Strange Voltage on long lan csbles and generall grounding praxis
  • gonzo0815
    • Feb 2006
    • 1600
    i`ve noticed in many instalations, that if i tuch lan cables shild an ground that there are some Voltage on those lines. Now i examinated my computer and i have seen some sparcs arcing from the case to the speaker jack if i plug it in slowly. If i disconect the lan cable this arcing stops.
    (my lan starts on the 1 flor an gos down to eart flor thru some cheap switches with build in cheap sps)
    Now ive discussed this with a friend which is an professional in this area and he said that this is may be due to the stupid grounding praxis in germany, where we ground both sides of the cables. I ve read many about that currents in the internet, and i read several arcticles that those currents are derrived from switching power supplies without A-PFC or bad y caps (like those bad and unsafe ceramic in cheapo PSU´s), as those phase shift currents will somhow went to the neutral and earth lines. Now i have changed many PC suply with a-pfc ones, as they are IMHO in many ways better than the others. But the Volltage never disapeers. Even if i tried to ground the lan calbes close at my pc this arcing never stops I tried to cut the ground of the lan calbes, but this wou`t help either.
    My friend told me, that if they have to do changes in building to building cables in large idustry complexes, they have realy high currents on the earth lines, so they have to use very very large calbes for it, if they will bypasse such calbes. No one cares where thos currents come from. I know in USA, shilds should only be put on one side tho ground. What is your experience with those things?
  • willawake
    Super Modulator
    • Nov 2003
    • 8457
    • Greece
    Re: Strange Voltage on long lan csbles and generall grounding praxis
    http://www.epanorama.net/documents/g...ck_wiring.html
    interesting.
    do you get shocked touching the back of the computer cases? you should test the mains power sockets, there may be a poor ground.
    • Per Hansson
      • Jul 2005
      • 5895
      • Sweden
      I would say either your house has no proper grounding at all, or the grounding is in the electric grid behind only one of the computers, and therefore the other computer will use the LAN cable as grounding for itself through the other computers working ground.
      This is very very common if you connect two buildings together, because since they do not share a common ground there will be ground potential differential; and it will try to level out through the LAN cable...
      You will either have to fix the grounding problems or use fiber optic cable, there is no other way to fix it I am afraid
      • gonzo0815
        • Feb 2006
        • 1600
        Thx for answers.
        No, iget not shocked if i touch the back of the pc case.
        The socket of the used psu`s are all good and are properly grounded. even the cheep switches are properly grounded, i cheked this with an dvm. I have often seen such kind of strange voltage on lan cables, not only in my installation.
        The grounding of the house is ok, at least what i have seen there are the normal grounding cables from the basement to all floors. All pc`s are now equipted with a-pfc psu`s from either Seasonic or Enermax.
        The only theoretical explanation would be the resistance of the thik groundingcable running from the zentral grounding point. May be i should chek the whole way of the grounding calbes, may be is there some connectionoxidiced or coroded.
        • Decade
          • Dec 2005
          • 37
          You are right Per but there is one thing more induced mains fields, long cable runs will most probably pick up more and result in bigger potential differences. Even equipments that are not safety grounded will have some potential differences against a real ground.
          • gonzo0815
            • Feb 2006
            • 1600
            @will
            this article is exaclty describing what the problem is, i think so far. But never the les, the building is grounded es Germanies VDE suggest. I can`t install ne grounding wires only due to one lan cable going through the house. But ok, may be i disconect the shild of the installation cable and thus this will help. But as far as i think i am only using some unshilded cat 5 patchcables.
            • Prott
              PS5 - long screw damage, via to ground layer short?
              by Prott
              Hello dear Badcappers,
              I came across a PS5 that was longscrewed. The screw went through the HDMI IC (which I replaced + repaired the traces it damaged), however the screw also bend the board and slightly cracked it on the other side. It still seems like it could be fixable though as the area might not have lots of traces going through it (fingers crossed).
              Can somebody, please, measure their board and tell me if my assumption of an inner short between the via and ground layer is correct? These 3 pads have almost no resistance. I would like to make sure those are not some data...
              07-27-2024, 08:54 AM
            • howardc64
              by howardc64
              Problem
              08-04-2024, 10:36 PM
            • mkdj
              Acer TravelMate P214 - N19Q7 main power rail shorted to ground
              by mkdj
              Dear all,
              I have taken out the motherboard of a Acer TravelMate P214. There is a short to ground on the main power rail (19V). I don't have the schematics or boardview for this board (DAZ8IMB1AA0 REVA). But I have found 4 MOSFETS close to the main power rail : 2 N-Channel and 2 P-Channel.
              I have checked resistance across each of the 4 MOSFETS. I have the following readings:
              Both N-Channel Mosfets: nothing odd
              P-Channel MOSFET number 1:
              source - drain : 117 kOhm
              source - gate: 96 Ohm
              gate - drain: 117 kOhm
              P-Channel MOSFET...
              08-20-2025, 06:08 AM
            • barry101
              Apple 820-3662 VCore shorted to ground.
              by barry101
              Hi, Would appreciate some help.
              I have an Apple Late 2013 15" A1398 MacBook Pro with Logic Board 820-3662.
              Get charger light but no fan spin or chime. No liquid damage.
              Found PPBUS and VCORE both shorted to ground. Other rails were ok.
              Removed VCORE MOSFETS U7310, U7320 and U7330. Found U7330 was in fact shorted.
              With the 3 MOSFETS removed, get PPBUS and fan spin. VCORE is still hard shorted to ground (0 ohms).
              Attempted voltage insertion on VCORE to locate short using bench supply set at 1.0 VDC and 4.95 Amps (max current for my...
              06-24-2025, 07:34 AM
            • Chaks
              Ground Plane For 5dBi ISM Band 865-870Mhz Embedded Ceramic Antenna
              by Chaks
              TAOGLAS ANTENNA MODEL: ISPC.86A.09.0092E
              The specs says ...
              High antenna efficiency 868MHz ISM Band
              5dBi Peak (when placed on 30cm x30cm ground plane) - Broadside to Zenith Radiation Pattern
              The antenna is 50x50 mm square and How do I fix it on the Ground Plane of 300 x 300 mm (aluminium sheet 3mm thick).
              1. Should I Fix it with a glue.
              2. Should I fix it with a double side adhesive tape
              3. Should I fix it with Screws (the screw head may just clamp the antenna to the aluminium...
              12-09-2024, 11:06 AM
