power inverter cap
  • justinf89
    • Jun 2011
    • 5
    power inverter cap
    Hey guys, first post. I've been looking over this forum for a few weeks now. It's pretty neat that there's a website dedicated to caps. I'm a computer/electrical engineer in college so I do have a little knowledge.
    Here's my question. I started a project today to wire up a 500w power inverter on my boat. I grabbed the inverter (vector sst max 500w) to test it with the alligator clips it came with, and about 5 seconds later, wham a lam, a huge pop from it and it shut off. Of course, I was up close looking at the led since it was bright out. Anyway, I've never used this inverter and it's probably been sitting for about 2 years on the shelf. After the loud pop, it turns back on normal but no voltage. I opened it up and sure enough, one of the 2 caps I can see had popped out the top and tore off the wire underneath(+). The caps are 4700uF xunda 105c 16v. I'd like to repair it but my question is, could there be something else wrong that would cause the cap to explode like this? I don't want to replace it and it happen again. All I did was clip it to the battery, no load, turn it on, and boom, explosion. My neighbor even looked over to see what happened. I even checked the polarity of the clips just to be sure I wasn't stupid or something but all was well.
    Please feel free to move this if it's not in the right place. Thanks guys.
    EDIT: After cutting all the wires and sliding the board out, it looks like the other 16v cap is bulged too. The 160v is a different brand and is fine. I assume because there was no load on it. What's kind of odd is there are no internal fuses either. Here's a pic. The other 16v cap is in the middle.
  • Th3_uN1Qu3
    Believe in
    • Jul 2010
    • 6031
    Re: power inverter cap
    Are you sure your boat doesn't use 24 volts?
    A working TV? How boring!
    • justinf89
      • Jun 2011
      • 5
      haha no it doesn't but I tried this on the car battery anyway.
      • Th3_uN1Qu3
        Believe in
        • Jul 2010
        • 6031
        Then go ahead and replace the caps then try it again. It's quite possible that the caps have lost their voltage holding capacity because they haven't been used.
        • justinf89
          • Jun 2011
          • 5
          Alright I picked up 2 panasonic caps and it took me more time to re-splice all the wires than to solder the caps in. I did find a great way to clear the holes to stick the caps through. I took a small drill bit (1/32) and drilled out the holes. It's a lot easier since I didn't have a stainless pick. Anyway, the inverter works great now! I put a dc load of 30a on it and it did fine for about 5 min so I'm pretty happy. I'm just glad the caps were the only thing wrong with it.
          • x_orange90_x
            Vizio E55-E1 bad backlights or bad inverter?
            by x_orange90_x
            I just got this tv today and it appeared to have no backlight on. After taking off the rear cover and checking again in the dark I can see that MAYBE one quadrant is lit.. But still it's quite dim. I was going to check the LEDs with my tester, and I found LED 1 and LED 2 + pins on the wire from the inverter, but I couldn't identify a ground. Nonetheless I tried using a mounting screw on the inverter board and also the chassis as ground but regardless my tester reads 300 which is what it reads when there is no voltage draw.
            I don't know how exactly to test the inverter itself. Is it...
            01-29-2025, 09:24 PM
          • Gentian
            APSINT3636VR 3600W APS INT Series 36V DC 230V AC Inverter/Charger schematic
            by Gentian
            I have a tripp-lite aspint 3636vr inverter charger which blow some of mosfet transistors. I replaced them repaired also the driver circuit and tested but the mosfets burn again.
            It work very well as inverter and also as charger if I let the rear switch in auto mode (inverter) and charger only(charging) but in auto when I connect the feed line 220V AC first time it pass ok to line and start charging the batteries but when I remove the feed line it pass to inverter mode and if I do it again the second time when passing from charging to inverter the Main transformer start making a...
            03-06-2023, 07:07 AM
          • valvashon
            Insignia NS-LCD19-09 (PS OK, Inverter problem?)
            by valvashon
            For some reason I'm just not going to let this 19" TV defeat me. I guess because I have a schematic to work from I feel like I'm oh so close.
            History- while adding a turn-on circuit I let a small screw roll under the power board. Worked through all of that circuitry, probably replacing a MOSFET and PWM controller that were not bad but I was following the service manual. Finally figured out that the power supply is in working order when the inverter section (for the backlights) is disconnected. When the +12 supply to the inverter is disconnected the +12 and +5 will come up...
            01-04-2024, 01:44 PM
          • eccerr0r
            A modified sine wave inverter + a grid tie inverter?
            by eccerr0r
            If I had a solar fed grid tie inverter (GTI), a modified sine wave inverter, and a power outage occurred, what would happen if you disconnected mains, backfed the modified sinewave inverter (MSI) into house power, and hooked up the GTI to the output of the MSI, would it work?
            Next thing is trying to charge the batteries using solar power, but that's another issue ...
            08-31-2023, 09:14 PM
          • caseyjay_48
            Sony KDL-46BX450 Inverter Troubleshoot Logic
            by caseyjay_48
            I am currently on a troubleshoot of 46” Sony KDL-46BX450 tv. I came back from Washington to Texas on medical emergency and had to leave all my tools up there. All I have is a couple of screwdrivers and a dvm. I wish to ask the community a troubleshooting question. Please forgive stupid questions as meds I am taking produce brain fog.
            I have well maintained Sony KDL-46BX450. It went black one day. After turn-on, I get solid green light and Sony logo in screen center for about 1-2 seconds, then black. No blinking LEDs, no hissing. Flashlight test shows screen characters dimly viewable,...
            09-23-2022, 08:08 PM
