Take That, Fuhjyyu!
  • kaboom
    "Oh, Grouchy!"
    • Jan 2011
    • 2507
    Take That, Fuhjyyu!
    Maybe not for a computer, but still a power supply
    12 volt to 120v power inverter heavy-up I did last year.
    Cleaned up wiring, lower Rds MOSFETS, 3a fast recovery rectifiers for boosted DC bus, copper wire to parallel traces, upsized input leads from 16 to 12awg. Paralleled a resistor across current sense shunt on the high voltage side, to allow for the originally designed 150 watt continuous output.
    Also got rid of the damn fuhkyoos
    With the original parts, DC bus was around 162v without a load. Under a 140w load, it dropped to 156. Now I have 165v with or without a 150w load, and the unit runs MUCH cooler. It's now capable of 225 watts out, but only for brief periods- obviously the transformer won't take that continuously. The load in the pic is a 150w bulb and a small shaded pole fan.
    As the bus voltage is 165, it should really be considered a ~117v inverter.
    -Paul
    "pokemon go... to hell!"
    EOL it...
    All style and no substance.
    guilty,guilty,guilty,guilty!
    guilty of being cheap-made!
  • TheLaw
    • Jan 2011
    • 477
    Re: Take That, Fuhjyyu!
    Nice!
    • japlytic
      • Oct 2005
      • 2086
      What is the series of the 200V Nichicon capacitor?
      • kaboom
        "Oh, Grouchy!"
        • Jan 2011
        • 2507
        CS- we've got high frequency coming in from the diodes and low frequency 'pulses' going to the stepped square wave 'modified sine' output.
        EOL it...
        • AJ847.63e
          Testing ATX PSUs under load - Does loading the ATX 24 pin also load EPS & PCIE?
          by AJ847.63e
          Hi Folks,
          Just wanted to clear up a misunderstanding of mine (or what I expect is one). Isn't the 12V rail from the 24 pin, EPS and PCIE separated? IE if I put a power resistor on the ATX 12V pin that is not going to load, thus tell me if the EPS or PCIE rails are fine?
          I was recently watching ArIs from Hardware Busters video on how to properly test ATX PSUs without using 5 figure Croma substations.
          The PCB adapter he used breaks out the 12, 5 and 3.3V pins from the 24 pin and gives you banana plugs to connect to. That is a bit useless is it not? Aren't...
          05-06-2025, 10:37 PM
          HP Elite Slice G2 + Image Load & Asset Tag Elite Slice i5-7500T Specification for Upgrade or Repair
          This specification for the HP Elite Slice G2 + Image Load & Asset Tag can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the Elite Slice G2 + Image Load & Asset Tag boardview and Elite Slice G2 + Image Load & Asset Tag schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please...
          09-12-2024, 02:20 PM
          HP ProBook 430 G6 + Image Load & Asset Tag Notebook 400 Specification for Upgrade or Repair
          This specification for the HP ProBook 430 G6 + Image Load & Asset Tag Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the 430 G6 + Image Load & Asset Tag boardview and 430 G6 + Image Load & Asset Tag schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we...
          09-06-2024, 10:56 AM
          HP ProBook 450 G6 + Image Load, Asset Tag & Testntag Notebook 400 Specification for Upgrade or Repair
          This specification for the HP ProBook 450 G6 + Image Load, Asset Tag & Testntag Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the 450 G6 + Image Load, Asset Tag & Testntag boardview and 450 G6 + Image Load, Asset Tag & Testntag schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps...
