Ideapad 100 NM-A841, P channel mosfet on laptop in.
  • tmaster21
    • Feb 2021
    • 28
    • Portugal
    Hello guys. i'm having problems here with this lenovo 110 with board NM-A841 laptop. There is an P channel(pq302) and after it i start ,i have 19v but with time, it decreases or if i press "power on" switch or jumper j6 , it falls to 0 and back to 19v. There is no short and works good on battery, but won't charge or charge until the voltage drop like i explain after P mosfet.
    Well i suspect that this mosfet is no good. if you look to skematic i have steady 19v on P2 but start to decrease on P3 like if the mosfet is dying . the gate of boot N an P mosfet are the same: is steady 17.7v.
    i don't undertand really why is this mosfet here and why are the running at same gate voltage...can someone give me a light whas happening here?
    skematic from here:
    https://www.badcaps.net/forum/showthread.php?t=76971
    Last edited by SMDFlea; 07-17-2023, 10:47 AM. Reason: Added model to thread title,added image to badcaps
  • janocko
    • Nov 2015
    • 19
    • indonesia
    Re: p channel mosfet on laptop in.
    you can try to reflow with hot air blower IC OZ or PU301.
    • mcplslg123
      • Jun 2015
      • 7262
      • india
      Re: Ideapad 100 NM-A841, P channel mosfet on laptop in.
      PQ301/302 are both P channel mosfets and their gates are connected together-so there will be same voltage on pin4 of both these mosfets. Since both are P channel,gate voltage should be lower(5V-12V) for it to work. You are getting +19V at P2 'coz the PQ301 has forward direction diode(inside mosfet) but it cant reach P3 as the diode is in reverse order or blocking mode in PQ302. So you need to fix gate voltage of both PQ301/302.
      01.
      Check resistance between
      pin1-4
      pin4-5
      pin1-8 for both PQ301/302.
      02.Try removing PQ304/305(they are there just for protection)
      03.Check resistor value for PR307/303 as they are voltage divider circuit for Gate pin voltage.
      If the issue persists, then measure voltage on PQ307/315 and post here. Dont reflow or heat up PU301 without finding the root cause.
      • tmaster21
        • Feb 2021
        • 28
        • Portugal
        Exacly what i think ... so this pq307 receive PACIN signal and shoud starting ground the gate for this mosfets start work. that's it? but i dont understand if the pq302 diode is reversed it will conduct forward to p3??
        resistors are ok.
        datashet from pq302 (4455) says vgs Threshold between -1.5v and 2.6v so power suply its around 20v - 17.7v from gate its 2.3v. Shouldn't be that gate ok for hold the mosfets running???
        • mcplslg123
          • Jun 2015
          • 7262
          • india
          PQ307 should receive PACIN high(Gate). Since the gate is high, that will turn on this N channel mosfet resulting in Source(GND) travelling to Drain. Drain of PQ307 is connected to PR307,pin2. A voltage divider will work when one end will receive voltage and the other vend will be ground. In this case PR303 is your R1 and PR307 is R2. R1 & R2 will act as voltage divider when pin1 of R1 will receive 19V and pin2 of R2 will be grounded. Going by the voltage divider formula you should get 4.82V at gate of PQ 301/302.
          Your understanding of mosfet datasheet is not correct. perhaps you need to learn more.
          Our mission is to help as many members in whatever way possible but we really cant teach complete theory/principles here. You need to understand what is blocking mode concept in mosfet. I cant explain everything here in detail.
          I tried my level best to explain how gate voltage of PQ301/302 will work.
          • tmaster21
            • Feb 2021
            • 28
            • Portugal
            Thank you. this explanation confirmes my doubts about this p chanel mosfet with reverse diode. i know they are used for reverse polarity protection here ,bus i was in doubt about the working principle here. know let me see whas happening on this gate for i have so high value o mosfets gate. (yes the laptop stills here waiting for i finish it...). always confirm every doubt before reheat and brake everything X)
            • tmaster21
              • Feb 2021
              • 28
              • Portugal
              @mcplslg123
              you are the best! SOLVED!
              pq304 was in low impedance ,causing that i measure 10k on the pr303 - 200kohm pr303 resistor. i thought tha was the resistor but was the transistor. now gate voltage = 5v ✓
              but i'm not getting ..why are there transistors here(pq304 and 305), protecting what ? PACIN send pq307A to ground and they conduct...than means mosfets only work if there is pacin present?for what is that? pacin is the one that activate the mosfets anyway...
              • mcplslg123
                • Jun 2015
                • 7262
                • india
                Pleased to know you solved it. What i have told is simple basics and certainly not rocket science.
                Yes PACIN will ultimately lead to correct gate voltage on dc-in mosfets depending on rest of the components are working. PQ304 and PQ305 are part of protection circuit and both of them are different(look at direction of arrow in PQ304/5).You need to understand how NPN and PNP transistors work and i'm sorry i cant explain them here in detail. there are youtube videos which you can watch and try to understand better.
                • dj8452000
                  How To Test a P-channel Trench Mosfet Using A Multimeter In Diode Mode
                  by dj8452000
                  I am new to electronics and I'm understanding most of what I'm reading but I have a mosfet on my board that I've identified as a P-channel Trench Mosfet. I haven't a clue how to test this and what I should expect to see with the multimeter probes. I am hoping someone with years more experience than myself can help me understand how to use a multimeter to read this. Please look at the drawing I have attached to this and can you try to explain to me what I should be doing with my multimeter in diode mode and what results I should expect from a good mosfet?...
                  02-18-2025, 08:28 AM
                • ebyte64
                  Lenovo IdeaPad 330 laptop mosfet issue
                  by ebyte64
                  Good day everyone.
                  I have been scratching my head with a Lenovo laptop I got in today.
                  The laptop had no power and taking no amps from the power supply. Checking voltage showed 20v only on one side of the first mosfet. Took it off and replaced it and then same story. Took off second mosfet and then the first mosfet had the right voltages as well as 25v on gate is it should. Replacing the second mosfet the problem started again.
                  Even using a wire to bypass the second mosfet does the same interference with the first mosfet.
                  Would anyone...
                  06-27-2023, 10:19 AM
                  Lenovo IdeaPad IdeaPad 3 15IGL05 Notebook 3 Specification for Upgrade or Repair
                  This specification for the Lenovo IdeaPad IdeaPad 3 15IGL05 Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the IdeaPad 3 15IGL05 boardview and IdeaPad 3 15IGL05 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet,...
                  09-07-2024, 05:20 AM
                  Lenovo IdeaPad IdeaPad Gaming 3 15IHU6 Ultrabook 3 Specification for Upgrade or Repair
                  This specification for the Lenovo IdeaPad IdeaPad Gaming 3 15IHU6 Ultrabook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the IdeaPad Gaming 3 15IHU6 boardview and IdeaPad Gaming 3 15IHU6 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any...
                  Lenovo IdeaPad IdeaPad 3 17ITL6 Notebook 3 Specification for Upgrade or Repair
                  This specification for the Lenovo IdeaPad IdeaPad 3 17ITL6 Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the IdeaPad 3 17ITL6 boardview and IdeaPad 3 17ITL6 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet,...
