TEA1532CT GreenChip II SMPS control IC Replacement
  • stevekasian
    Old N00b
    • 182
    • USA - West Side!
    I am desperately looking for a replacement for a discontinued NXP Semiconductor GreenChip II SMPS control IC, part number TEA1532CT.
    I have been scouring the internet for about 3 hours and have come up with nothing.
    I have a 715T2463-2 Power Board that blew a MOSFET, 2 .1 ohm resistors and other components. I've found that this happens with these boards quite often, and that after replacing the 3 parts mentioned above, it is often times still inoperative. This is exactly my experience as well. So I am on the hunt for each of the parts others have had to replace in this situation, the TEA1532CT being one of those components.
    If anybody with any information on this would please reply I would GREATLY appreciate it. Even if you have some technical knowledge that could help me search out a suitable replacement, I would be very grateful!!
    Thanks,
    SK
  • Scenic
    o.O
    • Sep 2007
    • 2642
    Re: TEA1532CT GreenChip II SMPS control IC Replacement
    from what i found out after a quick google search, only the TEA1532BT is discontinued.
    http://www.nxp.com/pip/TEA1532BT_TEA1532CT.html
    you might wanna try ordering samples from NXP..(!?)
    • Wizard
      • Mar 2008
      • 2296
      What is this power supply used in?
      Cheers, Wizard
      • jetadm123
        • 2169
        digikey.com lists a TEA1532T in stock. Not sure what the difference is:
        http://search.digikey.com/scripts/Dk...=568-3316-1-ND
        Also, if you search in ebay under TEA1532, you'll get several hits.
        • stevekasian
          Old N00b
          • 182
          • USA - West Side!
          Thanks!
          Scenic: Good call, I'll try that. Any suggestions as to what the best way to go about "ording samples" is? As in, what to tell them to get them to send me "samples" without thinking I'm just trying to repair a power board? lol
          jetadm123: There's a B and a C type:
          TEA1532CT: general purpose input for latched or safe restart protection and timing, e.g. to be used for OverVoltage Protection (OVP), output short-circuit protection or system OTP)
          TEA1532BT: general purpose input for latched protection and timing, e.g. to be used for OVP, output short-circuit protection or system OTP)
          So the C allows for safe restart protection & timing, whilst the B does not.
          Both C & B have a programmable switching Frequency Range of 100 ~ 150kHz (NXP's datasheet says ~ 128kHz), whilst the others are fixed at 63kHz.
          I don't know how important that is in this particular application, so if anyone here does I would appreciate any education on the matter! :-)
          Also, Digi-key lists them under different categories:
          TEA1532BT: "PMIC - AC DC Converters, Offline Switchers"
          TEA1532T/TEA1532AT/TEA1532AP: "PMIC - PFC (Power Factor Correction)"
          The TEA1532C* isn't even listed under either of those categories. Strange. I'm so confused by all of this.
          Wizard: It is used in a Dynex DX-LCD32 TV (Model 715T2463-2 Power Board).
          • Wizard
            • Mar 2008
            • 2296
            This is SMPS controller IC that controls the power MOSFET.
            Take MOSFET transistor out of circuit, use your bench power supply to juice ground and V+ supply on the IC (as specified by datasheet), Do IC output waveforms at all with scope? It may be very short burst, just watch the scope while turning bench power supply on and off.
            IC rarely fail, usually the components that go into latchup or shorted diode that limit swing to the MOSFET gate.
            Cheers, Wizard
            • stevekasian
              Old N00b
              • 182
              • USA - West Side!
              Aaah bummer. I knew I was eventually gonna get into levels of tech where I'd need a scope (and need to know how to use one as well!)
              All I have is a multimeter. Is there anything you can recommend in my situation, short of "go get a scope!" ??
              Others have reported that this IC went when the exact same components burned - the MOSFET and two .1 ohm resistors. They report a small transistor going as well. Seems to be a common failure on this board for whatever reason. Bad design perhaps.
              Thanks.
              SK
              • Th3_uN1Qu3
                Believe in
                • Jul 2010
                • 6031
                • Romania
                Nope.
                A working TV? How boring!
                • PowerAmpFreak
                  • 982
                  • Sweden
                  Thanks.
                  SK
                  It's common stuff the SMPS controller IC gets banged when the switch goes shorted. When we design flyback's we try to limit damage in failures like this, but it costs and it's not fully guaranteed. This is how electronic design works nowadays. Without a scope you're left with your multimeter, you could eventually hook up your mm to the IC output and measure duty cycle. That's a sign of life. if you're brave enough you could replace the obviously blown stuff and cross your fingers while you apply mains power.
                  • stevekasian
                    Old N00b
                    • 182
                    • USA - West Side!
                    Thanks for your input! I did replace all shorted/burnt/open items in the circuit already. Still no voltage on the 24v rail.
                    I'm finally able to take some HQ picts again, so I posted a thread over at the TV Troubleshooting forum to run through this thing once and for all, from top to bottom. (HERE: https://www.badcaps.net/forum/showthread.php?t=13337)
                    Thanks again!
                    SK
                    • BlkSmth
                      • May 2010
                      • 89
                      I got one of these boards also. The part number is the same but the version is "-4" looks Identical. Which parts did you replace? This one has no 24v either.
                      • stevekasian
                        Old N00b
                        • 182
                        • USA - West Side!
                        Hi BlkSmth,
                        Just saw your post in here. I had forgotten I even started this thread! It's been like 7 months since I was working on that board.
                        You have since posted in the thread I linked to above (again, here: https://www.badcaps.net/forum/showthread.php?t=13337 ) that you were hoping to solve the problem by replacing all the same components I did plus the IC referenced in this thread, just as the user "fleetwise" was able to.
                        This also made me newly aware of the fact that the "C" version of the IC is finally available thru Digi-Key! :-D That is AWESOME!!
                        So if anyone has come upon this thread and is having problems with this power board, take the link above and you will see a complete start to finish play-by-play of a successful repair job on this board. (Hopefully 2 of them - I'm now waiting for my IC to arrive and will know soon enough if it fixes the issue! And if BlkSmth posts an update there reporting that it fixed his issue as well, that'll make 3 of us! :-)
                        • japlytic
                          • Oct 2005
                          • 2086
                          I've seen a few power supplies with a TEA1532 which have the Drain (Pin 8) connected to the HV winding on the transformer, with nothing connected to the Driver (Pin 7) output.
                          In such a supply, no external MOSFET is used.
                          • rewease
                            Replacement for the Siemens Bakelite caps in an early 1980s SMPS
                            by rewease
                            There actually was a time when early SMPS and late bakelite housed electrolytic caps coexisted in high end industrial gear. A friend of mine just got himself a CNC milling machine form that time with its first set of now 41 year old caps still installed in the PSU... and it's malfunctioning.
                            Two of the caps have already leaked slightly onto the board. I have not desoldered or measured any so far but they should qualify for replacement.
                            Now I'm wondering what to put in there as a replacement. First idea was state of the art low-ESR Nippon KY,...
                            09-17-2023, 12:53 AM
                          • redoxy
                            Control Board Replacement for 2K display
                            by redoxy
                            I am looking at the option of replacing my control/driver board to one with HDMI and/or Display port input on a 2K LED (I think IPS) screen.
                            The display is Samsung LTM270DL07.
                            I have tried using the model number to search for a compatible control/driver board but so far my efforts have been futile.
                            I am looking for inputs on what board could potentially be used for my display.
                            Attached are pictures of the display label information and connectors (CON30 CON40 only) and pictures of the current control board.
                            Also attached is a technical...
                            03-14-2023, 08:52 PM
                            TL494 PWM Controller Module Booard to control a SMPS switching power supply are they available for this purpose
                            by sam_sam_sam
                            I have seen some board on eBay and Aliexpress but I have not seen any for SMPS switching power board modules I would like to build one if I can not find one that is already made
                            Dose anymore known if there is such a module and where would I find some
                            While searching this topic on google I found this
                            https://www.badcaps.net/forum/troubl...anything/page3
                            I have read through this I have some switching...
                            09-16-2024, 05:39 AM
                          • rwkish
                            Discontinued Capacitor looking for Replacement
                            by rwkish
                            Capacitor has been discontinued (EGXF101ELL331MM20S) all of the replacements I have found have are smaller than 0.709" Dia (18.00mm). I would like to use the same size or at least close to the same size Capacitor. 19mm would be too big as they would touch and not be able to through hole mount. Tia...
                            08-18-2024, 06:54 PM
                          • redwire
                            Onkyo TX-SR607 replacement volume control encoder
                            by redwire
                            I had an Onkyo SR607 with a volume control encoder not working, turning the knob up the volume number would move around crazy and not work reliably.
                            Took it out and apart and no, it's not oxide or cleaning, lube required etc.- the metal is simply worn out. It's a 30mm part with metal bushing.
                            Volume control encoder Onkyo P/N 25065655W, Alps EC12E2425 is some oddball variant I could not find. I did the dig and tried replacement part Alps EC12E2420803 and it works/fits just like the original. Mouser 688-EC12E2420803 for $3.00
                            09-09-2022, 08:59 PM
