Trouble finding an NEC IC
  • lethbrp
    • Apr 2023
    • 15
    • United Kingdom
    Guys,
    Can anyone help me identify this IC, it's connected to a thermocouple on a heater controller. I'm trying to find where I can get a replacement and a data sheet. I believe it's from NEC, but googling has drawn a blank after that.
    Best regards
    Peter
  • jiroy
    • Jun 2016
    • 2416
    • Lebanon
    Re: Trouble finding an IC
    Whenever you see a NEC integrated circuit and/or 90% of their products , you have to add the prefix microp or UP or µP ..
    https://www.alibaba.com/product-deta...515311714.html
    • lethbrp
      • Apr 2023
      • 15
      • United Kingdom
      Thank you. I've managed to order a few from Aliexpress. Hopefully, these will workout. Finding a data sheet is my next challenge for this chip.
      • jiroy
        • Jun 2016
        • 2416
        • Lebanon
        Re: Trouble finding an NEC IC
        Welcome lethbrp . NEC merged with Renesas , and most of specific NEC components go back to 1983-88 , so it's very tricky and difficult to find their datasheets .
        I'll try my best anyway .
        • hasefroch
          • Apr 2013
          • 42
          • Argentina
          Don't ask me why, but seeing the picture of your board the very first thing to pass for my mind was that your mistery chip was the good old CD4052 in package SOT-16. Back in the day, these were used as dual analog quad input selector in audio equipment.
          Could be way off the mark, but still... attached the datasheet so you can check if it does make sense in your circuit.
          Hope this helps.
          • redwire
            • 3902
            +1
            It looks like a CD4052 and you can see the 3 resistors it switches in/out.
            I don't see NEC markings and it's not a MCU if you follow the traces.
            • jiroy
              • Jun 2016
              • 2416
              • Lebanon
              Dudes , NEC was always a leader in Electronic components , and most of the Japanese companies took cross-references from its designs . I gave the man the original piece , not cross-references , that may or may not be compatible in lot of specific details . The suffix G is very important here , so don't confuse people ...
              • CapLeaker
                Leaking Member
                • 8081
                CD4052 is getting my vote too.
                • jiroy
                  • Jun 2016
                  • 2416
                  • Lebanon
                  It's not a matter of votes here , Capleaker .. The pictures facts speak enough ..
                  If I wanted , I could put the whole cross references catalogues of NEC , but that could take like 350 mb of catalogues ...
                  • PeteS in CA
                    • Aug 2005
                    • 3578
                    • USA, Unsure of Planet
                    Hope this helps.
                    The IC next to it is an OP07 op amp, i.e. analog. Your guess seems supported by the components around the IC in question. Ancient 4000 series CMOS is an example of things that work too well to go out of use. The OP07 has been around for quite a while too.
                    PeteS in CA
                    • lostone
                      Looking for help with a Viewsonic VP230mb where the backlight comes on only momentarily
                      by lostone
                      Hello, I came here after finding some similar questions asked on other monitors and hope someone here can help me get an ancient Viewsonic VP230mp (23" 4:3 LCD) back to working condition.
                      First a little background, I have a background in computer and electrical engineering, and I'm smart enough to know I know nothing about LCD displays and how they work. For this topic I'm as green as they come.
                      When the display is turned on the viewsonic logo displays in the uppper left for 2 seconds then the screen goes black, the power LED is green (on) and when a computer is connected...
                      05-19-2024, 11:40 AM
                    • Lee M.
                      LG 55LN5710 backlight diffuser sheet order
                      by Lee M.
                      Hello all, new member here. I replaced the LED strips and found that the BL can be turned on with the TCON board and LCD panel disconnected. So new LED strips are working fine. Now the problem. There are 3 diffuser sheets on this set. One sheet is thicker than the others and I know it goes in first next to the LED strips. But one side of this sheet has a rougher texture than the other side. Does the rough side go up or down? The 2 thinner sheets have tabs that will only allow them to be installed one way so that's good. One sheet is what I would call plain translucent. The other sheet is whiter...
                      11-29-2021, 07:52 PM
                    • lfhlaw
                      60LN5600 white reflective sheet
                      by lfhlaw
                      So I had to replace the LED lights on this TV and that worked out nicely. But the White reflector sheet that helps to diffuse the led lights evenly was glued into the back chassis which had to be removed to replace the LEDs.
                      Placing the white reflector sheet caused it to not sit evenly - causing weird diffusing when TV was all put together. Picture is still decent, but now there are dark and light spots due to the white reflector sheet not sitting against the back chassis.
                      Anyone have thoughts on replacement white reflector? or do I just scavenge broken TVs for...
                      05-23-2022, 07:14 PM
                    • Spork Schivago
                      Trouble finding telephone patch panel.
                      by Spork Schivago
                      Hi!
                      I'm looking and having trouble finding a patch panel for a PSTN telephone line. I tried using a regular cat 6 patch panel and just daisy chaining every port together, but that didn't work so well.
                      I've found patch panels that are made for ISDN, but I don't have an ISDN line and probably never will. Eventually, we'll switch to VoIP, but that's still a ways away.
                      Right now, I'm just looking for a patch panel where I can run in the incoming PSTN line to and have it distributed to all the ports (hopefully, at least 48 ports), and then run my cat 5e line...
                      11-24-2018, 09:38 PM
                    • jimbofz
                      just a quick question do all qled leds appear blue when fault finding ?
                      by jimbofz
                      i have replaced many leds strips that have changed blue when they are worn
                      and the new replacements are perfect white
                      but when fault finding do quantum leds always look blue?
                      08-28-2024, 06:51 AM
