Trouble finding an NEC IC
  • lethbrp
    • Apr 2023
    • 15
    • United Kingdom
    Guys,
    Can anyone help me identify this IC, it's connected to a thermocouple on a heater controller. I'm trying to find where I can get a replacement and a data sheet. I believe it's from NEC, but googling has drawn a blank after that.
    Best regards
    Peter
  • jiroy
    • Jun 2016
    • 2416
    • Lebanon
    Re: Trouble finding an IC
    Whenever you see a NEC integrated circuit and/or 90% of their products , you have to add the prefix microp or UP or µP ..
    https://www.alibaba.com/product-deta...515311714.html
    • lethbrp
      • Apr 2023
      • 15
      • United Kingdom
      Thank you. I've managed to order a few from Aliexpress. Hopefully, these will workout. Finding a data sheet is my next challenge for this chip.
      • jiroy
        • Jun 2016
        • 2416
        • Lebanon
        Re: Trouble finding an NEC IC
        Welcome lethbrp . NEC merged with Renesas , and most of specific NEC components go back to 1983-88 , so it's very tricky and difficult to find their datasheets .
        I'll try my best anyway .
        • hasefroch
          • Apr 2013
          • 42
          • Argentina
          Don't ask me why, but seeing the picture of your board the very first thing to pass for my mind was that your mistery chip was the good old CD4052 in package SOT-16. Back in the day, these were used as dual analog quad input selector in audio equipment.
          Could be way off the mark, but still... attached the datasheet so you can check if it does make sense in your circuit.
          Hope this helps.
          • redwire
            • 3912
            +1
            It looks like a CD4052 and you can see the 3 resistors it switches in/out.
            I don't see NEC markings and it's not a MCU if you follow the traces.
            • jiroy
              • Jun 2016
              • 2416
              • Lebanon
              Dudes , NEC was always a leader in Electronic components , and most of the Japanese companies took cross-references from its designs . I gave the man the original piece , not cross-references , that may or may not be compatible in lot of specific details . The suffix G is very important here , so don't confuse people ...
              • CapLeaker
                Leaking Member
                • 8344
                CD4052 is getting my vote too.
                • jiroy
                  • Jun 2016
                  • 2416
                  • Lebanon
                  It's not a matter of votes here , Capleaker .. The pictures facts speak enough ..
                  If I wanted , I could put the whole cross references catalogues of NEC , but that could take like 350 mb of catalogues ...
                  • PeteS in CA
                    • Aug 2005
                    • 3583
                    • USA, Unsure of Planet
                    Hope this helps.
                    The IC next to it is an OP07 op amp, i.e. analog. Your guess seems supported by the components around the IC in question. Ancient 4000 series CMOS is an example of things that work too well to go out of use. The OP07 has been around for quite a while too.
                    PeteS in CA
