bad coil
  • skystormfarms
    Banned
    • Mar 2011
    • 160
    bad coil
    the spark coil on my a.t.v just went up in smoak help the coil is brand new
  • seanc
    • Nov 2008
    • 1319
    Re: bad coil
    Replace it?
    A little context would be helpful.
    What happened before it was 'brand new'?
    • alexanna
      • Mar 2010
      • 1346
      Re: bad coil
      Is this a magneto ignition?
      • skystormfarms
        Banned
        • Mar 2011
        • 160
        Re: bad coil
        New spark plugs were put in one of the 2 new plugs one had a bent spark point that shorted out and that coil went wen i puld one of the spark plug it was the one then new coil and smoak
        • chth96
          How can I test coil whether it is really broken or not?
          by chth96
          I have old game console which have connected to 220v outlet by previous owner and It is not able to turn on.
          I checked continuity of fuse in PSU unit with a multimeter which is shown in the below picture with a orange circle around it, and It seems that fuse became open circuit.
          I also found that as well as bulging capacitor, there is unidentified coil which has residue all over its surface
          I want to replace this round black fuse and unidentified coil if it got broken.
          02-20-2024, 01:07 AM
        • waterchill
          What part is this coil from a MacBook A2681 ?
          by waterchill
          Hi everyone
          I'm struggling to point out what part is this? It is a coil, but the parameters say: 10OHM - 50% - 1A - 0.05Ohm
          So it is a coil with 0201 dimensions, 1A max current, 0.05ohm resistance but what is 10ohm? For a coil we need specs like 1uH or so.
          IAny ideas? It is from a MacBook A2681
          Thank you...
          08-08-2024, 01:46 AM
        • chth96
          How Can I identify IFT coil?
          by chth96
          I have a CD unit which is came from saturn game console.
          It always perceived Any retail CD or CD-R as Audio-CD.
          Of course I changed laser head and adjust pot of laser head nearby, but It always failed to perceive as saturn game CD.
          I think that this problem probably begins When I tighten IFT coil too hard with small screw driver and suddenly I heard some kind of snap or cracking sound
          I desoldered this IFT coil and It is 7pin IFT coil and written "4120 009 62VK" on the surface.
          Is there any way to identify its frequency in order...
          11-11-2022, 05:31 AM
        • lerom
          PowerEdge R740 coil resistance
          by lerom
          can anyone measure the resistance on coil L12 3.3V (near USB, EMMC chip) and coil L46 1V near CPU1 ?
          thanks....
          03-23-2025, 02:21 AM
        • Axis937
          Accidental slip of the hand caused a spark on Capacitor. Is my PANEL killed in action?
          by Axis937
          Hi folks, newbie here. My intention on a working monitor was to test for voltages on the various pins. Somewhere near the ribbon to the monitor, there we 2 caps. One was reading around 5V and the other was maybe about 12 or 14V . Cant really recall. Then it happened. The multimeter kissed the 5v cap and the other cap. Spark appeared. NOW... the part where the spark happened ( Caps near the Last ribbon cable ) is now totally white. 1/6 part of the screen is white. From my little understanding , i came to learn that there are transistors inside the TFT panel. Could that be a issue then? I have removed...
          11-10-2024, 06:50 AM
