Ring tester
  • tony359
    • Oct 2018
    • 259
    • United Kingdom
    Ring tester
    I'd like to add a ring tester to my toolbox to test flybacks but also low frequency transformers if possible.
    I found a few products online, some based on the "diodegonewild" design, others are different designs. Some are available to build DIY, others are not.
    Any suggestions on a DIY one I could put together? Ideally something which would also be able to test low frequency transformers, that might be handy.
    So far I found these two:
    http://bobparker.net.au/Basic%20Digital%20Ringer/ (the posher version is only for sale)
    https://oshwlab.com/michelemancini2/blue-ring-tester
    Any other options and/or recommendations?
    Cheers!
    Tony
    • 31015
    Re: Ring tester
    i built several dick-smith ones - they work well
    also there is a digital one now from Dany-K that looks more flexable
    https://danyk.cz/avr_ring2_en.html
    https://www.youtube.com/watch?v=QBbEYYWiBI8
    https://www.youtube.com/watch?v=E1dopmxph2A
    • tony359
      • Oct 2018
      • 259
      • United Kingdom
      Re: Ring tester
      Danu-K is "diodegonewild" indeed
      My only issue with that is that there is no gerber file available - unless I am mistaken? Sure, I could make my own but learning how to use KiCad is on my to do list
        • 31015
        Re: Ring tester
        gerbil file?
        lazy bastard!
        he used stripboard,
        if you want to make one you can generate your own board with kicad or Eaglecad.
        personally i use the old eaglecad 7.x before it got screwed over and turned into a cloud based mess by AutoDesk.
        i build the dick smith ones on stripboard btw - the circuits are not that large.
        • tony359
          • Oct 2018
          • 259
          • United Kingdom
          Re: Ring tester
          ahaha touche'!
          I have no problems getting a PCB design and just turning into a gerber file - I thought I had to create the whole board! But how do I do that? I don't see files to be downloaded. Am I being a lazy bastard again?
          Dany-K's one is good but there are some available which can also measure low frequency ones. I think Bob's tester I linked above is also doing LF ones?
          • redwire
            • 3910
            Re: Ring tester
            I feel the EVB guy in Portugal is too expensive at 72€ (USD $77, CAD $105, AUD $120) incl. shipping.
            I have never seen the firmware file allowing others to build the tester.
            It has a 3.3V impulse, JET and comparator for high sensitivity, boost-converter to run off 2 AA batteries, auto power off.
            Diodegonewild is basic and lowest cost, but is less sensitive. He needed a MCU with a few more pins for that.
            So I've been working on my own ring tester until I got burned by shitty Aliexpress IC's and lost interest lol.
            Testing on oddball magnetics, some huge tube audio OPT and chokes, and small SMPS transformers.
            Can't get more than about 7 rings on small SMPS transformers and shorted turns brings that right down to 0-1 ring.
              • 31015
              Re: Ring tester
              Originally posted by tony359
              ahaha touche'!
              you print the schematic - or put it on a second screen if you run several
              then recreate the schematic in eagle/kicad
              once you have the schematic in cad you can generate the board.
              you set the basics - size & number of layers.
              then put the parts where you want them and the software tries to work out the track layout
              you can trick these cad programs into generating stripboard layouts too.
              you say that the grid spacing is 2.54mm and it has 2 layers
              then you tell it to favor horizontal tracks on the top and vertical tracks on the bottom.
              then magic happens
              • tony359
                • Oct 2018
                • 259
                • United Kingdom
                Re: Ring tester
                Ah ok, that is what I mean with "learning how to use KiCad is on my to do list"
                I know what you mean it's just not something I can invest this amount of time on now - hence I was looking for something ready because I am a "lazy bastard"
                • redwire
                  • 3910
                  Re: Ring tester
                  Bob Parker's Blue2 Ring Tester cannot be built, we have no firmware or PCB/Gerbers.
                  Lately when I need a ring tester, I just breadboard it using an Arduino. But it struggles for computing power with its fat library code.
                  So I thought go to a SAMD21 M0 or write it in assembly language for the '328 or '328PB. I can't decide.
                  Dany-K ring tester 2 added a meh comparator and pretty small excitation pulse, I haven't yet tried it.
                  I can't see what the minimum ring frequency is, you'd need for testing big magnetics. The ATtiny24 source code needs a bit of translation I guess.
                  I had a 12V 10A mains transformer and detecting a shorted turn on it not easy. You need a good sized pulse like 5V I find.
                  • eccerr0r
                    Solder Sloth
                    • Nov 2012
                    • 8701
                    Re: Ring tester
                    hmm...tempting to design and build one in case my sencore dies ...
                    thinking it should be doable in a tiny2313... hmm!
                    (2313 because I still have a pile of unused at90s2313s that are waiting for a use ...)
                    • redwire
                      • 3910
                      Re: Ring tester
                      Tried out the circuit on a big ass choke, Hammond 193M rated 10H 300mA 63Ω weighing in at 10.5lbs/4.8kg.
                      You can see it rings for over 200msec which is a huge window. The comparator chatters a bit before and after. The spike is my S/W gate closing at the end (mosfet off). A 25msec gate dampens it fast and you get a wrong low ring count of ~8. Top blue trace is the comparator output, bottom yellow trace is output of the JFET.
                      I find you need more than a basic ring count because the magnetics being tested can have over 1,000,000:1 difference in inductance value. Then there is the effect of the shorted turns. uH matter for SMPS transformers and small inductors.
                      Shopping for an ARM MCU to get into and finish this.
                      ST are really expensive now and I hear their dev environment is brutal.
                      Microchip SAMD21 looks good but I can't find the dev board I have for it and the datasheet is at 1,153 pages.
                      ARM suck they've made everything super complicated.
                      It's a matter of a MCU for $1.50 or $6 I guess.
                      Open to any suggestions.
                        • 31015
                        Re: Ring tester
                        there are good st clones from gigadevice all over ali
                        you can use arduino ide with them
                        or you can use a raspberry pie thing, but i wouldnt recommend them - the i/o isnt 5v tollerent and they have no cpu cache.
                        or maybe an esp?
                        not much io on those but arduino ide supports them and they are piss-cheap
                        https://www.aliexpress.com/item/1005005470719229.html
                        • tony359
                          • Oct 2018
                          • 259
                          • United Kingdom
                          Re: Ring tester
                          Thanks.
                          Could you share a link of one of them?
                          • CapLeaker
                            Leaking Member
                            • 8148
                            Re: Ring tester
                            Redwire, you couldn’t find anything bigger than that? Lol
                            • redwire
                              • 3910
                              Re: Ring tester
                              I think a Ring Tester should work with big iron as well as small ferrites lol.
                              Still working on it, waiting for new parts.
                              I have learned there is no point being really cheap with MCU's even $1 more can get you tons of memory and features.
                              But three timers may not be enough for a better ring tester. More later.
                              For a bunch of magnetics I have, I prove things by adding a shorted turn and compare the before/after ring counts.
                              Large 12V 10A 60Hz transformer gives: 11 rings (primary) at 930Hz, shorted secondary (at center tap) 7-8 rings (primary) at 10kHz on the breadboard.
                              I thought some smarts should be added to the ring tester- so that is not misleading or a "pass".
                              From the Bob Parker instruction manual:
                              Low frequency transformers
                              "50/60Hz mains and tube output transformer primary windings produce much lower readings than ferrite cored transformers. If possible, always compare the tester's readings on a suspect transformer with its readings on a known good transformer of the same kind.
                              Typical readings are around 15 to 30 for a good transformer primary winding without any interference from other components in the circuit.
                              Shorted turns usually drop the reading to less than 10, however a solid short circuit on a secondary winding can produce a reading similar to a good transformer, so keep this in mind.
                              Please try out the tester on as many transformers and inductors as you can, to get a “feel” for what are normal readings. There are so many different inductors and transformers that it's not possible to provide “hard and fast” readings for all of them."
                              I was looking at the under $2 MCU offerings that are low power. The Blue Ring Tester has the 2xAA 3V->5V boost converter running all the time and powering the 5V MCU which goes to sleep. Bluepill STM32F103C8 is not low power enough in sleep mode.
                              Just tried Microchip MP LAB X IDE a 1GB download and install and what a piece of shit. It's covered in social media/cloud based crap and my firewall complained it wants LAN access. Then the message "you do not have a compiler installed" showed up Microchip is trying to railroad you into using their subscription compiler. Sigh. Need to install 2GB more... really?!
                              I love Atmel parts but Microchip buying them was a tragedy. Steve Sanghi is out to lunch. I can see why Arduino abandoned them now for Renesas.
                              Uninstall the IDE and it left shit stains all over - undeleted folders, files, registry entries and lots of time cleaning that mess up
                              Even Atmel Studio is a near 1GB download that Zuckerberg seems to have commissioned. Unbelievable.
                                Used a Ring tester to troubleshoot a switching power supply that has a blowed fuse
                                by sam_sam_sam
                                I found this switching power which has a blowed fuse checked diodes which were still good out of circuit checked main filtering capacitor with an ESR meter 220uf@450 volts 0.15 value which to me seem bad but maybe not but without these items not in the circuit because I have about 8 ohm on the output of the capacitors so I removed the switching power supply transformer and checked it with a ring tester and all but one winding showed good all others either showed two red lights or no lights on and one winding had all lights on which was the only one that was good
                                One other check that...
                                08-03-2021, 06:41 PM
                              • CapLeaker
                                VOIP, ATA REN and old analog phones ring voltage booster
                                by CapLeaker
                                I am working on a backup phone to VHF paging solution. Basically I am dealing with the old Zetron pagers. Here is how it works: One calls a number, the Zetron picks up, operator punches in the DTMF access code, the Zetron keys the transmitter and you can talk. press # the Zetron unkeys the transmitter and hangs up / times out.
                                Now this setup works good on the old land lines, but not at all using a VOIP ATA. You can call all you want and swear like a bastard at the Zetron, but it will not (even if I threaten it's life) pick up.
                                Yep, I know about the high ring voltage...
                                12-10-2022, 09:27 PM
                              • Lifeisfun
                                Trying to troubleshoot DDR4 SODIMM slot with slot tester
                                by Lifeisfun
                                Hi folks!
                                I have some kind of memory problem on Lenovo laptop. I was initially able to install windows after several tries since the laptop did freeze in middle of those attempts.
                                Eventually I discovered that it was related to moving the laptop.
                                Later on it even stopped booting unless I pressed around the memory slot. (no keyboard LEDs only power button responds)
                                If I remove the RAM I get the beeps that RAM is missing. Inserting the RAM there is silence and it will not boot most of the time. No picture.
                                I removed the board got one of those memory slot testers...
                                06-04-2025, 02:26 PM
                              • spleenharvester
                                Reverse engineering of 18650 4-channel tester
                                by spleenharvester
                                Hi friends
                                I have reverse engineered this tester, schematic is attached and is complete except for capacitor values. These testers annoyingly have no model number but they are the ones you find on the first page of just about any website if you type in "18650 4-channel tester". There is also a 2-channel variant and a newer 8-channel variant. They are very cheap (about £15) and can measure voltage, current, internal resistance and capacity. They have a multicolour display for all these statistics. They also have terminal blocks so that if you want to use a breakout board...
                                05-04-2025, 02:43 AM
                                FNIRSI HRM-10 Internal Resistance Detector AC Lead Acid Lithium Battery Tester Review on some testing of device
                                by sam_sam_sam
                                https://www.ebay.com/itm/405035016711
                                I got this device yesterday and did some testing on some tabbing and some incandescent light bulbs and it seems to work very well from what I can tell but how do I know how accurate the m-ohms section is what can I use to verify it accurately I also tested some li-ion battery cells and this seems to be fairly accurate because I have another tester and they seem to agree with each other
                                I also checked some capacitors with it that were brand new and seem to show about what I expected to see with my blue capacitor tester so I think it...
                                04-13-2025, 08:17 PM
