DC power jack marginal?
  • Agent24
    I see dead caps
    • Oct 2007
    • 4953
    • New Zealand
    I have recently finished adding A/V out connections to two Sega Master System 2 consoles.
    The SMS2 uses the Sony CXA1145P IC which provides a Mono audio output, and Composite, S-Video and RGB video outputs.
    The only thing lacking is the wiring and a couple of components, which are easy to add (see: http://knol.google.com/k/konsole-kra...gsu6gmugnec/3#)
    My modification is essentially the same, except it looks much better and uses shielded wire for the signal wires.
    Now, everything works fine, the magic smoke is still inside, I don't doubt the modification itself as many people have done it.... BUT with some positions of the DC power plug, I get buzzing in the audio.
    If I slowly turn the plug around in the jack, at some points, I can make the buzzing go away, in some places, power interruption, and the console resets.
    I get the impression that the jack is worn, there is a bad connection, possibly mild arcing causing the buzzing? Maybe they need cleaning?
    Is this a known issue with old power jacks (remember these console were made in 1990) or could it be something else?
    -David VanHorn
  • PCBONEZ
    Grumpy Old Fart
    • Aug 2005
    • 10661
    Re: DC power jack marginal?
    I'm going with bad connection, worn.
    Mann-Made Global Warming.
    - Dr Seuss
    • Krankshaft
      • Jan 2007
      • 2328
      Bad DC barrel connector try hitting it with some contact cleaner and see if it's just oxidation and dirt. If not and it's the spring steel contacts replace the jack.
      Hopefully it's a standard connector and not one of those proprietary ones like on the Super NES. I love how the voltage inputs were similar but Nintendo put a proprietary plug on their console.
      Both consoles SNES and Sega Genesis had an internal linear voltage regulator for the logic ICs so any adapter 9 to 12 volts would work.
      • Agent24
        I see dead caps
        • Oct 2007
        • 4953
        • New Zealand
        Yeah it's a standard connector, the console requirement says 9v DC @ 500mA but with center negative, just to be different to most things.
        Don't have any 'proper' contact cleaner that I know of, is there anything else that would work?
        The SMS2 has a 5v Regulator, however there's some circuitry before it, didn't pay too much attention but I'd be a bit wary about giving it a higher voltage, at least until I inspected it to see what it is.
        -David VanHorn
        • Th3_uN1Qu3
          Believe in
          • Jul 2010
          • 6031
          • Romania
          I wish my SMS2 still worked. I bought it a few years ago solely for Streets of Rage... i really liked the moves in that game. It mostly sat unused and when i wanted to play it again it just displayed a green screen. Probably the EEPROM got shot.
          A working TV? How boring!
          • Agent24
            I see dead caps
            • Oct 2007
            • 4953
            • New Zealand
            I don't know too much about them to know what sort of faults they get, if the EEPROM you're speaking of is a standard one I could probably read mine and send you a copy if that would help.
            -David VanHorn
            • Th3_uN1Qu3
              Believe in
              • Jul 2010
              • 6031
              • Romania
              Yes the EEPROM is a standard format (i believe it's 32-pin DIP like those old BIOS chips), but i don't have a burner unfortunately, and the SMS2 was one of those things i didn't use too often anyway.
              • Scenic
                o.O
                • Sep 2007
                • 2642
                if it's a standard eeprom you might be able to flash it in a computer motherboard using uniflash or something..
                • Th3_uN1Qu3
                  Believe in
                  • Jul 2010
                  • 6031
                  • Romania
                  Good idea. I'll take a look the next few days.
                  • Agent24
                    I see dead caps
                    • Oct 2007
                    • 4953
                    • New Zealand
                    I've taken some photos of mine, and it looks like my BIOS chip is a MPR-12808
                    MPR series according to the Internet means that it's a mask-ROM
                    (See: http://www.smspower.org/Development/ROMPartNumbers)
                    On the good side I can't see it would be able to get corrupted or anything, But of course on the bad side, you can't reprogram it to find out either...
                    BIOSes appear to be available here: http://www.smspower.org/Development/BIOSes
                    I guess if you can find an EEPROM with suitable pinout you could give those a try or something, but it may not be the BIOS ROM which is causing your problems, might be something like a bad voltage regulator causing the CPU to lockup, who knows...
                    -David VanHorn
                    • Th3_uN1Qu3
                      Believe in
                      • Jul 2010
                      • 6031
                      • Romania
                      For all i can remember it just powered up to this green screen when i tried to use it after it's been stored for an year or so. Could even be bad caps...
                      • Agent24
                        I see dead caps
                        • Oct 2007
                        • 4953
                        • New Zealand
                        Could be, though considering everything is powered with a single 7805 I don't see much going wrong in the power supply department..maybe if something went totally open or shorted...
                        All the electrolytic capacitors in mine appear to be Elna RE2 series (General purpose 85 degrees)
                        On-topic - I took a closer look at my DC jack with a magnifying glass and torch, the spring contact doesn't look too good, I see what could be rust, or carbon deposits.. (quite hard to see well actually)
                        I think I'll replace the jack tomorrow and see what happens.
                        -David VanHorn
                        • Agent24
                          I see dead caps
                          • Oct 2007
                          • 4953
                          • New Zealand
                          Well this is interesting, I now have a completely different theory about this problem!
                          Replacing the jack solved nothing, in fact if anything the problem was made worse ('what!' I hear you say?)
                          At this point I should probably admit that I am not using the official Sega power adaptor (yeah I know, I probably should have said this in the beginning, and I should know better...)
                          As it turned out that may be the key to the whole mystery....
                          The Sega itself has on its label "9v DC @ 500mA" - now my multi-voltage dual-polarity adaptor just happens to be 500mA and has a 9v setting.
                          HOWEVER - the official Sega power adaptor is actually rated for 850mA, a whole 350mA higher than the current drawn by the Sega (assuming that's what the label means). I was not given the official adaptor at the time as the wire near the plug is broken, but since it's twice the size of mine I have theory number 2:
                          The official power brick is rated higher than needed, runs only at 58% of capacity and possibly has better filtering, maybe even a regulator on board.... While my own adaptor would have been running at 100%, isn't regulated and probably has a horrible Fuhjyyu or something for a filter capacitor, knowing my luck.
                          So my theory now is that my adaptor was supplying a high ripple, otherwise noisy power to the device and causing problems. The brand new jack only allowed this noise to come though even better!
                          So, after picking up the proper adaptor this afternoon I will be getting a new plug for it tomorrow and seeing how that goes....
                          -David VanHorn
                          • Agent24
                            I see dead caps
                            • Oct 2007
                            • 4953
                            • New Zealand
                            So the conclusion to this dramatic and exciting story... haha
                            Official power adaptor works great after wiring a new plug on it, notice it's ouputting about 12.8v DC no load so I expect not regulated.
                            Either way, it works perfectly, no buzzing on the audio, both with the new and the old DC jack.
                            (I decided to put the old jack back and leave it there, after testing resistance it was flawless, I guess my eyes deceived me, it's not rusty or problematic at all, and I'd rather have a brand new jack for something else)
                            Sadly I can't really confirm my high ripple current theory as I still don't have an oscilloscope.... but the thing works now so that's what really matters
                            -David VanHorn
                            • valvashon
                              Samsung UN55FH6030CXZA main board USB jack indentification
                              by valvashon
                              Samsung UN55FH6030CXZA main board, BN41-01894, bad USB jack. Jack is mangled and needs replacing with like. Jack is marked "Simula" with the number 130318. Search for Simula turns up a weak looking website of a company that seems/seemed to supply USB jacks and other USB technology but no current items turn up for sale.
                              I should be able to research and find something applicable through a Digi-Key search after I unsolder/cut out this one and measure the mounting/pin connection pattern on the board but I thought I'd ask here to see if anybody knows of an exact make/model...
                              01-23-2025, 11:17 AM
                            • Petr0x
                              Bosch 12V and 18V chargers modification
                              by Petr0x
                              Hi, I would like to share with you small modification to your Bosch tool 12V and 18V chargers.
                              You can use it for almost all Bosch chargers what I have seen, for example part numbers GAL 18V-20, GAL 18V-40, GAL 1880, GAL 18V-160, AL 1820, AL1115CV, AL1130CV.
                              Bosch (today also other brands using the same system like Wurth, Fein) does not care if you destroy your batteries, because they can sell you new ones. So the marketing is telling you only about speed of the charging, so you will not wait for your batteries to charge too long. Me as a customer want the tools and batteries...
                              05-24-2024, 01:00 PM
                            • gabri2211
                              Xbox Series X Console Won't Turn On - Broken Nexus Connector on Mainboard
                              by gabri2211
                              Inside the console there is a small circuit board (see photo) that contains the main power switch, the one on the front.
                              This circuit board connects to a 10-pin flat cable called NEXUS that terminates on the motherboard.
                              This NEXUS connector broke.
                              Can anyone tell me, while waiting for a replacement, if it's possible to turn on the Xbox by disconnecting this circuit board and making some modifications (like adding a small power button) on the motherboard?
                              The Xbox has a power supply that provides 12 volts on all outputs, so the power...
                              07-28-2025, 07:13 PM
                            • dcbw
                              PowerMac G5 ACBel 614-0303 buzzing
                              by dcbw
                              The PSU works, but shortly after powering on (either in the G5, or by shorting the power-on pin to ground) it begins buzzing loudly. It also makes the LED lights connected to the same circuit flicker. It's definitely a buzzing, not a high pitched whine.
                              The buzzing seems to come from the high voltage side of the board, perhaps from the white relay. Could the relay be bad, or could the 5V supply be bad enough that it's unable to keep the relay on? Any pointers to help isolate the issue? Thanks!
                              Other info: API2FS34, ID 291, Date B0404
                              05-31-2024, 07:13 AM
                            • diamon
                              Dell 5590 LA-F412P does charge with USB-C not with DC-Jack
                              by diamon
                              As mentioned, I have a Dell 5590 laptop with motherboard LA-F412P.
                              This laptop works with the USB-C charger and not with DC-Jack charger.
                              With the USB-C charger attached, the battery is charging and in the BIOS the charger is also recognized.
                              With the DC-Jack charger attached (USB-C charger removed), the light of the charger is not going off and the BIOS does not see the charger (message AC Adapter = Not installed). I'm using original Dell chargers and I have tested the used chargers on other Dell laptops and they are working correctly.
                              I have replaced the DC-Jack,...
                              12-29-2023, 07:29 AM
