what are these things?
  • scampo77
    • 233
    i have a Bunch of these things which i originally thought were caps of some kind. but i recently blew up a thermistor and it looks just like these things. where i get confused is the units of measure printed on the side of these things, they all seem different i have K,n,V,J,u and some have strips like a resistor. I'm not sure what they all are or where to start cataloging these things or if i just throw them all away.
    K I'm guessing is Resistance?
    V volts?
    u micro farads?
    the J and the n have me most confused and J is on most all of them. any help would go a long way. i need a 2K ohm thermistor (QAD0012-202) and I'm wondering how to go about finding one in this pile.
  • Mad_Professor
    A Mech Warrior
    • Feb 2011
    • 1587
    Re: what are these things?
    Those good sir are ceramic caps.
    http://en.wikipedia.org/wiki/Ceramic_capacitor
    The labeling defines capacitance, volts and series and sometimes have a manufacturing logo stamp somewhere.
    • scampo77
      • 233
      all of them are? even the ones with stripes on them? can i measure them with a fared meter and just look for 25v,100v, etc... and use them like i would when replaceing a regular cap?
      are you sure they aren't thermistors?
      • mariushm
        • May 2011
        • 3799
        Those bean sizes ones with a L on them could be tantalum capacitors.
        • ratdude747
          Black Sheep
          • Nov 2008
          • 17136
          They sure are.
          Unlike cermic/mylar caps they ARE polarized... like 'lytics, the stripe marks the negative lead.
          sigpic
          (Insert witty quote here)
          • infringer
            Badcaps Member
            • Sep 2009
            • 244
            • United Frickin States
            some of them may be SCK's or thermistors hard to tell from the picture...
            Please note: I am not responsible for any harm caused to you anything discussed is just discussion. Before you try anything discussed be sure that you have the appropriate knowledge and safety gear for the job. Like with anything education and safety are first! Do not try anything @ home without it.
            • jsog
              • Feb 2011
              • 220
              The red rectangular ones are polyester film capacitors.
              • Evil Lurker
                Warranty Voider
                • Feb 2011
                • 454
                Remember, the red L on the tantalum caps indicates polarity. Tantalums are right opposite of aluminum electrolytics... the L indicates "+". NEVER subject a tantalum capacitor to reverse voltage or overvoltage, they WILL explode violently!
                • PeteS in CA
                  • Aug 2005
                  • 3583
                  • USA, Unsure of Planet
                  I see a mix with mostly disc ceramic caps, some film caps (probably polyester), some solid tantalum caps (the tear drop shaped parts) and a very few probable monolythic ceramic caps. That white or light mint green part in the center front of the pic may be an R-C snubber. That large brown part at the left marked "105K" is a 1uF, +/-10 film cap.
                  PeteS in CA
                  • scampo77
                    • 233
                    can i test them with a esr meter? or a farred meter? to check if they are good?
                    • Evil Lurker
                      Warranty Voider
                      • Feb 2011
                      • 454
                      Usually the preferred method is to use a DMM with capacitance capability to do the ceramic and foil caps, and use an ESR meter on the tantalums along with a DMM (provided the total capacitance is not over range... I think my DMM tops out at around 20uf).
                      • nmbb
                        Can not find Model/Value of Thermistor.
                        by nmbb
                        Machine: Autoclave.
                        Brand/Model: SANYO MLS-3780
                        Manual: (Sorry search option not working on this PDF)
                        Hello guys, this autoclave running with 2 thermistors already connected TH1 and TH3(on CN1,CN2 sockets). One for the water temperture and second one for chamber temperature. But there is another emtpy socket for optional third thermistor CN2 wich is for TH2 for object temperature. I wanna add the third thermistor TH2 to CN2 socket. But i can't figure what model/brand/value i need to use. In manual document, there is no info about TH1 and TH3 model number...
                        06-02-2022, 05:55 PM
                      • Use2bavolvo
                        Magic chef oven - thermistor ref voltage issue
                        by Use2bavolvo
                        I am having an issue with my wall oven temperature control is ~180f out of spec. The thermistor is measuring correctly but I noticed the ref voltage appears to be off. With the thermistor wires attached it's reading ~3.4vdc with the thermistor disconnected it's around I9.8vdc. my understanding is the temp is read off the resistance from the thermistor which leads me to believe the issue is with the ref voltage.
                        Another observation is the temp setting and readout at lower temps is way off meaning the oven thinks room temp is 300f and bake relay doesn't engage unless temp setting...
                        01-19-2023, 01:32 AM
                      • Quantum IC
                        Sony KDL-40BX450 LCD. Thermistor gets too hot 10 seconds after turning on the TV
                        by Quantum IC
                        Hello every one,
                        This TV came to me with the problem that it was totally dead.
                        The problem was the two MOSFETs and a fuse resistor in the power supply.
                        The original MOSFETs were KF7N50F and I repalced them with SLF65R700S2.
                        The original fuse resistor was 0.1 Ohm 1/2W. I didn't find a similar fuse resistor and I replaced it with 0.1 Ohm 5W ceramic resistor.
                        When I plug the TV the ST-BY LED turns on, when I press the power button on the TV, the ST-BY LED turns off and the TV doesn't turn on until the second time I press the power button is when the TV turns on,...
                        01-14-2022, 12:06 AM
                      • fab13
                        Thermistor exploded in two when turning on ps4 fat
                        by fab13
                        Hi there,
                        I have a fat PS4 with the fuse (5a) of the power supply which blows with each power on and there was a loud snap in the power supply and again the same problem after replacing the fuse.
                        I did not find a short circuit
                        The component that broke in two is an SCK 084 thermistor (See photo)
                        and measured at 11 ohm
                        So far I haven't received a thermistor.
                        Do you think that if I replace the thermistor and the fuse it should go away, because I have the impression that there is a strong current demand as soon as you press...
                        11-05-2022, 06:29 PM
                      • Rekoo1997
                        Ambient thermistor out of range
                        by Rekoo1997
                        dell latitude 5570
                        LA-C841P
                        i am check ph601
                        ph602
                        ph603
                        ph604
                        ph605
                        ph1302
                        all is ok and flash bios
                        and didn't fix
                        Can someone please tell me where to find this sensor and how to correct the problem?
                        04-21-2025, 10:35 AM
