Help identify
  • cmj21973
    • 267
    Help identify
    Need to know I'm reading this right.
    .1 uF 10% 400V
    ESR test = 16
  • cmj21973
    • 267
    Re: Help identify
    If I'm reading the markings right, then this should be a good substitute.
    http://search.digikey.com/us/en/prod...452-ND/1089732
    • PCBONEZ
      Grumpy Old Fart
      • Aug 2005
      • 10661
      Re: Help identify
      I -think- you're right. [Never had to order one of those.]
      Don't forget to check lead spacings.
      Mann-Made Global Warming.
      - Dr Seuss
      • cmj21973
        • 267
        Re: Help identify
        Thanks PCBONEZ.
        I made sure to measure H; L; W; and lead space.
        FYI
        I'm repairing the control board to an Onan generator (300-3056). It's a first gen. board and is obsolete. The replacement board is a third gen. board that cost about $124 to $188 excluding S&H.
        I have not seen resistor like the ones on this board.
        • Tube_Dude
          • Feb 2011
          • 51
          Re: Help identify
          Hi
          Are you sure the cap need substitution?
          This type of caps rarely fail, at last in my own experience of more than 40 years sniffing solder fumes...
          • cmj21973
            • 267
            Re: Help identify
            Originally posted by Tube_Dude
            Hi
            No, I don't need to replace it now that I know it's a .1uF 400V. An ESR of 16 makes scents now.
            • cmj21973
              • 267
              Re: Help identify
              UPDATE:
              Board was reinstalled. Blew a diode I soldered in backwards.
              Replaced 1n4006 diode with 1n4007. Radioshack doesn't have them or in the25 assortment pack.
              Board reinstalled. Blew the same diode even though in right direction.
              Upon inspection, found 16D nail in cummutator/collector rings area.
              With nail removed and 1n4007 replaced, "third times the charm". The board was reinstalled. Finally success! Onan generator running and working fine.
              $15 in components saved over a $100 for new board.
              • PCBONEZ
                Grumpy Old Fart
                • Aug 2005
                • 10661
                Re: Help identify
                Yup, them nails will do it every time!
                - Dr Seuss
                • kc8adu
                  • Nov 2003
                  • 8832
                  • U.S.A!
                  Re: Help identify
                  so how did the nail get in the alternator?
                  • cmj21973
                    • 267
                    Re: Help identify
                    What was thought to be a 16D nail turned out to be a very rusted/corroded square drive screw. Like the ones holding the floor in the RV it came out of.
                    More than likely it fell out of rotten RV floor and got lodged somewhere on the generator.
                    My brother had already cleaned the cummutator and collector rings. My guess is while he was put it back together, it got knocked loose from its' hidding place and ended up in there.
                    • PeteS in CA
                      • Aug 2005
                      • 3583
                      • USA, Unsure of Planet
                      Re: Help identify
                      I'm a little confused on that .1uF film cap. The picture is of a Roederstein MKT1822 part, but the linked datasheet is for Evox-Rifa MMK series film capacitors (the MMK series was originally from Evox). At any rate, if the dimensions for the part from Digi-Key are correct, it should be fine. Made now by Epcos, it was originally a Siemens part, and the dielectric for it and the original Roederstein part is polyester, which is excellent for GP usage.
                      PeteS in CA
                      • thesame
                        DVR HIKVISION DS-7208HWI-E1/A BOARD DS-80104 REV 2.2 help identify burnt components
                        by thesame
                        Hy guys , i have a DVR board DS-80104 REV 2.2 that was powered wrong, i have some smds on the board that are blown and i can't identify them , maybe if someone has this board somehow and we can identify the smds', i have searched online and i can't find a schematic.
                        The smds are SOT-23-6 , one of them i think it has the marking ADJF since i found another one on the board with this marking , but the other one it seems that it starts with AG or it looks like. I would really apreciate if someone could help me identify those IC's .
                        02-27-2024, 04:31 AM
                      • silver60618
                        Lenovo Legion 7 - Help Identify IC
                        by silver60618
                        Hi gang, its a long shot, but working on Lenovo Legion Pro 7 motherboard NM-F091, and trying to identify this component near GPU with marking "eHFQH" that is burned and shorting the board. Looks like power management IC
                        I couldnt find any schematic or boardview. The CPU side also has same chip. Any way to identify this chip? or take measurements from the good chip to determine what it is?
                        Any help would be appreciated...
                        07-02-2025, 12:16 PM
                      • SuperAman
                        PS5 HDMI port diode reading?
                        by SuperAman
                        I did an hdmi port repair for a PS5 and I lost the small diode z71 SOD923 on the back of the port. I did a trace repair for pin 19 of the port as well. Without the diode I get no display at all. I tried replacing the diode twice but after I get flux on it the marking comes off so I can't tell if I have it on the right orientation. When I measure I get a reading of 1(open) and 923 in diode mode. Is 923 a normal reading for these and also which side should the reading be with regards to the arrow on the board?...
                        02-03-2024, 10:16 PM
                      • chth96
                        How can I identify varistor which have been blew up?
                        by chth96
                        I mistakely pluged 100v japanese retro game console to 220v outlet.
                        So It seems that glass fuse and varistor have been blew up.
                        I can identify that voltage and ampere value of glass fuse(250V LF 1.6A),but It is impossible to identify varistor type in my sega saturn PSU(YAMAHA 35M07U XR258)
                        Is there any way to identify varistor type in my sega saturn PSU?
                        Any reply would be appreciated.
                        EDIT:
                        It seems that I finally found out what type this black varistor is. It is Panasonic ERZV05D221 “ZNR” Transient/Surge Absorbers (Type D) Varistor Voltage...
                        11-26-2023, 08:52 AM
                      • Fuzzy Fix
                        0.00 ESR reading on a capacitor
                        by Fuzzy Fix
                        Howdy all I have a 90uF Capacitor 200/275 VRMS and measured the ESR . Reading says 00.3 Ohms and about 1/2 a second later 00,0 and says low ESR (Really No Kidding).
                        I have checked it on the multimeter and reading is 94.7uF well within soec as ir has a 25% tolerance on it.
                        Can anyone advise me is this capacitor likely to fail in the near future or still good to use.
                        07-26-2024, 12:05 AM
