Any recommended thermal epoxy?
  • evilkitty
    • Nov 2017
    • 299
    What is something that is decent for gluing a heat sink to a IC's package (vram chip in this case)
    by decent i mean a good price/performance ratio, not extremely expensive or horrible performance
    • Jul 2011
    • 6057
    Re: Any recommended thermal epoxy?
    This is a good question I am interested in the possible answers to this question myself
    • diif
      • Feb 2014
      • 6978
      • England
      You don't want to use epoxy, you want something with some flex.
      Something like this https://www.aliexpress.com/item/1005004966102870.html or a piece of the double sided thermal tape used on LED strips.
        • 31139
        thermal tape is shit,
        the metal/ceramic loaded rtv from Tian-Mu is good though.
        • ChaosLegionnaire
          HC Overclocker
          • Jul 2012
          • 3264
          • Singapore
          thermal tape is pretty much the standard method of attaching ramsinks to vram. i use 3m 8810, 8815 or 9448A thermal tape. sticks well and doesnt fall off. the secret to getting thermal tape to stick well is to make sure the surface is clean and free from oil or other residue like dust. articlean or ronsonol/zippo lighter fluid then ipa to clean the die and heatsink surface before attaching the tape works wonders.
          i think epoxy may crack the die due to flex issues like diff said.
            • 31139
            zinc loaded epoxy is very expensive - but it doesnt crack
            the problem with the tape is poor thermal transfer.
            there was a vid on YT years ago where they compared various tapes, glues and squishy pads.
            • evilkitty
              • Nov 2017
              • 299
              https://www.ebay.com/itm/234485591632
              is this stuff any good?
              looking for something i can get is less than 2 weeks (preferably less than 1)
                master hoarder
                • May 2008
                • 12175
                ^ What he said.
                Yes, but VRAM chips have pretty low thermal output, so even a relatively "high" thermal resistance of thermal tape is good enough. After all, the epoxy casing on VRAMs, MOSFETs, and similar ICs is not great at conducting heat as well. In fact, most of the cooling on RAM chips is through their BGA to the PCB underneath. Of course, if the PCB doesn't have enough surface area, then that's when add-on heatsinks become helpful or necessary.
                BTW, I have some Arctic Silver thermal epoxy, and that stuff goes hard as a rock once it dries. I picked up a laptop on Craigslist a few years back, where the owner used this stuff on the CPU heatsink and you cannot separate the two off - not even with a big screwdriver prying between the two. I think some Radeon 7500 and 9000 video cards also used this or something similar, because I cannot separate the heatsinks on those from the GPU chips. There are no mounting/securing pins on those heatsinks, so I'm not surprised ATI did that. Still, it sucks once the fan fails, as the 40 mm fan was custom-made for the heatsink.
                No idea, but I always wondered myself. It's a "one part" glue, so I wonder how strong it would be. In contrast, the Arctic thermal epoxy is a two-part mix like a real epoxy (well, it is a real epoxy, AFAIK) and holds like one too.
                • eccerr0r
                  Solder Sloth
                  • Nov 2012
                  • 8701
                  Cyanoacrylate glues are 1-part ... so who knows...?
                    • 31139
                    cyanocrylate evaporates onto everything including your eyes when it gets hot - dont use it.
                    the heatsink bandage or whatever they are calling it is usually RTV with ceramic powder suspended in it to increase the thermal transfer.
                    i use that type of stuff on flashlights to mount the led "star" to the aluminium body
                    • evilkitty
                      • Nov 2017
                      • 299
                      The tube of stuff that came with my arctic mono plus was a single tube and the stuff is white, there was no branding on the tube itself
                      if you get the stuff a bit below freezing you can USUALLY break it off without ripping ICs off the PCB, dried stripes if you scrape them off are flexible
                      maybe this is the same stuff? https://www.amazon.com/dp/B072MSXHJD
                      • Gcnewbie
                        Dell Latitude 5570 Ambient thermal sensor reading -127 Degrees C
                        by Gcnewbie
                        Forgive me this is my first request for help on this forum, so if i've screwed up or not followed the rules i should have i apologise profusely.
                        I have a Dell Latitude 5570 that was randomly shutting down, on further investigation i found that the machine had been shutting down due to thermal events as noted by windows event viewer.
                        My investigations lead me to the dell diagnostics screen, where i found that there were two sensors out of range which had been causing the shutdowns, one of which was the GPU thermal sensor and the other the ambient sensor.
                        I opened the...
                        03-29-2024, 06:55 AM
                      • Veyron7887
                        Laptop overheating after replacement thermal paste
                        by Veyron7887
                        Hi. I have Asus X55C laptop from year 2013. It has i3-2328M CPU. I replaced stock thermal paste with high quality thermal paste. Before thermal paste replacement, I measured CPU temperature Around 65-70 degrees Celcius with stock thermal paste. If after the replace thermal paste, I measured CPU temperature around 80-84 degrees Celcius and fan don't stop when system is idle. I replaced the thermal paste several times but still did not change. Where is the problem?
                        11-24-2024, 05:08 AM
                        Mounting and Handling Guidelines for TO220 TO220F TO247 Cases / Packages
                        The TO220, TO220F and TO247 are the popular packages for power devices because of their versatility and ability to dissipate moderate amounts of heat. This application note describes the basic guidelines for handling power MOSFETs in TO220, TO220 and TO247 packages shown in Figure 1. Please note that only mechanical and soldering guidelines are covered here. Additional precautions are required for isolating high voltage rated devices to meet safety regulations.
                        Securing a good thermal interface between...
                        10-07-2024, 04:35 AM
                      • caspian
                        Can thermal paste cause corrosion?
                        by caspian
                        Dear members,
                        I have got an ordinary gray thermal paste that has no name/model on the box.
                        I put some of this thermal paste on a 128-pin QFP IC. A bit of this thermal paste was put on pins of the IC.
                        I tried to clean the pins by thinner but the thermal paste cannot be cleaned from the pins properly. because the pins are tiny and the thermal paste is stuck between them.
                        Is it possible that the thermal paste damages pins of the IC in long term by creating corrosion or something?
                        Is it safe to leave the thermal paste on the pins?
                        I guess the thermal paste...
                        06-19-2020, 10:47 AM
                      • gurj1979
                        MSI GP62MVR-7RF - weird fan / thermal issue
                        by gurj1979
                        Hey guys, I need help with my personal MSI GP62MVR-7RF. Annoying fan / thermal issue.
                        Machine Idle. Fan will spin medium speed for 4 seconds, then off for 1 second. Repeat forever.
                        CPU and GPU are cold. No load, just sitting doing nothing.
                        It's clean inside, nothing blocked. New MX4 paste.
                        Updated BIOS, EC, and VBIOS but nothing's helped.
                        Schematic shows 2 thermal resistors, but they're OK.
                        All thermal signals are good, inc PCH.
                        Has anyone ever come across this ? Any idea what to do ?
                        Could it be a faulty CPU / PCH / KBC ? I REALLY don't want...
                        09-16-2024, 02:14 PM
