Radio Shack 2200813 29 range DVM
  • Schoenradt
    • Jan 2021
    • 39
    • US
    Does anyone have any information for a Radio Shack 2200813 meter. I need to know what value R14 was. Mine is measuring 90 ohms. My meter did have a blown fuse F1 rated at 250V @ 500mA. Symptoms are meter doesn't measure DC mA correctly and beeps above 40 mA range if it is even giving proper current measurements. Below I have included some pictures and a macro shot of R14 on the pc board.
  • eccerr0r
    Solder Sloth
    • Nov 2012
    • 8703
    Re: Radio Shack 2200813 29 range DVM
    Does the meter otherwise work on voltage, resistance modes?
    Is that 90 ohms measured out of circuit?
    What does the meter read if you pass 20mA in it with that 90 ohm resistor in it?
    Without any additional information or schematic my guess is 10 ohms.
      • 31260
      show the whole board so we can see the chips
      • Schoenradt
        • Jan 2021
        • 39
        • US
        Yes the other ranges seem to work. I don't see any way to zero the ohms out as the meter reads about 46.7 ohms when leads are shorted. I'll send some more pictures of the main motherboard and some LCD readings.
        • Schoenradt
          • Jan 2021
          • 39
          • US
          I have included photos of the main board and some tests using a known good meter and it isn't good.
          • Schoenradt
            • Jan 2021
            • 39
            • US
            Adding complete picture of main board component side.
            • retiredcaps
              • Apr 2010
              • 9271
              I don't see any way to ero the ohms out as the meter reads about 46.7 ohms when leads are shorted.
              When you have an offset like that with the probes shorted, I would try the simple things first.
              1. Try a fresh batteries first. Some meters give incorrect readings before they show a low battery indicator (if they even have one).
              2. Give the entire PCB a good IPA clean with a clean toothbrush and let it dry overnight. Any unseen dirt, debris to the naked eye can affect the readings and give non zero ohms readings when the probes are shorted.
              --- begin sig file ---
              --- end sig file ---
              • redwire
                • Dec 2010
                • 3912
                Strange it has only one switch position for the mA/A function, so the shunt R14 is very likely 1R. 99R is typically used for a uA function.
                RAA1, RAA2 give 10R but there's no switch position to use them? some of the resistors appear to be loads for the battery test function.
                It looks like earlier Dream Tech Taiwan DMM IC used and a COB LCD driver.
                DTL02001 but I could not find a datasheet. Very similar to the ubiquitous DTM0660L. The multimeter's right part number is Radio Shack 22-813 similar to 22-812 etc.
                I would check voltage regulator U3 is 3.0-3.6V output across C7. You should get half its voltage between BATT(-) and input jack COM.
                The voltage reference is across C2 and I believe 1.2V
                Maybe measure these in the DCV function to see if the IC has hope.
                  • Jul 2011
                  • 6070
                  It could be the picture it self but I see some soldering joints that do not look very good I would check each and every soldering joint under a magnifying glass and reflow anything that does not look good
                  One other thing to be aware of is that meter leads have an issue with bad terminal connection issues and the meter leads that you get Radio Shack had these issues if you used the leads a lot
                  Or the wire that is used to make these meter leads are very poor quality and is corroding in the meter tip soldering joint or on the barrel end or both ends and will be either green or black in color on the wire strands bundle
                  Or the connectors pins on the barrel become loose in the mating connector spread them out a little bit and reinstall them and see if this makes any difference or not
                  However if the swivel is very loose and has play in it then this could also cause you problems as well it should be locked in place or if it rotates it should give you resistance to to move if not replace the barrel end with a new one
                  I have also seen where the barrel connectors corrosion inside the connector it self if that is case you can improve the connection by taking a piece of sandpaper roll tightly up that fits in the connector space and rotate it back and forth but note that if you have to do this then you are going to have this issue all the time
                  One more thing to be aware of is that if you have used this meter a lot the switch connections to the board can have corrosion on the traces or on the connection metal tabs that meets the board traces or not enough tension to the board end you can bend them outward however be very careful doing this because if you do to much of this can break them
                  I have a meter that has also done this as well but then some other failure issues happen to this meter and I stopped using it
                  I have 4 1/2 digit meter that has this issue can make you go mad because it a nice meter otherwise and it is the same problem with the meter barrel connector that becomes loose fitting in the connector and do not read the voltage or ohms correctly
                  I hope this helps
                  • shelby5041
                    clock radio / radio lifespan?
                    by shelby5041
                    hi
                    ive got a modern digital clock radio approx 15yrs old
                    my question is how long can a clock radio or a simple radio last ss farcas operating hours?
                    since elec components have limited hour lifecspan i would imagine the radio or clock radio would eventually fail.
                    the reason i ask is because i have my clock radio on radio function 24/7 for the past 7 years and its still working fine....i leave the radio on ..never turn off past 7years...thats approx 60000 hours
                    it uses very little power just a few watts i would imagine that may have something...
                    09-14-2024, 03:30 AM
                  • UserXP
                    Vintage SONY Digital Clock Radio ICF-C12W no audio
                    by UserXP
                    Dear all,
                    I have this old radio clock by Sony from the early 80s, I guess. The clock display works, but is dim, the function board appears to be OK - but the radio unit shows no signs of life. It doesn't produce a single noise, crack or anything from either FM or AM band. It's like it doesn't even power up.
                    i opened the radio and it is full of some TRACON gray capacitors. They only have their negative strip printed, voltage and capacitace markings - no series, no temperature marking, nothing else.
                    My question is, do you know of this brand of capacitors and how bad are...
                    07-21-2025, 08:35 AM
                    AE20218 Milliohm Meter Kit, 0.1 Milliohm Resolution, Four Wire Measurements bought one
                    I have been in need of a mega ohm meter for a while but just could not make up my mind to which one I want to buy and this one has a couple of things going for it can also be used on a computer to display a resistance graph plus it is a kit that you put together supposedly the only parts installed are the surface mount components
                    I will probably make a rechargeable battery pack for so it can be used as a portable device and anywhere
                    I kind a wish that it had a higher resistance value higher than 240 ohms at 10 milliamperes on high range but it is what it it
                    On the...
                    03-15-2025, 05:10 PM
                  • praveenramavath
                    Majority PETERHOUSE GRADUATE Internet Radio (Auna Silver Star) - Stuck at boot "Welcome" Screen
                    by praveenramavath
                    Hello All,
                    I have an issue with my Majority PETERHOUSE GRADUATE Internet Radio, it keeps rebooting at the boot logo Welcome screen. I have an another forum active in other website but due to lack of response I am posting the same here. I am positing a link below that has pictures including all the troubleshooting I have tried, appreciate if someone can take a look and give me any suggestions.
                    https://www.hifivision.com/threads/m...-screen.98243/
                    Troubleshooting Summary: Majority Internet Radio - Flash Chip
                    04-26-2025, 09:08 AM
                  • Dannyx
                    Hilti PD30 Laser Range meter Error 276
                    by Dannyx
                    Good day folks.....wow, seems like forever since I posted anything here Still alive and well, thank you I guess you could say I've become more independent and able to work stuff out on my own. This one though goes way over my head and I doubt is fixable, but maybe some bright spark out there has an equally bright idea.
                    So: my Hilti PD30 laser meter quit on me just the other day. It was working fine, I set it down for a while and when I tried using it again it gave me an E276 and wouldn't do anything else. I tried taking out the batteries, all that standard stuff but nothing...
                    07-30-2023, 05:05 AM
