DIY Car Battery Charger
  • mike9h29
    • Mar 2011
    • 60
    I want to build a 12v Car Battery Charger.
    What I have so far is a 18V Transformer. Is this good? or Its better if I find a 12/14v Transformer?
    Also, for the rectifier, is this good please? http://cgi.ebay.co.uk/ws/eBayISAPI.d...tchlink:top:en
    I will also buy a Volt Meter and Amp Meter.
    Any feedback is appreciated.
    Mario
  • 999999999
    • Sep 2006
    • 774
    Re: DIY Car Battery Charger
    It depends on what type of charger. If it's going to just trickle charge there's less to consider - just the trickle rate, but if it's going to float charge or use a termination method then you may have to account for the voltage drop across the regulation circuit.
    Thus, the rest of the charger design needs worked out first. Either way, with all else being equal an 18V (VAC) transformer is a bit on the high side. You could make it work but a 12V to 14V would be more optimal. Presuming the transformer isn't capable of 50A, yes the bridge rectifier you linked would work, though many of us might be charging at a lower current within which we already had a spare bridge rectifier lying around that would handle it.
    I have to wonder if it's a worthwhile project because by the time you buy all the components, including cables, clips or clamps, etc., let alone the time to build it, you could probably buy a complete ready to use charger with a charge termination circuit and meters built into it.
    • larrymoencurly
      • Oct 2004
      • 960
      Yard sales? I haven't come across a car charger yet with a bad transformer, mostly bad cables (broken at battery clamp or case strain relief) or shorted SCR (typically rated 50A) in automatic charges.
      • mike9h29
        • Mar 2011
        • 60
        Thanks for the useful reply.
        I have a battery charger already, but I want to build something and decided to build a charger
        I will search for a 12/14v transformer and use that.
        Thanks again.
        Mario
        • kc8adu
          • Nov 2003
          • 8832
          • U.S.A!
          junk 12v ups transformer.
          used one to repair a battery charger with a smoked transformer.iirc it was from an apc 650 with lightning damage.
          • mike9h29
            • Mar 2011
            • 60
            I opened a UPS today to take the Transformer but it has 5 wires on the primary side and 3 wires at the secondary side.
            Do you know which wires should I use please?
            Mario
            • 999999999
              • Sep 2006
              • 774
              ^ look in the UPS to see where those wires went. You need to find (trace) from the AC mains/wall outlet input to the ups, which winding that is, and trace from the battery back through its charging circuit to the other winding for that. Remember there is also the opposite that you don't need, the battery to transformer circuit to produce the AC output for the gear the UPS is powering when the grid AC shuts off.
              You might also see if there are markings on the transformer to help identify it, manufacturer and part #, or do a web search for the UPS model to see if anyone has discussed the parts internal to it, and of course, mention the UPS make and model here and provide some pictures.
                Or you can use the UPS batteries charging function if that section is still good for charging your batteries?
                • 999999999
                  • Sep 2006
                  • 774
                  ^ ha! The best answer, though with most UPS that circuit can only do a few hundred mA current AFAIK, Mario didn't mention the desired charge rate but it could be higher if he's considering a 50A bridge rectifier.
                  • Kiriakos GR
                    Banned
                    • May 2012
                    • 940
                    • Greece
                    I care for a true working Lead Acid battery desulfation - Pulse Generator.
                    If some one haves a good link just share it.
                    • kc8adu
                      • Nov 2003
                      • 8832
                      • U.S.A!
                      http://leadacidbatterydesulfation.yu...y#.T7zrCcWJJuY
                      • kc8adu
                        • Nov 2003
                        • 8832
                        • U.S.A!
                        the apc iirc had standard white/black on its secondary which becomes primary.
                        the 2 very heavy leads go to your rectifiers.
                        • Kiriakos GR
                          Banned
                          • May 2012
                          • 940
                          • Greece
                          Thanks, I am aware about this page, what I wanted was to find one person in this forum who will have made his own project.
                          Like: tested & working !!
                          In the above website they change the schematic almost every month. (experimental project)
                            NVDC charger configuration...
                            11-05-2024, 03:28 PM
                            ISL6257HRZ ISL6257HRZ-T Laptop Battery Charger Datasheet
                            Highly Integrated Narrow VDC Battery Charger for Notebook Computers
                            The ISL6257HRZ ISL6257HRZ-T is a highly integrated battery charger controller
                            for Li-Ion/Li-Ion polymer batteries. ISL6257 is designed for
                            Narrow VDC applications where the system power source is
                            either the battery pack or the regulated output of the charger.
                            This makes the max voltage to the system equal to the max
                            battery voltage instead of the max adapter voltage. Operating
                            at lower system voltage can improve...
                            11-05-2024, 04:43 PM
                            Modification of a Fluke multi meter that uses three AA batteries to use a 14500 lithium ion battery
                            by sam_sam_sam
                            I have had with regular AA batteries that leak this meter is expensive new I already replaced the battery battery clips once and the same thing happened again and I am tried of so it is getting modified to accommodate lithium ion batteries that are the same size excluding the positive terminal and removing the battery clips I will have enough room for the BMS protection board
                            I going to put 3 lithium ion battery in parallel with the BMS protection board and a way to charge the battery externally and heat shrink the battery pack and use a JST connector so I easily remove the battery...
                            12-31-2023, 06:04 AM
                          • Bowline
                            by Bowline
                            06-11-2025, 10:13 AM
                            Bauer tool battery pack charging with a HERCULES charger modification
                            by sam_sam_sam
                            The Bauer power tool battery charger just has to many issues with the charger over heating because I several HERCULES Hercules battery chargers that are 3 amp charge and because they have gone on quite a few times over the years before they came out with the fan cooling battery charger I going to modify one so I can charge Bauer battery packs faster than the crape battery charger that they have
                            Here is how this modification is going to be done I taking a 1.5 amp hour battery enclosure and gutting it removing the battery cells and replacing some Ryobi 1.5 amp hour battery pack that...
                            05-06-2023, 12:17 PM
