Ceramic instead of Electrolytic
  • amanoob
    • May 2011
    • 12
    A cap on a old Mobo was shot and I didn't feel like ordering a part of the internet. I asked a friend to get a capacitor 680 UF
    10V
    LE 105C°
    GSC
    I didn't say Electrolytic but I assumed the one he would get would be.
    And he got me a ceramic 680Uf 2% SAN300v. Would I be able to use this, I think not but I want to make sure. Thank you.
  • Th3_uN1Qu3
    Believe in
    • Jul 2010
    • 6031
    Re: Ceramic instead of Electrolytic
    I don't think they make ceramic caps in values that high... are you sure you read the value right? Maybe it's 680nF, and in that case you definitely won't be able to use it.
    A working TV? How boring!
    • ratdude747
      Black Sheep
      • Nov 2008
      • 17136
      agreed. not to mention ceramic caps behave differently... there could be ESR issues.
      sigpic
      (Insert witty quote here)
      • amanoob
        • May 2011
        • 12
        Thanks, I figured it wouldn't work. BTW the cap says 680 and then it has a equal sign with a line through it.
        Do you think this would be a suitable replacement? http://search.digikey.com/us/en/prod...1745-ND/589486
        • b700029
          Banned
          • Sep 2010
          • 640
          I'd like to see pictures of this 680uF 300V ceramic cap.
          • Th3_uN1Qu3
            Believe in
            • Jul 2010
            • 6031
            If it says just 680 then it's a 68 picofarad not uF... A few orders of magnitude off. FYI: http://www.electronics2000.co.uk/cal...calculator.php
            That cap you found on digikey is general purpose and not for use on motherboards or switching power supplies, it has too high ESR and too low ripple current. This will work in that position: http://search.digikey.com/us/en/prod...1644-ND/756160
            • PeteS in CA
              • Aug 2005
              • 3583
              • USA, Unsure of Planet
              A 680uF, 300V monolythic ceramic cap would be huge! And the temperature coefficient would be horrible (e.g. the cap might be 50% of its nominal value inside a warm case ... maybe lower). I'm also highly prejudiced against large form-factor monolythic ceramic caps because they are brittle and tend to be destructive to PCBs when they crack and short.
              PeteS in CA
              • amanoob
                • May 2011
                • 12
                I found out it is a mica cap. I had no idea what they were before I searched for it.
                The only thing I am worried about with the cap from the link is that the one I have is 15mm x 8mm.
                Thanks again for all of the help. I plan on giving the computer to my little brother.
                • Th3_uN1Qu3
                  Believe in
                  • Jul 2010
                  • 6031
                  A look at the board will tell you whether a 10mm diameter is going to fit or not. My guess is it will.
                  • PeteS in CA
                    • Aug 2005
                    • 3583
                    Yep, mica dielectric, 680pF.
                    PeteS in CA
                    • Agent24
                      I see dead caps
                      • Oct 2007
                      • 5085
                      • New Zealand
                      I have noticed that when capacitors are labelled directly in pF they are done so without the multiplier. Hence 68 would = 68pF
                      Therefore, I would suspect that being labelled 680 would actually = 680pF.
                      Of course, the only way to know for sure is to check with a capacitance meter or if you have the datasheet.
                      -David VanHorn
                      • PCBONEZ
                        Grumpy Old Fart
                        • Aug 2005
                        • 10661
                        Right
                        Wrong.
                        PW is a Low ESR cap exactly equivalent to Panasonic FC.
                        That grade is commonly used on motherboards and in SMPS for the small caps.
                        On much older boards [P-2] they are even used in Vcore.
                        In fact I have 3 old Intel P-2 slot 1 boards in stock and they all have PW and FC in Vcore. [Big fat ones.]
                        [2 have one series and 1 the other.]
                        In SMPS PW [and PW grade] are REALLY common except for the final OP filter caps.
                        That said....
                        GSC LE is a higher grade than PW/FC for ESR.
                        The PW won't work but it's not because it isn't a low ESR cap.
                        It's just not low -enough- to replace this specific GSC cap.
                        Mann-Made Global Warming.
                        - Dr Seuss
                        • PCBONEZ
                          Grumpy Old Fart
                          • Aug 2005
                          • 10661
                          GSC LE 680uF 10v
                          ... 8x14mm 950-Ripple .060-ESR
                          ... 10x12mm 1030-Ripple .053-ESR
                          It looks like the 8mm so:
                          Equivalents
                          http://search.digikey.com/us/en/prod...376-ND/2433510
                          FR 8x11.5mm 950-Ripple .056-ESR [extra short...]
                          http://search.digikey.com/us/en/prod...1645-ND/756161
                          KZE 8x15mm 995-Ripple .056-ESR
                          Upgrade
                          http://search.digikey.com/us/en/prod...2365-ND/613726
                          FM 8x15mm 1240-Rippl .041-ESR
                          - Dr Seuss
                          • chth96
                            by chth96
                            03-09-2024, 10:03 PM
                          • Adenitz
                            Replace electrolytic cap with bipolar one
                            by Adenitz
                            can I use this cap:
                            https://www.tme.eu/en/details/ues1h4...tors/nichicon/
                            Capacitor: electrolytic; bipolar; THT; 47uF; 50V
                            to replace this capacitor: Electrolytic Radial E 47uF/50V 6.3x11 RM2.5 105°C Jamicon
                            What exactly I can expect to install bipolar electrolytic cap instead a regular one?
                            Thanks.
                            02-02-2022, 07:44 AM
                          • madscientist750
                            Replacing electrolytic caps by solid caps on old motherboards
                            by madscientist750
                            I do have several old pc motherboards which i recapped 10 year ago and some of those caps are bulged now.
                            I would like to upgrade them using solid capacitors. I do use them for testing and helping some alternative operating systems.
                            I would like to ask if such an upgrade can be done, what should i have in mind when replacing electrolytic by solid caps and if such thing exist, if there are caps list for old motherboards. I would have to figure out what caps needs each motherboard and then prepare a list to try to ask for them on some electronics stores.
                            10-19-2025, 06:10 AM
                          • Perry Babin
                            Electrolytic cap endurance
                            by Perry Babin
                            From what I've found, the endurance of a liquid electrolytic cap is determined by the loss of electrolyte. If a cap is rated for 1000 hours. That's typically for a straight run test. How would the life vary if the cap is intermittently heated to its rated temperature (105C). Maybe for an hour at a time then cooled back to 30-40C (just a random number). Would the life still be 1000 hours?
                            Does it make a difference in the life expectancy if the cap is heating from ripple current (internal heating) instead of from the external ambient temperature?
                            Why do polymer capacitors...
                            10-18-2025, 05:21 PM
                          • ten-d
                            Nippon Chemi-con 100uf 100v BP electrolytic cap
                            by ten-d
                            Hi all!
                            I just bought a pair of ADS L810 speakers, which I've heard are some of the best speakers from that time (late 70's) into the early 80's. I was super excited to test them out and hooked them up and I was very underwhelmed by the treble. The treble was awfully muffled. I've been doing some restoration work on 70's stereos and a couple of speakers here and there so I am really just a beginner. I do know that capacitors in speaker crossovers filter out the lows to allow only the highs up to the tweeters and mids. Inductors filter out the highs to allow the lower frequencies to...
                            01-30-2024, 05:18 PM
