Honton HT-1212 help
  • livo
    • Dec 2017
    • 9
    • United Kingdom
    Honton HT-1212 help
    Hi, looking for some help with a Honton HT-1212 I have bought if possible, I bought it off eBay as faulty due to the last owner messing with the settings so it will would no longer work (I have tried a Rex C100 from another machine of mine and it works with this controller), It has a Rex-C10 PID controller fitted but I am unable to find the correct manual for this controller, I can find a manual that says it is for the Rex C10 as well as the Rex C100 etc but the setting names of some of the settings are different the first 2 settings on my Rex-C10 are HP and LP, does anyone have the correct manual or the same machine with the Rex C-10 controller that could look at the settings and let me know what they should be. Thanks for any help you may be able to give.
  • diif
    • Feb 2014
    • 6978
    • England
    Re: Honton HT-1212 help
    I'm guessing the instructions are for the genuine PID controller and you have a clone hence the reason they don't align. The clones have features/settings missing from the original.
    I have a 2020 but it uses a different controller.
    • R_J
      • 9588
      Does this help? or do you already have this, if is the REX-C10 series instruction manual
      • livo
        • Dec 2017
        • 9
        • United Kingdom
        Hi, yes I have seen that ins manual but the setting are still different on mine but thanks for the help.
        The settings I have on mine below with what the settings do that I have been able to work out,
        The model is RKC REX-C10FK02-M*EN
        Setting Range Explain
        HP -999 to +999
        LP -999 to +999
        C -100 to +100 sensor calibration
        OH -999 to +999
        P 0 to 999 keeps going round if I keep button pressed
        d 0 to 999
        r 1 - 200
        AR 0-1 auto tune
        LOk 0-999 lock
        • livo
          • Dec 2017
          • 9
          • United Kingdom
          So I managed to sort it, I played with the settings till I got it working but it was still over shoot the temp till I found a video on you tube which I had not seen before showing their settings on a Scotle ir 6000 which had the same as mine. So I copied them to my controller and it is now working a treat.
          in case anyone needs them they are
          HP 10
          LP 10
          C 0
          OH 300
          P10
          I or backwards C 130
          d 30
          r 02
          Ar 0
          LoK 000
          • R_J
            • 9588
            I see you have it working, I found this manual for a Bird lucky kit 777, that uses the rex- c10, Here is the manual and page 16 has a bit of an explanation of 3 parameters. Maybe it will help?
            • livo
              • Dec 2017
              • 9
              • United Kingdom
              Thanks for that I will take a look
              • master3112
                ASUS ROG Strix- G513IH-HN008, G513-6050A3249301- MB-A04 (A4) damaged Embedded Controller
                by master3112
                I have an ASUS ROG Strix- G513IH-HN008, motherboard G513-6050A3249301- MB-A04 (A4)
                When I received the device, the device has no function. After an investigation, I found that the PWM CONTROLLER RT6575B (U6100) is getting warm and there is a short circuit at the 3V3 output. This normally supplies 3V3 for the embedded controller IT5571E-128 (U301). When measuring and analyzing with a thermal imaging camera, I found that some components are damaged: SLG4E42553VTR (U8500), IT5571E-128 (U301), LAN RTL8111H (U450), LOGIC 74LVC1G08GW (U1900), RT6575B (U6100) All these components are on...
                10-29-2024, 09:32 PM
              • Ayrtec
                Honton ICS-5630 BGA Machine Users Manual
                by Ayrtec
                Hi I am currently seeking help to find a copy of this operators manual for a Honton ICS-5630 Model BGA Machine , Please anyone out there that can help PLEASE PLEASE PLEASE.
                05-15-2022, 09:50 AM
              • ronnygracias
                Help with freemotion incline trainer with controller comm error
                by ronnygracias
                The treadmill was working fine, one day the belt snapped and after checking the unit I also noticed that the display is now showing the Controller comm error. So I opened it up and the treadmill had two boards. One is a power supply board and the other is the motor controller. I noticed there was a mouse nest, so I took power supply board out, cleaned it up, replaced the big capacitor and that did nothing. Then I took apart the motor controller and cleaned that up, and when I plugged it in, it started right up. I thought I fixed it. But when the belt arrived, I installed it and tried to power...
                11-04-2024, 01:32 PM
              • madan1
                Cisco catalyst 2960c POE
                by madan1
                Hello everyone.
                Got a catalyst 2960 from the usual scrapyard - ebay.
                It is stuck in bootloop and the power supply is missing the 3.3v rail. (+12V, -53V, +3.3V)
                Some green moisture crystallization on mainboard, which cleared very well with IPA and visually there is nothing rusted or gone.
                Still working on the PSU to get the 3.3v rail back (waiting for parts), but for now I'm using an external buck converter board hooked up to the 12V rail ( by the way, the switch seems to be working with only 12V ).
                The switch fails to boot due to the following POST error:...
                12-19-2024, 09:34 AM
              • RetroComputingGrotto
                New Toy UNI-T UTi260B - What Settings?
                by RetroComputingGrotto
                I've literally just received in the post a UNI-T UTi260B (it's currently on charge).
                After quickly scanning the user manual I see there are all sorts of configurable settings (Measurement settings, Palette settings, Point temperature settings and Image Mode). As this is my first Thermal Imaging Camera I have no idea what all these settings are nor if I need to change/configure any of them.
                I intend/hope to use this to help me diagnose issues with laptop motherboards so should I just leave the settings as the default or is there someone out there with a UNI-T thermal...
                09-02-2025, 08:36 AM
