12VDC to 5V USB port.
  • Colt45ws
    • Jan 2009
    • 174
    I was on a sudden and unexpected trip out of town the other day, and realized my phone was running low on charge. I went to the local WalMart and grabbed a cigarette lighter to dual USB adapter. Then I found a 140W inverter with a usb port for a couple bucks more so I grabbed that. Well, the inverter runs all the time. Huge parasitic draw for just a USB port.
    I pulled it apart and traced it out, the 5V is coming off its own board and is just taking 12V from the board. The only thing that is being done is a pair of 16V 2200uf on the feed.
    Could I take just the board and hard wire it up to my switched aux line I have in my car? Should I add a capacitor on the input, maybe a 470uf? I have a couple Chemi-con KMG 470uf 16v. Those twin 2200s are shared with the inverter section, so I dont think I need quite that much.
  • Krankshaft
    • Jan 2007
    • 2328
    Re: 12VDC to 5V USB port.
    Why not just buy a charger for your phone that plugs into the cigarette lighter?
    The USB section is just a 5 volt voltage regulator with a filter cap connected afterward. That is why they're so dirt cheap. This modification sounds very convoluted for what you're trying to accomplish.
    To answer your question it won't hurt to have an input filter cap. 16 volt rated filter caps are a bit too close for comfort the alternator can put out around 14-15 volts when the engine is running. I would go up to the next standard voltage 25 volts.
    • Colt45ws
      • Jan 2009
      • 174
      Well, I would like to make it look like it is supposed to be there in the dash. Plus I would like to put it on my aux keyed acc/on line I already have run behind the dash for stuff like this.
      • kaboom
        "Oh, Grouchy!"
        • Jan 2011
        • 2507
        A '140' watt inverter from whalemart is gonna need some help, the least of which will be a cap job.
        https://www.badcaps.net/forum/showthread.php?t=13201
        Try one of those USB backplates that's made to fit a rear expansion slot. Cut it to fit, paint it gray or black, mount it in the dash and be lookin sharp. A little 7805 ckt is perfect.
        -Paul
        "pokemon go... to hell!"
        EOL it...
        All style and no substance.
        guilty,guilty,guilty,guilty!
        guilty of being cheap-made!
        • fredyjbi
          please help, friend, thinkpad L480 NM-B461 rev 1.0 JDOCK1 type C port 5volt only, thank you
          by fredyjbi
          I have a thinkpad L480 NM-B461 rev 1.0 laptop functioning normally with Type 1 port (JUSBC1)
          if you use port type C 2 (JDOCK1) with a usb type meter it only displays 5v, thank you
          I tried to look at the schematic diagram USBC_VBUS20, which is the port path from JusBC 1 to U4701 then goes to the system2 charging IC, why is there no system2 path leading to the charging IC on the TYPEC_VBUS20 port which is JDOCK1, thank you for your help.
          if you look at the power sequence there must be 2 types of port type C a (JUSBC1) via U4701 and port type C b (JDOCK1)
          On the type...
          07-09-2024, 11:28 PM
        • x_orange90_x
          Vizio E55-E1 bad backlights or bad inverter?
          by x_orange90_x
          I just got this tv today and it appeared to have no backlight on. After taking off the rear cover and checking again in the dark I can see that MAYBE one quadrant is lit.. But still it's quite dim. I was going to check the LEDs with my tester, and I found LED 1 and LED 2 + pins on the wire from the inverter, but I couldn't identify a ground. Nonetheless I tried using a mounting screw on the inverter board and also the chassis as ground but regardless my tester reads 300 which is what it reads when there is no voltage draw.
          I don't know how exactly to test the inverter itself. Is it...
          01-29-2025, 09:24 PM
        • Scarfycake
          ASUS proart Studiobook h7600ZW; Had DC in port replaced and all the sudden it isn't charging but is the charging sign is on!
          by Scarfycake
          I sent my ProArt Studiobook 16 OLED (H7600, 12th Gen Intel) to the local repair guys to have a very simple DC in port replaced. I sourced the part myself on accessoires-asus (french company) after struggling to find the right part in the UK. It looked completely the same to the installed part from what I can tell. Originally the only issue with the laptop was a bad / loose DC connection, and so the computer and battery acted completely normal aside from a very poor connection that would fail at certain angles. After the repair was completed I brought it home and used it for...
          05-21-2024, 08:16 AM
        • rounin
          MacBook Air A2337 (820-02016) USB-C Port Issue – Only Works in One Orientation (CC Line Problem?)
          by rounin
          I'm working on a MacBook Air 2020 (A2337, board 820-02016) and running into a strange USB-C issue. I've gone through quite a bit of testing and part replacement, but I'm stuck — hoping someone here can shed some light.
          🛠 Original Issue
          The machine initially wouldn't negotiate 20V over USB-C — stuck at 5V.
          ⚠️ New Problem: One USB-C Port Only Works in One Orientation...
          04-19-2025, 01:18 AM
        • eliemgh
          Dell Latitude 7410. The USB Type-C port is not working
          by eliemgh
          I have a Dell Latitude 7410 with an Intel i7 10th Gen CPU. The USB Type-C port is not working, and since it's the only charging port on the device, I'm unable to charge the laptop.
          I inspected the motherboard and found that the IC labeled TPS65988 had a short circuit. I ordered a replacement IC from Alibaba and replaced it. The short issue is now resolved, but the laptop still doesn't charge, and the Type-C port remains non-functional.
          After doing some research, I found out that the TPS65988 needs to be programmed after replacement in order to function properly.
          04-14-2025, 04:20 AM
