacing them with good-quality capacitors, it'll be fine for a long time. As long as the rating is just as good, which it is, it shouldn't matter.
    You know there's something wrong when you open up a PSU and are glad to find Teapos.
    Why I don't buy cheap cases!
    • gonzo0815
      • Feb 2006
      • 1600
      Generally the bigger the longer the life. But of course any branded cap will last at least as long as it is rated for.
      But 6mm sounds very small to me, so make shure the ratet life, esr and ripple current at least meet the original or exceed them. Then you are on the safe side. Due to some improvements like aqueouse elektrolyte it is possible to reduce cap size dramatically, but those caps are usually 2000h rated.
      • willawake
        Super Modulator
        • Nov 2003
        • 8457
        • Greece
        what brand/series of caps will you use to replace
        • kids
          • Oct 2005
          • 13
          Re: Replace same rate - not same size
          I replaced GSC 1500uF-6.3V-8mm with Nichicon 1500uF-6.3V-6mm. My replaced mainboard is Gigabyte EP-3WEM2. All caps are around CPU (near FETs). It ran OK for 3 days. Hope for more long time.
          • howardc64
            by howardc64
            Problem
            08-04-2024, 10:36 PM
          • m1ch43lzm
            Notice to users of XGecu TL866II Plus / T48 / T56 / T76 programmers regarding BIOS backup file size
            by m1ch43lzm
            Hi everyone
            I noticed on the Xgpro software the BIOS backup files have extra bytes at the end when reading some chips, this is because the Xgpro software also reads the OTP region of those flash chips, and by default will append that region to the saved file
            Programmer models: XGecu TL866II Plus / T48 / T56 / T76
            Example: GD25LQ128D (1.8V), IC size is listed as 0x1000000 Bytes (16777216 bytes) + 0xC00 bytes, those extra 0xC00 bytes will be appended to the end of the saved file by default, resulting in a file size of 16780288 bytes
            There's also an extra OTP Secu.R...
            09-06-2025, 05:47 PM
          • dragometin
            Hitachi 40HYC42
            by dragometin
            TV Model: Hitachi 40HYC42
            Power Supply: 17IPS71
            MainBoard: 17MB95M
            Panel: VES400UNDS-2D-NO3
            When the set came in it was dead. Fuse was open primary side and the power mosfet was shorted. So I ordered a new power supply. Now it turns on, only displays "Hitachi" and then power off red and blue led flashing.
            I had to modify the 0ohm resistors in the led backlight of the new PS like the original power supply.
            Is there any variants on 17IPS71 power supply's?
            UART output pins 10 and 12 on scart connector:
            Code:
            12:24:04.595
            08-08-2024, 05:53 AM
          • szreder6
            HP Pavilion 14-ce0505sa, 5 long 3 short, no display. g7a-2g da0g7ambd1
            by szreder6
            Hello guys,
            I have a problem with my laptop as in the title, black screen, capslock displays error code 5 long 3 short, no voltage on the coils above the CPU, before removing the drive I had 0.8v there, power led flashed 5x long and the battery would not charge (current jumped from 0.5a to 2.8a), now on the power led I have a steady white light or orange when the battery is connected.
            What I did:
            - Laptop was not detecting ram, loose pins on ram slot, error 3.2 disappeared, ram working tested in another laptop
            As far as I know the laptop was in another service center...
            11-22-2024, 05:17 PM
          • ahmedtou
            HOW CAN I UPDATE HL-DT-ST BD-RE GGW-H20N XA02
            by ahmedtou
            help me please
            I have an HL-DT-ST BD-RE GGW-H20N with ROM version: XA02.
            When I tried to burn a 25GB Blu-ray disc using ImgBurn, I got an error.
            I will share all the details with you, including the disc information.
            Code:
            HL-DT-ST BD-RE  GGW-H20N XA02 (ATA)
            Current Profile: BD-R
            Disc Information:
            Status: Empty
            State of Last Session: Empty
            Erasable: No
            Free Sectors: 12,219,392
            Free Space: 25,025,314,816 bytes
            Free Time: 2715:27:17 (MM:SS:FF)
            Next
            08-27-2025, 08:49 AM
