Blue ESR Meter "F6" Error
  • vyliam
    • Jan 2010
    • 6
    Hey everyone,
    I have been trying to figure out this error. I have not been able to calibrate the unit, not getting anything from the test resistors. Running the self diagnostics give me the F6 error code. I have at this time de-soldered the components checked the resistors, and verified that everything has been put into place. Re-soldered the components listed under the F6 code. Maybe everyone here might be able to stop a misplaced component or point me to test some thing.
    I have followed the leads on the board and tested with an ohm meter to see if there are any breaks, but non found. I have pictures located on my web site, you can view them here http://www.comshyft.com/ESRMeter/ . The I have the photos split up into two folders for the front and back side of the board.
    I am just stuck at this point and I am trying to avoid the expense of sending it into Anatek. I was working with their tech support, who was stuck on solder whiskers or a bridged lead. After I posted the pictures and sent them a link they jumped to it can be troubleshooted. I figured I would check here with you guys and see what options I may have.
    Thank you in advance.
  • Krankshaft
    • Jan 2007
    • 2328
    Re: Blue ESR Meter "F6" Error
    Did you put the calibration POTs in the right places?
    They are two different values one for the low battery warning and the other for resistance calibration.
    • vyliam
      • Jan 2010
      • 6
      I have both of the POTs in their correct location. The 201 (middle right hand side) and the 103 (middle bottom side), both are in their center position. You should be able to see it in this picture http://www.comshyft.com/ESRMeter/fro...d/PICT0164.JPG.
      • Radio Fox
        • Jan 2010
        • 281
        You have R13 & R30 transposed.
        R13 (100k) = brown black yellow
        R30 (100R) = brown black brown
        ________________________________________________
        Invisible airwaves crackle with life
        Bright antennae bristle with the energy
        • vyliam
          • Jan 2010
          • 6
          Thank you Radio Fox. I switched those resistors, great find, the unit now tests fine with ".8.8". Calibrated now and all is working. Thank you again.
          • Krankshaft
            • Jan 2007
            • 2328
            Resistor problem yet again as I suspected .
            If you have difficulty determining the color bands measure the resistor with a DMM to verify before installation.
            • vyliam
              • Jan 2010
              • 6
              Yes, I did use a DMM . I didn't pay attention to color bands and didn't know that there was a difference between 100R and 100K. But now that its worked out I will pay closer attention in the future. Great learning experience for me. Thanks again everyone.
              • Toasty
                • Jul 2007
                • 4171
                Why is the picture now missing? I wish you would upload to forum for future reference.
                veritas odium parit
                • vyliam
                  • Jan 2010
                  • 6
                  The pictures are still on my site. I can upload to the form if you would like. Oh, the reason for the picture not linking correctly is the security I enabled in CPANEL to prevent bandwidth theft. If you go http://www.comshyft.com/ESRMeter/ you should be able to view all the files I uploaded I don't plan on taking them down anytime soon.
                  Front side of board: http://www.comshyft.com/ESRMeter/fro...%20of%20board/
                  Back side of board: http://www.comshyft.com/ESRMeter/bac...%20of%20board/
                  • vyliam
                    • Jan 2010
                    • 6
                    Missed the time I could edit the previous post. Here are two main photos of the back and front so they can live here. Images were reduced to fit image size, and file size limits.
                    • Bob Parker
                      Technician
                      • Feb 2007
                      • 182
                      Quick message for Radio Fox.... due to various reasons, for many weeks I haven't been looking closely at this forum or the one on the Anatek Corp website until today.
                      THANK YOU enormously for helping people to get their Blue ESR meters working. I really appreciate the effort you're making and your correct diagnoses of their problems. Also thanks to Krankshaft and others who've been making helpful suggestions. All much appreciated!
                      I'll try to pay more attention to these forums from now on.
                      It is a good shrubbery. I like the laurels particularly...
                      • Radio Fox
                        • Jan 2010
                        • 281
                        Hi Bob. Thanks for the above post.
                        No doubt you've been thanked many times over the years, but I think this is the first time you have posted since I became a member. So can I just take the oppertunity to add my thanks for designing such a helpful piece of test gear. Cheers.
                        • Bob Parker
                          Technician
                          • Feb 2007
                          • 182
                          Hi again,
                          I only designed the ESR meter for doing my own repairs back in the 1990s. I'm amazed that it's become so well known in its various forms and I'm very happy that it's useful to you and others who are trying to track down those troublesome electrolytic capacitors.
                          Thanks,
                          Bob
                          • Krankshaft
                            • Jan 2007
                            • 2328
                            For future reference 100R means 100 ohms, 100K (Kiloohms) means 100,000 ohms (one hundred thousand), and 100M (Megaohms) would be 100,000,000 ohms (one hundred million).
                            I love my ESR meter and scooped it up from Anatek right after it went back into production in 07.
                            Saved me alot of work on the first 27" CRT it fixed I tracked down about 20 under 100uf bad caps. No outward signs of failure but their ESR was high and they made the TVs micro go wonky.
                            • xclusiveplayer
                              • 43
                              My meter doesn't zero out like it supposed to when I short the leads together. What may be wrong? Every is correctly in place.
                              • Krankshaft
                                • Jan 2007
                                • 2328
                                It isn't automatic you are pressing the power button after shorting right?
                                • xclusiveplayer
                                  • 43
                                  Works now thanks.
                                  • Krankshaft
                                    • Jan 2007
                                    • 2328
                                    No problem.
                                    When the leads are shorted the power button zeroes the meter when they are apart it's a power button.
                                    • Bob Parker
                                      Technician
                                      • Feb 2007
                                      • 182
                                      Originally posted by Krankshaft
                                      No problem.
                                      That's a good explanation - thanks!
                                      • sds
                                        • Jul 2010
                                        Thank you very much.
                                        • Dannyx
                                          Hilti PD30 Laser Range meter Error 276
                                          by Dannyx
                                          Good day folks.....wow, seems like forever since I posted anything here Still alive and well, thank you I guess you could say I've become more independent and able to work stuff out on my own. This one though goes way over my head and I doubt is fixable, but maybe some bright spark out there has an equally bright idea.
                                          So: my Hilti PD30 laser meter quit on me just the other day. It was working fine, I set it down for a while and when I tried using it again it gave me an E276 and wouldn't do anything else. I tried taking out the batteries, all that standard stuff but nothing...
                                          07-30-2023, 05:05 AM
                                        • Sus256
                                          HISENSE 65E7KQ PRO - no boot
                                          by Sus256
                                          Hi all!
                                          HISENSE 65E7KQ PRO
                                          RSAG7.820.13512 - chassis
                                          MT9618BAATAB - cpu
                                          RSAG7.820.12059 - power
                                          HD650Y3U77 - panel
                                          KLM8G1GETF - emmc
                                          The TV does not turn on, the standby indicator is on. All voltages are present.
                                          Emms is dead. Not readable, not detected.
                                          Replaced emmc.
                                          But with another dump there is no launch
                                          Terminal log
                                          UART
                                          AC_ON
                                          RPMB key is not yet programmed
                                          HASH1_VERSION=0x00000000 64bit
                                          E-B
                                          FDE enabled
                                          layout pattern onebin by SAR7,0...
                                          06-01-2025, 02:11 AM
                                        • sushilachuthan
                                          APC UPS error P13
                                          by sushilachuthan
                                          one of our new (only 4 year old) 1KVA APC UPS stop working and through error P13 contact customer support.
                                          the equipment is out of warranty , upon investigation, we found the inverter board has the fault on the output hybrid relay circuit.
                                          The inverter output relay is parallel by SCR/Triac to enhance the relay performance or other means.
                                          We replaced the SCR with new device,, but the device is not power on as expected.
                                          Further research on the issue found that, the error P13 (event ID 107) is latched on the UPS nvram/MCU and need to clear/reset using a service procedure....
                                          09-26-2025, 09:00 AM
                                        • classicandy
                                          Dell Latitude E7450 "bhtemmcdr.sys" Blue Screen error. Need Help Please
                                          by classicandy
                                          I have this Dell Latitude E7450 with "bhtemmcdr.sys" error that causes a blue screen few seconds after the laptop has booted to the home screen. I have attached an image of the blue screen error it shows.
                                          I need help in fixing it. Thanks...
                                          07-28-2022, 05:10 PM
                                        • amintvn
                                          precision 7730 blue screen error
                                          by amintvn
                                          this laptop when is installing graphic Nvidia driver, gives blue screen error.
                                          i tested version driver ok.
                                          could it be problem with the bios?
                                          motherboard:
                                          dap20 la-f601p rev:1.0
                                          06-08-2023, 03:39 AM
