Suggestions on soldering station etc.
  • junktv
    • Nov 2010
    • 3065
    I've been soldering more than normal and my cheap popular mechanics that i have been using for the past 15 years or so has been great to me but i'm getting over having to mess with the tip when it gets more use. I was wondering what you all use and suggest? I'm not really wanting to spend over $100 but want something that will last for years and will be able to get parts for. Here are a couple i have been looking at.
    Seem to be recomended alot.
    http://www.testequipmentdepot.com/we...lder/wes51.htm
    http://www.tequipment.net/Hakko936-1...?Source=Google
    Cheaper and digital.
    http://www.testequipmentdepot.com/el...ions/sl30a.htm
    Maybe same as above
    http://www.mpja.com/productsdirect.a...item4=15141+TL
  • shovenose
    Send Doge Memes
    • Aug 2010
    • 6575
    Re: Suggestions on soldering station etc.
    the hakko 936 gets good recommendations (i dont have it tho), (but thats what i will get when finances allow)...
      • 31278
      Originally posted by junktv
      that's a good base but the irons dont last - but it should cost about half that price!
      it's discontinued btw, not made for atleast 2 years - they are lcd now - not led.
      • junktv
        • Nov 2010
        • 3065
        So looks like weller or hakko then. Any others or know of cheaper places to get a digital read out? Goot?
        • PCBONEZ
          Grumpy Old Fart
          • Aug 2005
          • 10661
          We just went around with that one few weeks ago.
          https://www.badcaps.net/forum/showthread.php?t=11489
          Lots of good advice buried in there.
          Just FYI:
          A Hakko 926 is electrically the same as a 936 but with a different PCB layout and plastics on the base.
          All the external parts interchange.
          Used bases are sometimes cheap on eBay.
          Then you can get replacement handles and tips from here:
          http://www.vendio.com/stores/cantonm...chString=hakko
          [Have bought from him. They are legit Hakko parts..]
          There are also these guys that sell three brands of Hakko knock-offs that do pretty well.
          http://www.circuitspecialists.com/level.itml/icOid/9258
          Mann-Made Global Warming.
          - Dr Seuss
          • romansroad
            • 123
            I bougth my Hakko 936 at Fry's fro around $60.....well worth it!
              by sam_sam_sam
              07-01-2024, 06:34 AM
            • chth96
              What soldering station should I purchase for 900M-TJ-I tip?
              by chth96
              hello.
              A few months ago,I have purchased 0.1mm Soldering Iron Tip of below aliexpress link,But I noticed that It is totally impossible to use this 0.1mm iron tip in the T12 soldering station
              https://ko.aliexpress.com/item/4001275635593.html
              Is there any good soldering station which is possible to use 900M-TJ-I tip and have inexpensive or reasonable price in aliexpress?
              Any reply would be appreciated.
              11-24-2023, 05:08 PM
            • caprider
              Recommendations of quality soldering station and (separate) hot air station
              by caprider
              Hey,
              I'm looking for some recommendations of a decent quality soldering station and a separate hot air station. I'm just a hobbyist, so even if (ultra)premium tools are not required, I still want some good tools. They should be available in Europe.
              I now have a TS100 and some soldering irons and looking for some better tools.
              1. Soldering station, budget around 200-240€
              JBC BT-2BWA seems to be a good product in the budget.
              2. Hot air station, budget around 200€
              Up to now I've found ATTEN ST-862D to be a good option....
              01-15-2022, 02:05 AM
            • mkbehbeh
              KSGER C245 Soldering station PSU 220V only?
              by mkbehbeh
              I purchased this soldering station when it was on sale at amazon. It had a slew of one star reviews, but the price was low enough that even if the controller and PSU were toast, the handle tips and stand were worth more than the price. All of the reviews mentioned that the unit was either DOA, or died on the first use. I looked on Aliexpress and the first clue was that KSGER still sold the 220V version of this station, but all of the 110V versions had been discontinued. I figured That there was a problem with the 110V on the power suppply and the controller would be fine.
              I am...
              04-17-2023, 03:11 PM
            • Peter_1402
              Yihua 992DA+ Hot air gun and soldering rework station, burnt mark
              by Peter_1402
              Hi Everyone,
              I bought a Yihua 992DA+ hot air gun and soldering iron unit from a used market.
              1. Soldering iron works great
              2. There is a burnt mark on the hot air gun handle.
              I am a bit concern by the look of the melted plastic. I opened the hot air gun handle and took some readings with a multimeter.
              Heating element ~ 75ohm. (Similar reading taken from a spare heating element that came with the unit.)
              Thermocouple ~ 1.5ohm. (Similar reading from the spare heating element.)
              Reed switch tested ok with a magnet.
              From the above test, I can conclude...
              07-12-2025, 11:50 AM
