time to ditch my $20 25w iron and get sumpin' REAL!!!
  • shovenose
    Send Doge Memes
    • Aug 2010
    • 6575
    so i need a couple suggestions for a good soldering station (primarily for recap work on power suppies ut other stuff too)!!!
    budget: $50-80
  • Krankshaft
    • Jan 2007
    • 2328
    Re: time to ditch my $20 25w iron and get sumpin' REAL!!!
    The Hakko 936.
    You just can't get REAL temperature regulation unless you have a remotely mounted base station.
    http://hakkousa.com/products.asp?CID=49,112
    They can be found at the end of your budget range at the $80 mark.
    There are three models 936-11, -12, and -13. The difference is the size of the iron included. 11 being smallest 13 being largest.
    The size included means the handle size and what size tips they can accept the small model for example accepts many small tips for SMD work.
    The medium and large accepts larger tips for through hole work and some smaller tips but not as many as the iron equipped with the -11 model.
    They all connect to the same base station the model prefix has nothing to do with that so you could always buy a different iron for example the small one for SMD work later.
    You can look on their site for the assortment of tips that each iron accepts to help make a decision.
    • shovenose
      Send Doge Memes
      • Aug 2010
      • 6575
      looks fancy. but its $93??? i would need to buy it new from the loal hardware store which would have to order it, (i have gift cert there)...
      they will need to order it from their suppplier...
      btw am i totally missing something but it didnt say the wattage
      i woud thik the medium one is best. because it probably is the most versatile. am i correct?
      • Krankshaft
        • Jan 2007
        • 2328
        60 watts more than enough thermal recovery for electronics work.
        • shovenose
          Send Doge Memes
          • Aug 2010
          • 6575
          ok. so i reaallllly like that one. i hope i can get it
          • Professor Peach
            • Oct 2010
            • 18
            Again, I recommend buying used on ebay.
            Buy a METCAL, you won't regret it.
            • shovenose
              Send Doge Memes
              • Aug 2010
              • 6575
              i have $50 gift certificate credit towards the local hardware store, my mom wouldnt mind contributing a certain amount, so i want the hardware store to order one
              • Professor Peach
                • Oct 2010
                • 18
                Ah! Sorry.
                You could get them to buy one on ebay for you
                • shovenose
                  Send Doge Memes
                  • Aug 2010
                  • 6575
                  that's a good idea
                  • shovenose
                    Send Doge Memes
                    • Aug 2010
                    • 6575
                    http://cgi.ebay.com/936-12-Hakko-Sol...item5acdd857f9
                    under $80
                    • shovenose
                      Send Doge Memes
                      • Aug 2010
                      • 6575
                      who likes my new avatar i found a picture of a fuhjyyu on google images, erased the fuhjyyu and wrote over it.
                      • Krankshaft
                        • Jan 2007
                        • 2328
                        Metcal to me is like Snap On an over hyped and overpriced brand. I really don't like their induction heated tip design.
                        I don't want any RF fields anywhere near my work. It seems to me Metcal got a bit too clever for their own good.
                        When I hear induction heating I think of forging operations and expanding bearings to install them on interference fit shafts. Not fine electronics work.
                        The heating element is simple and with the newer printed type heating elements Hakko uses (Weller still uses the old wire wound elements) the tolerances are very tight. If you're even more anal about it there is a calibration pot to fine tune the base station if you have a tip thermometer.
                        Oh yeah I'd also recommend a tip cleaner like this one:
                        http://www.amazon.com/Hakko-Cleaner-.../dp/B000PDQORU
                        It's filled with brass shavings harder than tip oxidation but softer than the iron plating on the tip. No more sponges to keep wetting. Just plunge it in every now and then and it removes oxidation (the black stuff on the tip that affects heat transfer).
                        You can go through tips like toilet paper if you don't clean them off because the oxidation eats away at the iron plating.
                        • willawake
                          Super Modulator
                          • Nov 2003
                          • 8457
                          • Greece
                          metcal like one of the more expensive goot stations has expensive tips
                          • shovenose
                            Send Doge Memes
                            • Aug 2010
                            • 6575
                            meh the first time i triedto use a sponge i didnt wet it enough and it started smelling terrible
                              • 31278
                              dont use a sponge, use a brass-wool tip cleaner.
                              • ratdude747
                                Black Sheep
                                • Nov 2008
                                • 17136
                                or use both... i have the sponge and a homeade stainless steel cleaner made from a stainless steel scrubber (from a 3-pack at dollar tree if they exist out your way). it uses half a popcan , crimped to hold the scrubber, as a base. every so often i change the scrubber as the coils do get messed up and you run out of space to rotate the scrubber.
                                sigpic
                                (Insert witty quote here)
                                • mathog
                                  • Mar 2010
                                  • 2655
                                  +1.
                                  Also comes as "sponges", like this one:
                                  http://www.sparkfun.com/commerce/pro...oducts_id=8964
                                  From what I can tell in most cases both are made of a similar brass coil, but the sponge is one or just a few coils bunched up, whereas for the shavings the coil is broken into many smaller pieces. (The sponge will break up into smaller pieces eventually from the iron poking it.)
                                  In my hands these clean tips much better than do wet cellulose type sponges.
                                    • 31278
                                    xytronics make an iron stand with one built in where you usually find a sponge.
                                    • kiddznet
                                      • Jul 2010
                                      • 176
                                      This baby. 80 watts ideal for folks with four thumbs like me
                                      939 DualCore AMD Opteron, 1800 MHz (9 x 200)
                                      Abit AN8 / Fatal1ty AN8 SLI Series
                                      3072 MB (PC3200 DDR SDRAM)
                                      ATI Radeon HD 4300/4500 Series (1024 MB
                                      Lian LI Aluminium mesh case
                                      • shovenose
                                        Send Doge Memes
                                        • Aug 2010
                                        • 6575
                                        um what is "that baby"? and its euro plug-im in the us. but ive already decided on the hakko 936. now i just need to buy it
                                        and i need a multimeter
