How to remove permanent magic marker ink from plastics/LCD screens/painted stuff.
+ More Options
Posts
  • Evil Lurker
    Warranty Voider
    • Feb 2011
    • 454
    Here is a helpful hint... the recent PCB cleaning thread got me to thinking bout this. Very handy information to know for when the kids get ahold of magic markers and decide your 52" tv would make a perfect canvas for their artwork.
    Yes you can safely remove permanent magic marker ink from most hard plastics, LCD screens, even stuff that has been dried for years using DMSO as the solvent. In most cases it will get it off permanent marker ink completely leaving no or very little trace of ink.
    DMSO is found in most rural supply stores as horse linament. Its completely safe for use on plastics, but you might have to keep it a bit warm since it crystallizes around room temps. And oh yeah, try and keep it off your skin since it can be absorbed transdermally. Its not considered dangerous, but it does leave a funky taste in your mouth... sorta reminds me of pressure cooked cabbage.
  • b700029
    Banned
    • Sep 2010
    • 640
    Re: How to remove permanent magic marker ink from plastics/LCD screens/painted stuff.
    Another trick I've heard is to use an eraseable whiteboard marker to solvate the dried ink, and then wipe it off.
    • jsog
      • Feb 2011
      • 220
      Ordinary rubbing alcohol will remove Sharpie "permanent" ink from a lot of things.
      • Th3_uN1Qu3
        Believe in
        • Jul 2010
        • 6031
        Yes but it'll also leave traces of its own... it is especially bad for transparent plastics.
        A working TV? How boring!
        • Krankshaft
          • Jan 2007
          • 2328
          I will only dull the cheap plastics I've found.
          There are buffing and polishing compounds to remove the light haze.
          • larrymoencurly
            • Oct 2004
            • 960
            Waterless hand cleaner
            • mathog
              • Mar 2010
              • 2655
              The DMSO itself isn't bad, but whatever it carries with it into your body might be. Google and you will find that the consensus seems to be that thick rubber gloves (ie, chemical handling gloves) should be used. Some of the other glove types dissolve in the stuff.
              • Rangefinder
                • Dec 2010
                • 11
                • Gods country until the Politions got ahold of it...
                Save a trip, WD-40 contains DMSO.
                • Uranium-235
                  Comrade Glimmer
                  • Aug 2007
                  • 5042
                  • US
                  yeah and a bunch of other shit too
                  best way to keep screens clean...not have kids to write on them in the first place
                  • mathog
                    • Mar 2010
                    • 2655
                    I don't think so. At least it isn't listed specifically on the MSDS, and it would be a strange ingredient to mix in with a bunch of oils. If DMSO is present there cannot be much of it, since the vast majority of the ingredients are hydrocarbons and oils.
                    • thisguy
                      • 19
                      DMSO is absorbed quickly into the skin. That's why you can often taste it when you handle it without gloves. As long as it not mixed with anything poisonous, I think it should be safe.
                      • killian6pk
                        • Apr 2010
                        • 502
                        The reason DMSO is in horse liniment is that it helps the stuff get absorbed. My grandmother used horse liniment for years (this was before icy hot and the like) for arthritis. It stunk to high heaven, but seemed to work for her. Don't know what that has to do with LCD screens. Just throwing it out there.
                        Have you ever stopped to think and then forget to start thinking again?
                        As a very wise man once said on this forum: "Of all the things I have lost I miss my mind the most."
                        • tommy97
                          MacBook A1932 & A2337 MDM - Permanent solution?
                          by tommy97
                          we're getting quite a lot wiped A1932 & A2337 from scrap with MDM (Remote management), we'd like to find permanent solution to remove it without CPU swap as it gets not economical, I found iremove.tools website which offer permanent solution, however if they got shut-down i believe laptops would also get locked? Does anyone have any knowledge about this service & about any other possible method?
                          06-18-2025, 02:43 AM
                        • Borteck
                          Apple Magic Keyboard A1843 EMC 3138
                          by Borteck
                          My Magic Keyboard with numeric keypad and no TouchID has lost its magic and doesn't work anymore. Not by Bluetooth nor with direct lightning/usb cable.
                          The model is A1843 EMC 3138 and logic board 820-00789-A.
                          Does someone have the schem and boardview please ?
                          Voltage test points would be much appreciated !
                          Battery is charging : 4,2v on pin 4
                          Thanks a lot
                          A.
                          09-26-2023, 07:44 PM
                        • smurtz
                          Cambridge Audio Stream Magic 6 - Power Supply
                          by smurtz
                          I have here a Cambbridge Audio Stream Magic 6 which does not power on.
                          When opening the case the PSU appears to be faulty:
                          IC1 (ICE3BR0665J), D2, the rectifier bridge, C15,C16 are dead and T2 is fried:
                          I found the schematics of the PSU in the cambridge Audio CXN Service guide which uses the same:
                          My problem is that I cannot find any info on T2 (SG01323) which seems to be a choke. Anyone knows how I can find a replacement & the value of that choke ?
                          Thanks very much in advance...
                          12-20-2024, 02:40 PM
                        • alfatv
                          LG 47L5700, add RF emitter for magic remote
                          by alfatv
                          This is 2011 LG model.
                          There is an option to add AN-MR200 magic remote, but it requires another dongle connected to TV.
                          I got a hold of plasma TV from the same year which works with magic remote and comes with so called RF emitter inside TV. I confirmed that it's essential for magic remote operation by unplugging it.
                          So, the idea is to install this RF emitter into 47LW5700, has anybody tried it?
                          There is unsoldered connector on main board possibly for it.
                          Here is ebay listing for this module:
                          https://www.ebay.com/itm/New-LG-60PZ...7LW6500-UA-55L...
                          01-05-2021, 12:28 PM
                        • tmcw
                          NEY Ultrasonic bath - magic smell
                          by tmcw
                          Does anyone know much about ultrasonic baths?
                          I got one here at work, a NEY Ultrasonik 2QT/H, was in the trash, lovely smell of "magic smoke" having recently been emitted. Might have been the Engineering Dept that dumped it.
                          Anyway, the sonic and heating lights on the front come on when plugged in and switched on, but no familiar noise I'd expect (like the sound effects from old Flash Gordon tv series of the 30's).
                          Opened it up, and see some remains of something that was on the piezoelectric device on the underside of the bath, but not sure...
                          04-19-2023, 05:14 AM
