Allen & Heath Xone 92 Filters Problem
  • thesame
    • Mar 2018
    • 141
    • Romania
    I will post some video just so you can understand the problem, no caps with problem on the effects boards, weird is that the second filter affects the one that's assigned , hope you can notice that in the video, is it safe to just put the effects boards into the ultrasound cleaner ?
    https://www.youtube.com/watch?v=dwUm...nnel=TechStuff
    https://www.youtube.com/watch?v=He_q...nnel=TechStuff
  • thesame
    • Mar 2018
    • 141
    • Romania
    Re: Allen & Heath Xone 92 Filters Problem
    Problem solved after cleaning mainboard and all faders i found two swallen caps 470 uF 25V on the psu, replaced them ,and everything came back to normal.
    • analogicalmind
      Allen & Heath Xone:92 mixer problem - faulty phono channel outputs on one side only
      by analogicalmind
      Wondering if anyone here can help – I have an Allen and Heath Xone:92 silver mixer with one faulty channel – channel 2 is only outputting on one side (right side) when set to a phono input. It works fine with a line input, and all the other channels work perfectly with phono and line inputs. I'm not sure when this happened as I rarely use the faulty channel – it could well have been like this for years! Any thoughts on what might be causing the fault and how it could be repaired? I can do some basic soldering, so I'm hoping I might be able to fix it myself.
      02-17-2022, 12:33 PM
    • trickartt
      Allen & Heath Xone:02 (DJ Mixer) - Burnt out Resistor
      by trickartt
      Hello Badcaps!
      I am trying to troubleshoot my Allen & Heath Xone:02 DJ mixer. I have had this for somewhere close to 20 years and have played music through it in one form or another pretty much every single day since I've had it, though these days it's usually from a wireless streaming receptacle (Apple Airport) more than the turntables that are also connected to it.
      This week my music stopped working, and after a bit of a wild goose chase, I realised my mixer was dead. I checked the 500mA fuse in the device beside the power supply and found it was blown, so I replaced...
      05-04-2024, 12:07 PM
    • jaifraic
      Allen & Heath Xone:92 (DJ mixer) no output on main out & magic smoke
      by jaifraic
      I have a DJ mixer here, an Xone:92 by Allen & Heath.
      When I turned it on, only magic smoke came out, so I turned it off again.
      An optical troubleshooting has brought me quite fast to the
      source of the smoke: two resistors look disproportionately black (see first pic)
      Those are R73 and R74 on the master PCB. See second pic for the corresponding page of the service manual.
      Behind those resistors are five OP-Amps (U3, U4, U5, U6 and U9).
      My thought is that one (or more) of those is defective. I've measured...
      03-15-2022, 12:32 PM
    • JTaylor
      Allen and Heath Xone S2
      by JTaylor
      Hello everyone.
      I am trying to repair an Allen and Heath Xone S2 mixer but need a schematic. I found the service manual on line but it is missing 4 pages.
      When an input is connected to one of the four line / phono input channels I can hear the music in the cue / headphones but there is no output on the master, the input faders are doing nothing. I can connect the sound input to the mic / line inputs or the external input boards and there is sound on the master output. One of the 74HC4053D Multiplexer/Demultiplexer had blown on the slave PCB so I changed this, I also changed two of...
      05-02-2025, 08:08 AM
    • theone111
      by theone111
      3. Problem: TV shuts down
      07-22-2024, 10:36 AM
