I Need help finding this resisteor for a Rog Ally Z1 extreme. I cannot find one anywhere. RES 20m OHM 1W (0612) 1%//CYNTEC/RLM1632W-6F-R020-FNH-50 PRS8901
Rog Ally Z1 extreme, Need help finding a resistor
by Agx03This is found between the usb-c port and processor of a Asus ROG Ally Z1 Extreme. I cannot find it anywhere on google. Please help me identify....
by jinu_jHi
4. D930 - Shorted Schottkey Diode...-
by mikey5791Hi to all forum members,
Initially i replace the two burned resistors near my marked red arrow to 200 ohm resistor... -
by ongobongoHello,
I'm fighting with an rog ally that i bought broken and which will not start. I found that the ec chip was shorting out so i replaced it with a new and empty one, short's gone and values look good. unfortunately, the ec chip doesn't reprogramm itself although - according to experience from others I've checked with - it should rewrite itself. WHen i attach power, both ec-chip and bios get power supply. to dig further i decided to read bios, maybe there is some corruption going on in there. Bios chip is a Winbond 74m25jweiq, neoprogrammer/ch314b identifies it as W25Q256JW and reads it...-
Channel: BIOS Requests ONLY!
I am curious if a 0402 resistor could go from 43 ohm to 0. In electronics class and my experience a resistor can degrade and gain resistance all the way up to not being able to conduct at all. I have never heard of a resistor decreasing in resistance and becoming 0 ohm or a dead short… that's not the direction they fail… or so I thought.
I was attempting to remove a wson8 chip on an iMac motherboard and it required a lot of heat, on one side of the chip were 3 0402 resistors that were very close. I popped the chip out unintentionally out of the tweezers and sent those resistors... - Loading...
