Calculating resistor values in parallel with Caps
  • Crystaleyes
    • Sep 2021
    • 493
    • Brazil
    Hi all.
    I recently picked up a dead car amplifier from the flea market, with the intention of learning some more in the area of audio repair.
    It has a stereo output with an added mono woofer output. The stereo channels are on one board, whilst the woofer section is on a separate board. There are also three large (ish) transformers.
    Apart from the fact that it was seriously dirty inside, it seems to be essentially complete with the only clearly damaged component being a toasted 1/4 watt resistor on the woofer board and it is this which I am wondering how to replace?
    I'll post some pictuires if requested, however the resistor in question is in parallel with a 47uF 63v electrolytic.
    I won't lie that I'm not familiar with the reason behind using resistors in parallel with caps, but surely, for the cap to have any effect, then the resistance cannot be too low?
    That said, is there some kind of calculation that can be used to discover an appropriate value for the resistor, considering we know the value of the capacitor?
    Everyday is a school day...
  • tester272001
    • 91
    Re: Calculating resistor values in parallel with Caps
    I'd suggest you post a picture. Best to try to see if you can read the burnt resistor value. One use of a resistor across a cap is for bleed off the voltage. It would normally be a higher ohmage value. Seeing the component and what is NEAR might help too.
    • Crystaleyes
      • Sep 2021
      • 493
      • Brazil
      Thanks for the response.
      The large thing at the bottom is a transformer, but not the mains transformer...
      • Loading666
        • Jun 2023
        • Portugal
        Cant u get with a multimeter?
        • Crystaleyes
          • Sep 2021
          • 493
          • Brazil
          Yes, and it reads less than an ohm, but I can't rely on any value given by a toasted resistor.
          In orde for the capacitor to actually have any useful effect, I would have imagined that the resistor would have been much higher, but I honestly don't know... Hence my asking here.
          • Per Hansson
            • Jul 2005
            • 5895
            • Sweden
            It does not look burnt, it only looks like it desperately needs a bath in some warm water with dish soap in it!
            • faraday28
              • Jan 2022
              • 15
              • Indonesia
              It looks like snubber circuit, diode + cap + resistor but snubber usually don't use polar capacitor and the resistor usually in series with cap in PSU design.
              There are ways to determined the resistor but it does involving removing the parts and not burnt.
              Unsolder the resistor in question and check if it really dead or not with multimeter.
                • 31092
                unusual visuals there.
                remove the electrolytic and check it didnt leak.
                and show us the trackside of the board.
                if thats the sub, it may be a lowpass-filter to make sure the center-drive only amplifies the bass.
                  • 31092
                  incidentally, watch where you put your fingers while testing it later.
                  the reason for so many transformers is because they usually have a boost convertor that steps the 12v upto around 40v to feed the amps.
                  • Crystaleyes
                    • Sep 2021
                    • 493
                    • Brazil
                    Thanks for all the input fellas.
                    The cap in place is a replacement and the original hadn't leaked.
                    I've emailed the manufacturer a couple of times now but no joy with any response, but I will pull the resistor and see how it reads...
                    I'll be back
                    • Crystaleyes
                      • Sep 2021
                      • 493
                      • Brazil
                      So...
                      Came across an article which suggested removing the burnt coating from the resistor in order to see how many spiral stripes there were.
                      The less stripes, the lower the resistance value. Makes sense...
                      As can be seen in photo #1, the original resistor appears to have roughly two stripes, which (according to the article) would indicate a value of between 10 to 100Ω.
                      Measuring the burnt resistor however reads just over 150Ω.
                      Considering that resistances tend to increase once a resistor has been overheated, I'm thinking of just sticking a 100Ω resistor in its place and see what happens.
                      The hope is, that the damage was caused by the output wires being shorted and not some other fault on the pcb.
                      If anyone has any other opinions then I'm all ears.
                      EDIT:
                      After stripping down a 62R resistor (pic #2), it looks like that wouldn't be such a bad replacement, especially when compared to the 100R in pic #3.
                      It should perhaps be an 82R but I don't have one here
                      • Crystaleyes
                        • Sep 2021
                        • 493
                        • Brazil
                        The two empty solder holes are where the resistor came from...
                        • Crystaleyes
                          • Sep 2021
                          • 493
                          • Brazil
                          In the end I found a single 75R (which measured 79Ω) 1W resistor in my supplies and installed that.
                          So, I reckon this thread is closed.
                          I needed to work out what the burnt resistor value had been and am 90+% sure that it was +/- 82Ω.
                          Thanks for all the input as I have learned a valuable lesson here.
                          • Califauna
                            Help with boom box modification
                            by Califauna
                            Hi, this is more of a project help request than a troubleshooting question. I hope I can post it here.
                            I have a W-King D8 Bluetooth boom box which I'd like to modify with some external speaker output jacks and some buttons to switch the internal speakers on and off.
                            From factory the specs of the boom box are:
                            -Power Input: DC 5V
                            -Speaker Output Power: 2 x 25W ( confirmed by Youtube channel Hartdegen review as 12.5W RMS per channel)
                            -Drivers:
                            -2 x Woofer, 70mm, 10Ω, 70mm,15W
                            -2 X Tweeter, 8Ω, 30mm,10W x 2
                            -Frequency...
                            12-04-2021, 01:53 PM
                          • Kobok
                            Different (lower) resistor values on PCB?
                            by Kobok
                            Dear Alls,
                            For sure it id a stupid question, but help me to understand. I am in a Dell 2007WFP revitalizing project - searching reason why not starting. Some resistors needed to replaced is is obvious. When I have soldered some resistors the measured (with multimeter) values were sometimes rather different written on them. I supposed these are wrong units so I desoldered and made a checking measurement and voilá the values is the same is written on. This happens only in case of a few resistors, most have the same values (+/- 10%) are written on it. "strange" SMD resistors =>103...
                            09-19-2022, 07:30 AM
                          • jinu_j
                            by jinu_j
                            Hi
                            05-03-2025, 10:51 PM
                          • madushanka 1234
                            need to find RESISTOR values of mising LA-E831P
                            by madushanka 1234
                            need to find mising parts LA-E831P
                            need to find values of this marked resistors...
                            another shop mixed this marked 5 resistors...
                            please check 3rd photo
                            (rt3661b section/puz1)
                            thank you
                            02-17-2025, 07:26 AM
                          • chronic519
                            HP EliteBook 845 G8 (need resistor values by EC chip please)
                            by chronic519
                            Hello, I have an EliteBook 845 G8 motherboard sitting here. Customer knocked of 2 resistors by the EC chip. I cannot find schematics, board view or anything related to ID these 2 resistors.
                            If someone has this board, could you please tell me the values of these 2 resistors?
                            I hate to see this board be unusable due to something so minor....
                            Thanks...
                            02-14-2025, 10:36 AM
