0.00 ESR reading on a capacitor
  • Fuzzy Fix
    • Apr 2022
    Howdy all I have a 90uF Capacitor 200/275 VRMS and measured the ESR . Reading says 00.3 Ohms and about 1/2 a second later 00,0 and says low ESR (Really No Kidding).
    I have checked it on the multimeter and reading is 94.7uF well within soec as ir has a 25% tolerance on it.
    Can anyone advise me is this capacitor likely to fail in the near future or still good to use.
  • CapLeaker
    Leaking Member
    • Dec 2014
    • 8327
    You can't trust a small ESR tester on higher voltage capacitors as they don't show leakage.
      • 31198
      what tester was it?
      • redwire
        • Dec 2010
        • 3912
        MS22 series is motor start, aluminum electrolytic. Duty cycle small at 1.67%
        I think an ESR tester needs high pulse-current to measure decently, a flea fart tester will not measure accurately. Even then, there are no ESR specs for these type of caps. Similar parts ESR 1 to 2Ω.
        Motor start/run caps have a safety discharge resistor in them, typ. 32,000Ω for 220VAC rated cap. so measuring resistance it will top out at that, looks like a low value but is OK.
          • 31198
          if it has a discharge resistor you cant test capacitance or esr
          • redwire
            • Dec 2010
            • 3912
            Motor start/run caps have agency approvals which include the resistor. Here I think it's BS5267.
            If the cap tester is dual-slope (measures both up ramp and down ramp) I think it can work despite the safety discharge resistor making it appear leaky.
            ESR you need 50mA pulses I would say like the Blue ESR meter can do.
            Op's cap could be dodgy chinese stuff, Aerovox website dead and it does look a little fake.
              • 31198
              it's not fake, just ancient
              https://www.procureinc.com/manufactu..._Rifa_-_Kemet/
              • redwire
                • Dec 2010
                • 3912
                Motor capacitor made in the UK? Ends up in Australia? Next you'll be telling me the earth is round lol.
                They usually dry out and capacitance value drops, so I would not replace it, check if a date code on it.
                I would expect it to last if it's not in a hot location like mounted on the motor etc. and vibration also can make them fail. It really sees only seconds of use with every motor start.
                OP's ESR meter seems suspect, the test leads, the battery, the zeroing etc.
                If in doubt, test it using a resistor say 1Ω, see what it reads.
                • MORETTIGIAN
                  by MORETTIGIAN
                  Title:
                  Description:
                  Procedure performed:
                  - Removed backplate
                  - Reapplied thermal compound
                  - Reassembled card
                  09-18-2025, 12:14 PM
                • Prolog
                  by Prolog
                  12-01-2024, 08:27 PM
                • chth96
                  by chth96
                  12-22-2023, 04:34 AM
                • chth96
                  by chth96
                  06-02-2024, 07:31 PM
                • chth96
                  Is it no harm to replace with capacitor without ripple current rating?
                  by chth96
                  When I tried to repair LG 29 inch CRT TV, I found that the ESR value of samyoung SMS capacitor(160v 2.2uf), which is very close to D1879 transistor, is 6 ohm.
                  Judging from above ESR Meter Table,I think It is necessary to replace this sms capacitor.So I visited local electronics shop,and I purchased 160v 2.2uf rubycon YK capacitor.
                  But when I browse through rubycon YK datasheet,I found that there is no ripple current rating for 160v 2.2uf specification. But On the contrary, I found 39 mA ripple current rating for 160v 2.2uf SMS capacitor.
                  Rubycon YK DataSheet (b...
                  04-19-2024, 05:19 AM
