need to find RESISTOR values of mising LA-E831P
  • madushanka 1234
    • Apr 2019
    • 68
    • sri lanka
    need to find mising parts LA-E831P
    need to find values of this marked resistors...
    another shop mixed this marked 5 resistors...
    please check 3rd photo
    (rt3661b section/puz1)
    thank you
  • skdsp
    Need help identifying resistor values near BIOS chip on ASUS Zephyrus G14 GA402XV
    by skdsp
    I purchased a laptop that the previous user had tried to remove and replace a BIOS chip using a soldering iron not knowing that there is a ground pad under the 25R256JWEQ chip. In that process he damaged the BIOS chip and 3 of the resistors near the IO3, CLK, and IO0 pins. I have programmed a spare 25R256JWEQ chip using a CH341A programmer but not sure what values those resistors should be. If anyone has a boardview of this area and can provide those values that would be very useful for me.
    Attached is the photo.
    Thank you!
    09-27-2025, 09:05 PM
  • vladprogressive
    HELP to find out the value of the resistor HP Elitebook 840 G10
    by vladprogressive
    Hello everyone, please help me find out the value of this resistor in the photo. Unfortunately, it flew away during desoldering, and pc don't power on without.
    It is located next to the EC BIOS on the Bottom of the motherboard Hp Elitebook 840 G10
    You can measure it directly with tester
    I can't find schematic and boardview for this laptop 😓
    Thank you!
    07-25-2024, 10:29 AM
  • Kobok
    Different (lower) resistor values on PCB?
    by Kobok
    Dear Alls,
    For sure it id a stupid question, but help me to understand. I am in a Dell 2007WFP revitalizing project - searching reason why not starting. Some resistors needed to replaced is is obvious. When I have soldered some resistors the measured (with multimeter) values were sometimes rather different written on them. I supposed these are wrong units so I desoldered and made a checking measurement and voilá the values is the same is written on. This happens only in case of a few resistors, most have the same values (+/- 10%) are written on it. "strange" SMD resistors =>103...
    09-19-2022, 07:30 AM
  • Crystaleyes
    Calculating resistor values in parallel with Caps
    by Crystaleyes
    Hi all.
    I recently picked up a dead car amplifier from the flea market, with the intention of learning some more in the area of audio repair.
    It has a stereo output with an added mono woofer output. The stereo channels are on one board, whilst the woofer section is on a separate board. There are also three large (ish) transformers.
    Apart from the fact that it was seriously dirty inside, it seems to be essentially complete with the only clearly damaged component being a toasted 1/4 watt resistor on the woofer board and it is this which I am wondering...
    05-21-2023, 07:35 PM
  • mikey5791
    by mikey5791
    Hi to all forum members,
    12-26-2024, 04:55 AM
