testing equipment
+ More Options
Posts
  • kaniki
    • 514
    testing equipment
    Ok, this probably has already been said but i could not find it. I know the basics now on what a bad cap looks like, how to solder, good vs bad names, etc. but what i am not 100% sure about is how to test and find out if caps are bad that are not visibly bad. I did have a multimeter bad when i got it out after being in the basement for years, it was kinda corroded and could not get the old battery out without breaking it so i ordered a new one. this is what i bought, but just ordered so have to wait a bit f0or it to come in.
    http://cgi.ebay.com/ws/eBayISAPI.dll...E:L:OU:US:1123
    Can you check to see if a cap is bad with one of these and if so then how? is it best to use the ohms settings or soemthing else if so? or is the only way to tell if the cap is good is to buy a ESR meter? and can you use either while the caps are still on the board?
    I did find a place where i can buy a tester that can test in pf nf uf and mf for what i would consider a more reasonable price for what i can afford. here are the 3 that i was looking at:
    http://cgi.ebay.com/DMM-Digital-Mete...item45f1069c42
    http://cgi.ebay.com/Capacitor-Capaci...item4a974c62d4
    http://cgi.ebay.com/A6013L-Capacitor...item3efc72ceab
    If you think that it would be a good investment to buy one and that is the only way to tell if one is bad, which do you think would be the better choice to buy, or are they all crap?
    I dont have a lot of money and do not do a lot with replacing caps so i do not want, nor have the money to put a lot into something a bit pricier like $100. Any explanation or description would be appreciated.
  • aliasdck
    • Sep 2009
    • 100
    Re: testing equipment
    Originally posted by kaniki
    ...but what i am not 100% sure about is how to test and find out if caps are bad that are not visibly bad...
    ...Can you check to see if a cap is bad with one of these and if so then how? is it best to use the ohms settings or soemthing else if so? or is the only way to tell if the cap is good is to buy a ESR meter? and can you use either while the caps are still on the board?
    A capacitance meter can sometimes be used to test if a cap is bad as the capacitance value can drop. However, problematic caps can still show good on a capacitance meter and can still pass the test using an analogue meter on ohms scale.
    An esr meter is the way to go. Its going to be able to tell you more about the condition of a capacitor than any of those meters will.
    An esr meter can be used to test caps in circuit, however, you need to pay attention to what you are metering... for example, when capacitors are in parallel.
    I cannot comment on any of those meters you linked to as I have never used any of them.
    Hope that helps.
    • Radio Fox
      • Jan 2010
      • 281
      As you have already bought a multimeter, I would ignore the first capacitance meter on your shortlist, as it is a multimeter with a capacitance function tacked on. It only measures up to 20uF which isn't high enough for a lot of the power supply capacitors you may need to measure.
      The other 2 have all the same functions, just in a different case. Either should cover the majority of capacitors you will come across.
      As aliasdck says, an ESR meter will be more help as a troubleshooting aid.
      ________________________________________________
      Invisible airwaves crackle with life
      Bright antennae bristle with the energy
      • kaniki
        • 514
        you are correct. I did not realize that that one did not have a mf rating like the others but would have double checked that before i would have.. personally, i was leaning more towards the 3rd or honeytek one. here is what i found so far
        2nd one i can get fron china for about $20 from
        http://www.dealextreme.com/details.dx/sku.27256
        but i have to wait. I can find no reviews that say it is good nor bad or about the quality. If i get it from them, they are on a holiday and it will not ship for at least a week.
        3rd one or honeytek one is from an iso09001 company, i have seen it being sold at companies that sell stuff from brands like dewalt, etc. but that does not mean it is good either (companies that sell good stuff can sell crap too) and basically no good nor bad reviews for it either. this one is also shipped form the US so no long wait time for delivery but is also $31 which is over 50% more in cost too. (found they have a buy it now for $2 less)
        Ill wait a few extra days since i dont need it right now and if no more comments, then i will probably go for the honeytek one.
        • chth96
          by chth96
          03-09-2024, 10:03 PM
        • bauto601
          KDM 480W PSU upgrade succes! (opinions?)
          by bauto601
          Back in 2020 i bought a (2nd hand) compact ATX psu to replace my current one. My PC case only fits very short ATX power supplies so i didn't really have the choice of buying a decent 80Plus unit. The current unit is a modded YoungYear unit that i made a thread about a while ago:
          A "nice" YoungYear unit? - Badcaps
          The "new" unit is a KDM-M6480 480W psu, the 480W number is a typical KDM bullshit claim of course, but the 24A rating on the 12V rail seemed reasonable and the "Active PFC" claim gave me a bit of hope that this was going to be decent-ish....
          12-26-2023, 03:05 PM
        • lmcancu
          LED Strip test points and testing?
          by lmcancu
          Hi is there a guide in this forum on how to test the LED backlight TV strips? I purchased an LED tester on amazon, but I am a bit confused on the test points and how to test the individual LEDs? I took apart a RCA 43" TV Rlded4331b. Please see attached pictures. I understand that all the LEDs are in series, but on these strips I don't see any individual test points for each LED? Any tips or guides?
          Thanks in advance...
          03-20-2023, 07:52 AM
        • ttmi100x
          HANNSG Hi221 -- 2 secs to black feat. CCFL flicker & "burn" marks on power board
          by ttmi100x
          Greetings everyone,
          I have a HANNSG Hi221 monitor that exhibits two seconds to black issues (backlight goes off, display is still on as confirmed by shining a flashlight on it) with some additional oddities...
          The monitor failed on me with a standard "2 seconds to black" some time ago prompting me to initially replace most of the electrolytic capacitors (some of them were bulging/leaking).
          Things kinda sorta worked for a night, then the problem returned along with some flickering and "buzzing" noises.
          Upon closer inspection...
          07-31-2024, 06:36 PM
        • Fritter
          Your most useful test equipment.
          by Fritter
          Hi All,
          For some background, I passed an OND in electronics in the 80's. Life took me elsewhere, and I've finally got around to using it practically. My interest is in vintage electronics.
          My question is, other than a multimeter, what is the most used and useful piece of test equipment ?
          Thanks !
          06-07-2023, 12:23 PM
