GTX480 started with distorted checkered screen now completely dead
  • learnmore
    • Mar 2022
    • 107
    • England
    Hello Community,
    I have an oldie GTX 480 that started showing a checkered screen, then finally went blank and now stops the desktop from turning on. I got a new GPU, and now everything works. I'm going to use the faulty one to learn. Any help or signposting to a good learning resource is also welcomed.
    Many thanks
    LM
  • maleksa
    Yamaha MOX8 boot freeze and distorted sound
    by maleksa
    My Yamaha MOX8 synthesizer recently developed two issues.
    Firstly, after booting up, it operates as normal. However, after about 5 minutes, the sound starts to get distorted (broken up screeching sound) almost like putting it through a guitar distortion pedal. After a while, the distorted sounds will go away for a while and comes back. At times, the synthesizer will also freeze I need to power off and on again.
    Secondly, when powering off and on again, there will be times where the synthesizer will freeze during the boot sequence (freezes at the MOX8 Opening Screen),...
    11-07-2024, 03:28 AM
  • sima112
    Marantz pm 6005 right channel not worknig
    by sima112
    Hi guys,
    I need a help with my Marantz pm6005. It started to have weaker the right channel a few months ago, than it got back to normal and now it has lost sound completely on the right channel. At the final stage it was loosing the channel for a while and than it returned. After it has disappeared completely I could forced it back by unplugging the source form CD (which I normally use) to phone and back. It would then work for a few minutes and died again. Now it is possible power up and all function works normally (apart the right channel ) on all inputs, except the phone both channel...
    01-30-2023, 12:11 PM
  • cappernicus
    Satellite r945-p440 - Hard crash coming out of sleep
    by cappernicus
    Toshiba Satellite r945-p440
    Motherboard: FAM2SY2 A3256A
    I do not have a schematic or board file
    I usually let it go to sleep every time I use it because it is nearly always plugged in, with occasional shutdowns to reset things. Then it started to hard crash every time it tried to come out of sleep. The lights would come on for half a second but before anything shows on the screen they would all shut off and it would boot up as if I had shut it down completely (except that windows knows it didn't), and when it comes back on the fan ramps up to full and stays there perpetually...
    04-16-2025, 05:31 PM
  • LEECH666
    Grundig Vision 9 37 9880 T USB (Chassis SR) TV Repair Help - Distorted Subwoofer Sound and overall weird sound waveforms
    by LEECH666
    Good day ladies and gentleman!
    I am currently trying to repair a Grundig Vision 9 37 9880 T USB LCD TV for a friend that has a weird audio problem. Basically everything works fine except for the heavily distorted sound when the Subwoofer module is connected and there is a buzzing sound coming from the PSU PCB.
    This seems to be a rather rare TV so there is not much prior on topic help to be found however a service manual is available at the usual sources (Electro Tanya i.e.).
    I think the PSU buzzing comes from one of the coils near the bridge rectifier but...
    01-19-2024, 05:46 PM
  • Neddsme
    Bios partially corrupted somehow and now warm boot doesn't work which is critical
    by Neddsme
    Hie.
    I own a Lenovo ideapad v310-15IKB with an i5 7th generation with only Intel graphics configuration.
    Now the heart of the problem is that I don't know when or how it happened but I suddenly started getting distortion in the graphics output on the LCD. This basically meant a black screen full of flickering multicolored short horizontal lines. This would happen 30-60 minutes after booting and using it normally.
    I run Windows 10 20H build so I thought it was just a Windows update issue or graphics driver outdated issue.
    I managed to run Windows troubleshooting and...
    02-04-2022, 05:57 AM
