help identifying resistors
  • testas86
    • May 2010
    • 140
    My dad brought home this logic board with some burnt out resistors and i was going to replace them for him but i cant figure out what the resistance was (the resistor burnt out)
    here is the info i found on the board
    24-0316
    rev P1
    remote adapter
    Gas tech inc.
    11170178
    57-7705 rev B
    0819sw034268442
    the burnt out resistor is R7
  • killian6pk
    • Apr 2010
    • 502
    Re: help identifying resistors
    Did you try using your DMM to check the ohms? Can you see the color code the picture is too blurry when I tried to do a closeup view?
    Have you ever stopped to think and then forget to start thinking again?
    As a very wise man once said on this forum: "Of all the things I have lost I miss my mind the most."
    • testas86
      • May 2010
      • 140
      the color code is burnt off otherwise i could get the value from that. so i dont know if i can trust the value i get off my DMM cus the resistor is physically burnt through
      • Jack Crow
        It's a CLASOB!
        • May 2008
        • 823
        T,
        If your careful, very often the colors will still be there on the bottom of the resistor.
        Just one hint, burned resistors are a symptom of a problem, not usually what caused the problem.
        Jack Crow in VA
        "You are, what you do, when it counts"
        The Masso
        "Gravity, the quickest way down"
        Mayor John Almafi
        "You ever drop an egg, and on the floor you see it break?
        You go and get a mop so you can clean up your mistake.
        But did you ever stop to ponder why we know it's true?
        If you drop a broken egg you will not get an egg that's new?"
        MC Hawking
        • testas86
          • May 2010
          • 140
          ive removed the resistor and its burned all the way arond. the only bands i can see are the first and the last which are both brown and the problem in they unit has been fixed. someone wired something incorrectly
          • b700029
            Banned
            • Sep 2010
            • 640
            I see an LM324 which has 4 opamps in it, R2 and R3 which might be in parallel, and burnt R7 is the same color as R5. They're both beside another resistor of a different but same color.
            Do R4 and R6 have the same value? Then R5 and R7 might also have the same value. All that symmetry makes me think so but I'd check to be sure. Trace the board and draw a schematic. If the device has two identically wired channels and the burnt resistor is part of one channel then it would likely have the same value as its counterpart in the other channel.
            • jwsdevil
              • Aug 2011
              • 3
              Do you have the name and model # of the unit it came out of?
              • CG2
                LED uplighter dimmer burnt resistor
                by CG2
                I've got a 240v LED uplighter which isn't working. Pulling it apart shows a clearly burnt resistor on the circuit board, and I'm hoping some of you will have suggestions on what to replace it with. First, here are some photos. Power comes in, through the fuse and choke, then through the big blue variable resistor labelled B500K (ignore the similar blue component at the bottom - it's a simple switch for an attached reading lamp). It then passes through the burnt resistor (or at least did once), through diac DB1 and the unburned 30 ohm resistor to the gate of the triac.Now I assume there's a simple...
                02-14-2024, 09:23 AM
              • trickartt
                Allen & Heath Xone:02 (DJ Mixer) - Burnt out Resistor
                by trickartt
                Hello Badcaps!
                I am trying to troubleshoot my Allen & Heath Xone:02 DJ mixer. I have had this for somewhere close to 20 years and have played music through it in one form or another pretty much every single day since I've had it, though these days it's usually from a wireless streaming receptacle (Apple Airport) more than the turntables that are also connected to it.
                This week my music stopped working, and after a bit of a wild goose chase, I realised my mixer was dead. I checked the 500mA fuse in the device beside the power supply and found it was blown, so I replaced...
                05-04-2024, 12:07 PM
              • ugamazing
                Assistance with identifying resistor value on 820-02918 A2992 board?
                by ugamazing
                Working on a 2023 M3 A2992 unit with 820-02918 board, and it uses a new USB-C power architecture, with rectangular controllers. I do not have a perfect-matching board, so have been repairing this one the old-fashioned way (slowly).
                I managed to blow-away a single resistor that I can't find and can't determine the value of. It connects to ground, so I went ahead and stuffed it with a 100K resistor in case it's a simple pull-up. But, I'm now having issues with that side of the board, and am curious if it's possibly related to this resistor! I have no schematics and no board view, so...
                09-06-2024, 08:33 AM
              • dutchgaucho
                Need help identifying resistor on Asus FA507RC DA0NJNMBAD0 schematic
                by dutchgaucho
                Hi colleagues,
                Looking for a schematic DA0NJNMBAD0 or the MP2845A 6-phase PWM controller.
                Working here on a DA0NJNMBAD0 rev D motherboard (Asus FA507RC) with liquid damage. Board has some tiny corrosion around the MP2845A controller and one resistor is missing. I need to know the value of the resistor, but no schematics are available. Not even for the MP chip or anything similar (this is a 6 phase PWM controller).
                On one side of the pad 20V is present. The other side connects to a cap and to pin 16 of the MP2845A. Resistor seems too small for VCC...
                11-09-2023, 11:27 AM
              • unimatrix93
                Identifying backlight resistors, power supply is a BN44-00852
                by unimatrix93
                Dear forum, I would like to ask some help identifying the backlight circuits resistors to limit the ampere to the backlight leds.
                The power supply is a BN44-00852 and I want to decrease the backlight to increase the lifetime of the LEDs.
                The TV is pretty much always on, used for CCTV cameras.
                I suspecting R9838 -> R9841 resistors but I'm not sure. Thanks in advance!
                04-29-2024, 04:49 AM
