Power-One solar Inverter driving me NUTS!!!
something strange happening in my last reply .. second link again here .its just an example and not saying buy from there
https://allegro.pl/oferta/zrodlo-odn...69-12780645910Comment
No worries Pete, I got it on my shopping list. Thank you again!!something strange happening in my last reply .. second link again here .its just an example and not saying buy from there
SUCCESS!!! Replaced those burned components and a few more that were shorted on the logic board and this is the result. I want to give a big shout out and THANK YOU to CapLeaker, SAM_SAM_SAM and Petehall347 for all your help and dedication. You guys are absolutely amazing and I could not have done this without you. THANK YOU!!Comment
I glad you got it fixed
So what were all of the bad parts did you have to replace that was either burnt out or bad when tested
I am very lazy to go back and read all the posts that were written about this issue with this inverterComment
the parts were in the area i suspected earlier on .i have never seen one of these units in front of me so i could only guess the general area like around an mcu. i should have said look for the clock crystal that's there in most cases next to them .would have been good to know what caused the damage whether it being bad design or bad quality parts etc etc . .Comment
I was wondering the same thingthe parts were in the area i suspected earlier on .i have never seen one of these units in front of me so i could only guess the general area like around an mcu. i should have said look for the clock crystal that's there in most cases next to them .would have been good to know what caused the damage whether it being bad design or bad quality parts etc etc . .
They were right next to the crystals. The parts I replaced were:
3 mosfets (SOT-23) One was burned and the other two were shorted.
4 shorted diodes (One was burned) (SOD-323)
3 zener diodes (should have been SOD-323 but I used through hole wire leads instead)
I had trouble with the zener diodes trying to figure out the marking whether it was "WI" or "W1". neither of these made any sense because my research showed the WI is 12v and W1 is 2.7v but when I found some good ones on the board and tested them, they measured 3.4v and 3.7v. So I had some 3.6v through hole zeners so I just bent the leads and soldered them to the pads. Looks like it did the trick.Last edited by mitsu2k; 12-05-2023, 10:06 PM.Comment
Yes Pete you kept asking for the model of the controller. I should have paid more attention but honestly that board intimidated me and I was too lazy to scrape off all the silicone they coated the board with. I should have listened to you earlier but I had tunnel vision and did not think the problem was on that board. Obviously I was wrong and I learned a lot from you and the other gentlemen. Next time I need to keep an open mind, get over my fear, and be more thorough with visual inspection.the parts were in the area i suspected earlier on .i have never seen one of these units in front of me so i could only guess the general area like around an mcu. i should have said look for the clock crystal that's there in most cases next to them .would have been good to know what caused the damage whether it being bad design or bad quality parts etc etc . .Comment
That is a lot that went wrong with this inverter wow
Yes the two burned components (one diode & one mosfet) were open. The rest of the components in the other side were shorted). I suspect something shorted and went down the line and fried everything else. It ran all day yesterday with no problems and still running good now.Comment
by CamaHello,
I need help to find the value of 2 missing capacitors ( C102 and C117) on my Easun SMH-II mainboard (solar hybrid inverter). I circled it in red on the close-up picture. The 2 old capacitors are completely missing, so I have no reference. Does anyone have this board and can tell me the value or make an educated guess based on the location ?
My model is : EASUN SMH-II 7 KW
Mother Board : P/N 18947-002401250250
Maybe the EASUN SMH-II 4.2 KW have the same capacitors
Thank you... -
by Francesc V.My parent's solar inverter died after 5 years of good service.
It's a called hybrid inverter:
- It can go with or without batteries
- It has 2 MPPT (8 330W panels in 2 strings) -> 5280Wp
- A 20kWh lithium battery previously used in a Nissan leaf (14S at 4.1V max) -> 57.4V
Panel is showing error 17 and the battery connection has disappeared. On the other hand, is delivering load, MPPTs are working and it's exporting energy to the GRID. Not that "bad".
Let's open it......
I see that 150A fuse is gone and the... -
by sam_sam_samI just seen this item is this a good idea if why and if not why not
Here is the website link to it
https://www.ebay.com/itm/40599879518....c101465.m3507 -
by x_orange90_xI just got this tv today and it appeared to have no backlight on. After taking off the rear cover and checking again in the dark I can see that MAYBE one quadrant is lit.. But still it's quite dim. I was going to check the LEDs with my tester, and I found LED 1 and LED 2 + pins on the wire from the inverter, but I couldn't identify a ground. Nonetheless I tried using a mounting screw on the inverter board and also the chassis as ground but regardless my tester reads 300 which is what it reads when there is no voltage draw.
I don't know how exactly to test the inverter itself. Is it... -
by GentianI have a tripp-lite aspint 3636vr inverter charger which blow some of mosfet transistors. I replaced them repaired also the driver circuit and tested but the mosfets burn again.
It work very well as inverter and also as charger if I let the rear switch in auto mode (inverter) and charger only(charging) but in auto when I connect the feed line 220V AC first time it pass ok to line and start charging the batteries but when I remove the feed line it pass to inverter mode and if I do it again the second time when passing from charging to inverter the Main transformer start making a...03-06-2023, 07:07 AM - Loading...
