Cisco catalyst 2960c POE
  • madan1
    • Nov 2016
    • 697
    Hello everyone.
    Got a catalyst 2960 from the usual scrapyard - ebay.
    It is stuck in bootloop and the power supply is missing the 3.3v rail. (+12V, -53V, +3.3V)
    Some green moisture crystallization on mainboard, which cleared very well with IPA and visually there is nothing rusted or gone.
    Still working on the PSU to get the 3.3v rail back (waiting for parts), but for now I'm using an external buck converter board hooked up to the 12V rail ( by the way, the switch seems to be working with only 12V ).
    The switch fails to boot due to the following POST error:
    POST: PortASIC Port Loopback Tests : Begin
    POST: Failed PortMacLoopback Packet Receive asic_index 0 port_hardware_index 1
    POST: Failed PortPhyLoopback Packet Test asic_index 0 port_hardware_index 1
    POST: PortASIC Port Loopback Tests : End, Status Failed
    Error: ASIC/PHY POST failed. Cannot continue.
    According to the Internet, the ASIC is dead and the switch is just a paperweight.
    After forced boot with "-skip_post", the switch boots fine, all RJ45 ports (8 fastEth. + 2 giga.) work fine. I can not test the 2 SFP ports. The POE also seems to be working fine.
    In brief - the switch does switch and provide POE so basically all I need from it.
    So any ideas on how to proceed?
    If the switch switches is it really possible that the ASIC is dead (like the switching to be going on PHY level without any ASIC input/control)?
    Any ideas what asic_index 0 and port_hardware_index 1 actually mean? Like asic_index 0 is the connection to let's say the ethernet controller (in this case a single broadcom BCM5248)? Is port_hardware_index X the ethernet port X?
    I'm new to cisco IOS and just getting to know the basics. Is there a way to force it to boot every time with -skip_post?
    Here are the boot settings:
    switch#show boot
    BOOT path-list : flash:c2960c405-universalk9-mz.152-7.E8.bin
    Config file : flash:/config.text
    Private Config file : flash:/private-config.text
    Enable Break : yes
    Manual Boot : no
    Allow Dev Key : yes
    HELPER path-list :
    Auto upgrade : yes
    Auto upgrade path :
    NVRAM/Config file
    buffer size: 65536
    Timeout for Config
    Download: 0 seconds
    Config Download
    via DHCP: disabled (next boot: disabled)
    Any help is appreciated.
    Thank is advance.
    P.S. OK, I think I found the faulty port - It is one of the 2 gigabit ports (I was more focused on testing the ports with POE and almost skipped the gigabit ports by just checking if the IOS detects the connection).
    Here is what the IOS shows on that port
    "Gi0/2 connected 1 a-full a-1000 Not Present"
    while the correct status is
    "Gi0/1 connected 1 a-full a-100 10/100/1000BaseTX".
    When no cable is connected:
    Gi0/1 notconnect 1 auto auto Not Present
    Gi0/2 notconnect 1 auto auto Not Present
    There seems to be some kind of a transfer on that port (the LEDs are blinking on both sides of the cable), but eventually no connection is established.
    Each gigabit port (1 rj45+1 SFP) is controlled by a dedicated Marvell® Alaska® 88E1112. So I guess now I have to find out if the controller is dead...
    By the way - any idea how the loopback test works? Is it just checking the connection to the controller or testing if the TX RX lines are fine to the magnet/transformer or even the port itself?
    • 31139
    i would check the current transformers for open windings.
    they are the first thing to get hit by EMP from a storm.
    also you can have a bad transformer cause a gigabit connection to run at 100meg or 10meg because 10/100 uses 2 pairs and gigabit uses all 4 pairs
    • privato89
      Nintendo Switch Oled HEG-001: Second-Stage Boot Failure
      by privato89
      I'm facing an issue with a HEG-001 motherboard that is unable to complete the Second-Stage Boot. I'd like to start directly with my conclusion, which is the decision to replace the MAX77621AEWI chip, and understand if it could be a correct evaluation.
      Before I dive into the process that led me to this decision, I want to mention that I have a fully equipped lab where I can perform any kind of tests.
      Let's begin:
      Following some guides online, I tried to understand how the Boot phase of the Nintendo Switch works, and what are the...
      03-26-2024, 06:37 AM
    • Luke Anders
      Lenovo Legion 5 (15ACH6H/17ACH6H) - Does not boot into any OS
      by Luke Anders
      A few details about the laptop itself:
      Name: Lenovo Legion 5
      Model: 15ACH6H (according to its back cover details) / 17ACH6H (according to the BIOS Menu)
      BIOS Version: GKCN60WW
      EC Version: GKEC65WW
      Serial Number: PF39AQ7Z
      Board Model: NM-D562 Rev 3.0
      RAM: 16GB Installed, DDR4 (brand new)
      NVME: 500GB NVME drive (brand new, installed Windows 10 onto it for testing purposes and tested on another laptop (a dell XPS) works perfectly fine and boots in)
      I bought this laptop recently from eBay as a faulty device....
      10-12-2024, 05:13 AM
    • hinisa
      Xiaomi router freezes at boot after re-capping
      by hinisa
      I'm using Xiaomi Router 4A gigabit edition as wireless repeater. It worked fine for 2 years or so, but last week, wireless started to disappear.
      When I unplug/replug the power, it was working fine for a day/half a day or so until it freezes again.
      After testing with different power supply adapters and concluding it wasn't the issue I finally opened the case and this was the situation:
      Anyway I proceed to clean up the mess and replace all caps but unfortunately it made the situation worse. Now router can't even boot, either it freezes during...
      07-08-2023, 05:58 AM
    • NolesFan
      Samsung un82ru88000f - Boot loop sort of but can correct with taping of LVDS ribbon
      by NolesFan
      Hello all... TV started boot looping. Opened the back panel and tried to isolate the problem. Just PSB no boot loop. PSB and MB no boot loop. Plug in the LVDS from panel to MB and boot looping starts up. It doesnt matter of order that I plug the LVDS ribbons back in, only 1 and no boot loop but as soon as 2nd one plugs in boot looping. I then noticed a flicker on the screen when I was closing the clip on the harness to the LVDS. Shut the lights off so I can see better, and I noticed as i slowly close it, I will get a picture, but as soon as it clips in, I lose picture and booting happens. So I...
      10-24-2024, 06:36 PM
    • praveenramavath
      Majority PETERHOUSE GRADUATE Internet Radio (Auna Silver Star) - Stuck at boot "Welcome" Screen
      by praveenramavath
      Hello All,
      I have an issue with my Majority PETERHOUSE GRADUATE Internet Radio, it keeps rebooting at the boot logo Welcome screen. I have an another forum active in other website but due to lack of response I am posting the same here. I am positing a link below that has pictures including all the troubleshooting I have tried, appreciate if someone can take a look and give me any suggestions.
      https://www.hifivision.com/threads/m...-screen.98243/
      Troubleshooting Summary: Majority Internet Radio - Flash Chip
      04-26-2025, 09:08 AM
