Repairing a snapped pcb
  • Crystaleyes
    • Sep 2021
    • 493
    • Brazil
    Hi all.
    Recently picked a very cheap (20 Euros) Allen and Heath XONE 62 DJ mixer, which had clearly been dropped and upon opening up, has two snapped pcb's.
    Other than bridging each trace, does anyone have any other suggestions or ideas as to how to resolve these?
    There are probably twenty broken traces on each board.
    The photos are of the board I glued with No More Nails (just to get things started).
    I was thinking of using enameled speaker wire...
  • petehall347
    • Jan 2015
    • 4426
    • United Kingdom
    Re: Repairing a snapped pcb
    might be easier to use conductive paint on the thin close together ones .careful scraping and masking off first .
    • Crystaleyes
      • Sep 2021
      • 493
      • Brazil
      Sounds interesting.
      Didn't know that it existed
      Just looked it up, wicked stuff. What a great idea!
        • 31010
        the tracks arent the problem, reinforcing the board is.
        it would be tempting to price up a new pcb from pcb-way,
        it's only single sided.
        • truclacicr
          • Apr 2019
          • 301
          • australia
          I would run wires from point to point. Tedious, but reliable.
          • Crystaleyes
            • Sep 2021
            • 493
            • Brazil
            Thanks for the suggestions...
            To be honest, board strength has been my main concern, although after soldering the thicker traces, the board pictured is already fairly rigid again.
            I should finally be back in England next month, earning real wages, so I was thinking of ringing up Allen & Heath and seeing if they had any old 'blank' boards laying around that they would sell?
            I need both the boards with the LED power bars.
            And seeing how I essentially got the mixer for free, it had also crossed my mind to get some replacements made, although that is something I've never done before.
            I'll see if anyone here sells the conductive paint first.
            • Crystaleyes
              • Sep 2021
              • 493
              • Brazil
              Do you reckon I could get away with enameled speaker wire on the thinner traces?
              • tester272001
                • 91
                To add strength. Perhaps use some epoxy like JB weld to glue the component side with some plastic to help prevent flexing.
                • Crystaleyes
                  • Sep 2021
                  • 493
                  • Brazil
                  This is also what had crossed my mind.
                  There are areas with just resistors or links (which could easily be replaced with longer legs), where another piece of board could be added and the holes re-drilled with a Dremel.
                  • petehall347
                    • Jan 2015
                    • 4426
                    • United Kingdom
                    with it being audio the routing might be important .. i know wires in the wrong rout can cause havoc
                    • truclacicr
                      • Apr 2019
                      • 301
                      • australia
                      Any insulated wire should do the job. Audio is low frequency, so you don't need to be concerned with exotic stuff like transmission line impedances, unless you're an audiophool.
                        master hoarder
                        • May 2008
                        • 12170
                        • Bulgaria
                        You could.
                        But I personally would use (and have used in the past) very thin bare copper wire. The best place to get this is to find some 24-18 AWG stranded copper wire with fine strands and then pull individual strands from the wire to put on those traces. The neat thing about using very thin bare wire is that it is easier to solder and you don't have to worry about removing any insulating coating. With enameled wire, you have to strip the coating, and it has to be done well so that each wire solders properly to each trace. But the stripping will make the job much harder and slower, IME.
                        As for PCB reinforcement, you can do that on the top with some scrap plastic or wood or PCB pieces and hot glue. I know it sounds janky/ghetto as heck, but it works really well, especially if you happen to have good quality hot glue and get it extra hot on there. I have fixed a number of PCBs like this before, and they are still holding up well - even to slight abuse.
                          • 31010
                          the way to fix broken traces is to scrape any solder mask off whats still there and solder copper wire onto the trace.
                          i like to strip old power cables for nice copper strands
                          the bigger pads i use offcuts of solid copper from house wiring.
                          transformer wire is tempting but getting the enamel off them is a pain.
                          • Crystaleyes
                            • Sep 2021
                            • 493
                            • Brazil
                            Some excellent suggestions, so thank you sincerely.
                            One observation is that some of the broken traces are really fine, therefore it is easier to run longer lines and those would need some form of insulation.
                            As for using solid copper.. I like that, and have lot's of that here.
                            I-ll keep you all updated as I do this work
                              master hoarder
                              • May 2008
                              • 12170
                              • Bulgaria
                              Maybe it's the size/zoom of the images, but the small traces don't look that bad to me. Would/should be pretty easy to do with just shorter pieces of very thin bare copper wire (again, strands taken from bigger wire, like 24-18 AWG.) I've fixed PCI-E lanes on a graphics card with this method and it's certainly easier than running long pieces of insulated wire.
                              The only trick to soldering all of the fine wires next to each other is to 1) always keep a good amount of flux on everything and 2) very little solder on the soldering iron's tip (close to none would be ideal so you don't run the risk of bridging the wires.) And on that note, use solder that is eutectic in nature (63/37 OK). As much as I like 60/40 for general repairs and its ruggedness / flexibility, I tend to avoid it for SMD and very thin traces, because it has a higher chances of bridging over if I'm not extra careful. In contrast, the cheap 95 Sn / 5 Sb lead-free solder I use is quite eutectic and I've really gotten used to it for SMD and fine trace repair - the moment I pull the soldering iron away, it hardens.
                              • harp
                                • Jun 2022
                                • 598
                                • Planet Earth
                                It is one side pcb with not to much fine traces.
                                I preffer to use a used (soaked with tin) pieces of soldering wick (yes I collect it), it is ideal to combine and reinforce big area, like grund plane or power rails. It is not so stiff like solid copper wire, and it almost flatten with surface on pcb when done. It cover large surface with equal strenght. Try.
                                For fine traces, I preffer to use a ripped fine traces from scrap board, it is much less hassle then to use round wire. But you must prepare them... I think that in your situation is not necessary to use fine ripped traces, use a pretinned fine copper wire.
                                https://m.youtube.com/watch?v=igUjV-u4BmQ
                                To repair fine traces who has a near one by side, like on your edges, use a technique to separate workarea like in this video
                                https://m.youtube.com/watch?v=PO6b5VD7bbg
                                • truclacicr
                                  • Apr 2019
                                  • 301
                                  • australia
                                  People seem to be focused on bridging the crack. Instead, if a trace connects a capacitor to a resistor, say, then run a wire between the solder terminals of the two components.
                                  • Crystaleyes
                                    • Sep 2021
                                    • 493
                                    • Brazil
                                    Some excellent tips and suggestions, most of which I can see being extremely useful, so nice one, for all the input.
                                    Haven't had a free moment to try any of these out yet but gonna get on it in the coming days.
                                    Wish me luck!
                                    • harp
                                      • Jun 2022
                                      • 598
                                      • Planet Earth
                                      Example: used desoldering wick (bottom left part) and twisted pretined wire (centar)
                                      When you finish share outcome pics... luck
                                      • JTaylor
                                        Allen and Heath Xone S2
                                        by JTaylor
                                        Hello everyone.
                                        I am trying to repair an Allen and Heath Xone S2 mixer but need a schematic. I found the service manual on line but it is missing 4 pages.
                                        When an input is connected to one of the four line / phono input channels I can hear the music in the cue / headphones but there is no output on the master, the input faders are doing nothing. I can connect the sound input to the mic / line inputs or the external input boards and there is sound on the master output. One of the 74HC4053D Multiplexer/Demultiplexer had blown on the slave PCB so I changed this, I also changed two of...
                                        05-02-2025, 08:08 AM
                                      • trickartt
                                        Allen & Heath Xone:02 (DJ Mixer) - Burnt out Resistor
                                        by trickartt
                                        Hello Badcaps!
                                        I am trying to troubleshoot my Allen & Heath Xone:02 DJ mixer. I have had this for somewhere close to 20 years and have played music through it in one form or another pretty much every single day since I've had it, though these days it's usually from a wireless streaming receptacle (Apple Airport) more than the turntables that are also connected to it.
                                        This week my music stopped working, and after a bit of a wild goose chase, I realised my mixer was dead. I checked the 500mA fuse in the device beside the power supply and found it was blown, so I replaced...
                                        05-04-2024, 12:07 PM
                                      • jaifraic
                                        Allen & Heath Xone:92 (DJ mixer) no output on main out & magic smoke
                                        by jaifraic
                                        I have a DJ mixer here, an Xone:92 by Allen & Heath.
                                        When I turned it on, only magic smoke came out, so I turned it off again.
                                        An optical troubleshooting has brought me quite fast to the
                                        source of the smoke: two resistors look disproportionately black (see first pic)
                                        Those are R73 and R74 on the master PCB. See second pic for the corresponding page of the service manual.
                                        Behind those resistors are five OP-Amps (U3, U4, U5, U6 and U9).
                                        My thought is that one (or more) of those is defective. I've measured...
                                        03-15-2022, 12:32 PM
                                      • analogicalmind
                                        Allen & Heath Xone:92 mixer problem - faulty phono channel outputs on one side only
                                        by analogicalmind
                                        Wondering if anyone here can help – I have an Allen and Heath Xone:92 silver mixer with one faulty channel – channel 2 is only outputting on one side (right side) when set to a phono input. It works fine with a line input, and all the other channels work perfectly with phono and line inputs. I'm not sure when this happened as I rarely use the faulty channel – it could well have been like this for years! Any thoughts on what might be causing the fault and how it could be repaired? I can do some basic soldering, so I'm hoping I might be able to fix it myself.
                                        02-17-2022, 12:33 PM
                                      • thesame
                                        Allen & Heath Xone 92 Filters Problem
                                        by thesame
                                        I will post some video just so you can understand the problem, no caps with problem on the effects boards, weird is that the second filter affects the one that's assigned , hope you can notice that in the video, is it safe to just put the effects boards into the ultrasound cleaner ?
                                        https://www.youtube.com/watch?v=dwUm...nnel=TechStuff
                                        https://www.youtube.com/watch?v=He_q...nnel=TechStuff
                                        08-02-2022, 01:10 PM
