Getting started with microcontrollers.
  • Th3_uN1Qu3
    Believe in
    • Jul 2010
    • 6031
    • Romania
    Fed up with my "sinewave" inverter i decided to build a better one, but i need a stable 50Hz source. Upon giving it some thought... i finally decided to go with a micro. One of my mates at uni built a LC meter for a contest, using a PIC, so that's what i'm going to use as well. So i can bother this guy with stupid questions.
    I'll be buying a Pickit 2 clone. The reason i'm not building it myself is that the Pickit itself needs to be programmed by other means before it can be used.
    A working TV? How boring!
  • mathog
    • Mar 2010
    • 2655
    Re: Getting started with microcontrollers.
    Isn't the electricity over there 50Hz? So what's wrong with using the voltage out of your wall sockets? Most large scale power systems have extremely stable frequencies. It might be a bit noisy, but you can always put a filter on it.
    • Th3_uN1Qu3
      Believe in
      • Jul 2010
      • 6031
      • Romania
      Um, why would i use an inverter to generate 230v when i have working mains? The inverter is of course to be used when power goes down.
      • mathog
        • Mar 2010
        • 2655
        So you're talking about a UPS, or is it something much bigger, enough to run the whole house/apartment on?
        For the former I'd say, just get a UPS and go with that. It doesn't have to be new. I have seen many of them thrown out when the batteries died because the cases are stamped with "no user serviceable parts". But that's usually nonsense and on opening them one finds standard lead acid batteries which are easy to replace. I suppose there may be some with one of a kind oddly shaped and oddly volted batteries, but so far, I have not run into one.
        • Th3_uN1Qu3
          Believe in
          • Jul 2010
          • 6031
          • Romania
          You got it. Blackouts haven't happened in a while (knock on wood), but brownouts that last just enough to shut down some stuff are quite frequent. I also plan to add some solar panels later on. Not necessarily as an alternative energy source, just to not use utility power to keep the batteries charged.
          • mathog
            • Mar 2010
            • 2655
            For short brownouts you might want to consider putting in a cutout circuit to protect refrigerators and other devices that are unhappy when the power isn't what it should be, but can be safely turned off for a few minutes at a time. That shouldn't be very complicated, all it needs is a voltage measurement on the mains side, a big enough relay to handle the open/close current for the device, and a tiny bit of control electronics to drive the relay. The control circuit will need a fair bit of hysteresis, so that it doesn't toggle the relay on and off quickly if the mains voltage wanders around near the cutoff.
            • Th3_uN1Qu3
              Believe in
              • Jul 2010
              • 6031
              • Romania
              Well, my fridge doesn't complain. Anyway. The Pickit 2 clone is here. It works. I managed to blink a couple LEDs. On to more interesting stuff.
              • mathog
                • Mar 2010
                • 2655
                I'm not sure I could hear the difference on my fridge even if it never got up to speed. Anyway, just stumbled on this (only the first page is free), which is a circuit that does what I was suggesting:
                http://www.siliconchip.com.au/cms/A_111036/article.html
                • Th3_uN1Qu3
                  Believe in
                  • Jul 2010
                  • 6031
                  • Romania
                  Sounds like too much hassle for something that this inverter will accomplish anyway.
                  Progress on the microcontroller side of things. I successfully used up all 6 I/O pins available on this PIC. I put four LEDs two by two, and two push buttons. The LEDs continuously transition from one another, making a spinning effect. The buttons change the speed of the spinning. PIC assembler is really easy to learn. I ran into a few snags but it's looking good so far.
                  I also found a Microchip appnote, complete with source code, which does - guess what? Software PWM generation. Unfortunately MPLAB tells me the code won't fit in this little bugger i have (a PIC12F675), so i'll have to cook my own. Shouldn't be too hard tho.
                  This chip's quite impressive - it's even got a 3-channel ADC onboard. Mmm. I smell cap torture device with LCD readout.
                  • Th3_uN1Qu3
                    Believe in
                    • Jul 2010
                    • 6031
                    • Romania
                    I'm back on it... I have switched to a larger PIC btw, a 16LF876A. More outputs, more ADC channels, a built-in PWM module... neat. That's old news though - i bought that PIC like a month ago - but i think i posted about it in another thread not in this one.
                    I've written my own LCD routine out of bits and pieces i found on the internet (since none of the ones i found actually worked by themselves), but i hadn't figured out how to deal with strings, and sending data letter by letter (and in ASCII codes at that), quickly got annoying.
                    That is, until now. Looky what i've accomplished.
                      • Jul 2011
                      • 6045
                      How do you know that ........>
                      Did you ask the fridge if it matters ....>
                      I can tell you it dose MATTER and over time your fridge will complain and may be to late for you to help it and will be DEAD
                      I am a refrigeration / air conditioning technician by trade and one of the most
                      comman problem is brown outs and the compressor try s to restart and can not this is hard the strating up parts of the fridge
                      You might want to consider putting in a cutout circuit to protect refrigerators
                      I have one these on my fridge and they do help
                      • joshnz
                        • Feb 2011
                        • 969
                        • New Zealand
                        MMMMMMM microcontrollers I started working with them last year. what got me into it was i needed a fail safe for me rc car.
                        My pc
                        CPU : AMD PHENOM II x4 @ 3.5Ghz
                        MB : ASUS M4A89TD PRO USB3
                        RAM : Kingston ValueRAM 16gb DDR3
                        PSU : Cooler Master 850W Silent Pro
                        GPU : ATI Radeon HD 6850
                        • Th3_uN1Qu3
                          Believe in
                          • Jul 2010
                          • 6031
                          • Romania
                          That's something to keep in mind, thanks. For now the brownouts never lasted long enough for the fridge to stop - yes i did happen to be in the kitchen on a few occasions - but thanks for the warning.
                          • Th3_uN1Qu3
                            Believe in
                            • Jul 2010
                            • 6031
                            • Romania
                            Alright, movin' on. Tonight i will set up a TL431 as reference for the ADC, and start getting some readings.
                            The plan is to be able to measure the ripple applied to the cap under test, in my upcoming capacitor load tester. And there will also be a couple linear regs i will need to monitor and adjust by the means of digital pots. While the PIC's ADC is certainly too slow to sample a 100kHz signal - and i have my eyes on a dedicated chip already - there is a possibility that i will be able to cheat and do by without the help of an external chip.
                            Here's why. I am not interested in "seeing" the signal, like an oscilloscope would. I know how the signal will look like, i don't care whether the PIC sees its shape or not. All i care about is the peak-to-peak value, and the signal is repetitive... and that means i can make several readings over a longer period of time and just pick the highest values.
                            I will only update the LCD display every 200ms (as it's so slow it gets blurry at 100ms refresh, and starts displaying garbage at 50ms) - and that's a crapload of time to do stuff even with that slow ADC.
