BGA my balls keep rolling away
  • dicky96
    Sun Seeker
    • Mar 2017
    • 1825
    • Spain
    Hi guys
    So after best part of a year doing other stuff, I'm back to master this BGA reworking, 2nd time lucky I hope
    So I thought the best place to start was with the steps that were giving me problems last time.
    With this type of reballing jig and stencils:
    https://www.aliexpress.com/item/3303...archweb201603_
    What is the best tyoe of flux to use to get the balls to stick to the BGA. Amtech NC559-ASM?
    Once I have applied the balls, how do I melt them without them rolling away? Even with my Hot Air (Quick 861DW) on minimum airflow once the flux liquidizes the balls start floating around.
    I did try last time using this little hot air preheater I have, and putting a square sheet of metal over the hot air vent then using it like a hot plate to put the BGA on top, but I still had trouble with the balls moving, though it was more successful than the Quick 861.
    https://www.aliexpress.com/item/3270...archweb201603_
    Is this due vibration from the heater?
    Is there some way to do this reliably with what I have or do I need to get something like this?
    Cheers
    Follow me on YouTube
    Learn Electronics Repair
  • diif
    • Feb 2014
    • 6978
    • England
    Re: BGA my balls keep rolling away
    There are two types of stencil. Indirect and direct. With direct heat, the balls are held in place with the stencil, hot air is applied and the stencil removed when the balls have melted.
    Indirect heat does not use hot air, it uses a hot plate and as there is no airflow the balls melt in place.
    Yes so thing like that hot plate, or perhaps something much smaller and cheaper like the LED reflow plates.
    • dicky96
      Sun Seeker
      • Mar 2017
      • 1825
      • Spain
      Thanks diif, I remember that now, and the stencils and jig I have are indirect heat yes?
      When you say something cheaper you mean something like this?
      https://www.aliexpress.com/item/4001...archweb201603_
      Or get some direct heat stencils?
      https://www.aliexpress.com/item/4000...archweb201603_
      https://www.aliexpress.com/item/3291...archweb201603_
      Which type are the best/easiest to use or is it a matter one type is better for certain work than others?
      • diif
        • Feb 2014
        • 6978
        • England
        I was thinking even cheaper, although it might need some finer control with a PID controller/thermocouple. https://www.aliexpress.com/item/33057592999.html I've used my larger 20x20cm hotplate as per your first link when reballing as it was what i had on hand, but it's far larger than it needs to be and i wouldn't buy one solely for reballing.
        It's mainly matter of preference I think although when i needed a stencil a year or so ago it was only available in direct heat, with direct heat there is sometimes difficulty of releasing the stencil.
        • dicky96
          Sun Seeker
          • Mar 2017
          • 1825
          • Spain
          OK that is cheap - and with the money saved I can grab some direct heat stencils and have a play with them too - see what works best for me
          I could attach one of my digital thermometers to that plate and switch it off once it gets hot enough to melt the balls - otherwise I wonder how it would work on my 2000VA Variac?
          I saw some videos using solder paste and a plastic spatula with direct heat stencils - I suspect you probably tried that sometime, is that method any good?
          • diif
            • Feb 2014
            • 6978
            • England
            I've seen the paste and stencil method on Apple SMC and memory chips, it's not something I've tried.
            I use one of those cheap hotplates for doing LED replacements, with a cheap thermocouple permanently jammed in, I did fit a PID controller but it didn't work, I should revisit it.
            • dicky96
              Sun Seeker
              • Mar 2017
              • 1825
              • Spain
              I did it
              I used the indirect heat stencil and jig.
              I used the Kada 853B and NC-559-ASM flux applied with a small paint brush
              I used the base off an old el cheapo soldering iron stand, with the springy soldering iron holder removed, and it just fitted exactly over the KADA hot air plate with about 2mm spare each side. I used the little indent where the sponge should go as a tray for my BGA.
              Even with the KADA on the highest setting, I couldn't get the thermocouple to read over 182C, but I noticed around that point all the balls seemed to have aligned fully on the pads and were looking shiny, so I turned off the heater and left the fan running to cool it down - and found that the BGA was reballed.
              Possibly the thermal mass of the soldering iron base was too high for the heater to get it any hotter or maybe it was because the thermocouple was not on the hottest part directly above the hot air. It's possible these are 0.76mm 60:40 lead balls as 183 is the melting point for leaded solder
              Anyway - regardless - I had success the first time round... this time round.... LoL. It's not the biggest BGA in the world but I feel pretty good about it.
                • 31289
                this looks interesting!
                https://www.youtube.com/watch?v=o3vK0fikX80
                • diif
                  • Feb 2014
                  • 6978
                  • England
                  Originally posted by stj
                  Interesting yes, but at £90 it's not that interesting.
                    • 31289
                    lol - i didnt check the price!
                    • dicky96
                      Sun Seeker
                      • Mar 2017
                      • 1825
                      • Spain
                      Out of interest (or anyone else trying this) I think the reason that balancing a metal sheet on top of the hot air pre-heater failed when I tried it before (the balls moved and some joined together) was because I used a very thin piece of metal which was the top from some RF section of an old PCB I was stripping down. This was like very thin tin or something.
                      And I think with such a light piece of metal the vibration from the pre-heater was moving the solder balls. This time I used something fairly hefty, and possibly the pre-heater struggled a little bit with the thermal mass but it definitely worked.
                      Anyway that's my best guess on it - FWIW
                      Rich
                        • 31289
                        you should use something thick to spread the heat evenly - like 5mm aluminium or even copper if you can scavange something.
                        • dellxps15
                          • Feb 2014
                          • 1598
                          • italy
                          sorry for the late reply. with that method u are heating the silicon bga chip part the most and that can cause damage to the bga itself.
                          for reballing u can use direct heat for small bga and it works very well.
                          for large bga i use 90x90 stencil, but before use hot air station i apply flux like always, but this time i use my finger to remove some portion of the flux as it need a very small amount of it otherwise u can have the problem u have described.... balls going anywhere...
                          if u are not satisfied with hot air, u can make a homemade reballing station using cooking hooven modified witl a pc100 rex controller.
                          • Stanley1843
                            BEST 505 Vs Mechanic Brand Reballing Balls with Lead
                            by Stanley1843
                            has anyone use these Brands of solder balls? The brand BEST writes on the label of the jar the specs of the solder balls instead of the Mechanic brand. I beleive that BEST brand must be more professional (in labeling at least) but I have never try one of them so I would like your opinion. By the way I hardly can I find the Mechanic brand in aliexpress (the only where I found was lead free solder balls) and on ebay these that I found are approximately15USD per jar. If you know any other trusted brand of solder balls please tell me.
                            06-22-2024, 11:06 AM
                          • corrize
                            What are the 2 or 3 most used BGA balls sizes please ?
                            by corrize
                            Hello, I want to buy BGA balls (not stencils, only balls) but I don't know what size, it's just for reballing the new chip balled if the first attempt fail. So I will rarely use it. Probably chips are PMIC with max 60 balls. I don't need to reball EC chips from laptops of big chips like that.
                            So what are the 2 or 3 most used BGA balls sizes I should have for cover the jobs please ?
                            05-09-2024, 02:18 PM
                          • jason123
                            ASUS PG27V Rolling Image - TCON?
                            by jason123
                            Hi there,
                            My son's gaming monitor started having rolling image (vertical roll - See Video) similar to vertical sync issue, or T-CON problems in TVs. Has anyone see this? is it fixable or a throw away?
                            I haven't even opened it up yet. Does it have a T-CON? Help is appreciated.
                            It does this even with the monitor not connected to a computer / graphics card....
                            11-01-2025, 05:41 PM
                          • Joe24
                            BGA reballing techniques and equipment
                            by Joe24
                            I work mainly with larger (2000-3000 ball) BGA chips, typically 0.4-0.55mm solder balls. I've reballed many of these, and it's always a royal PITA. My current system is direct heat stencils and hot air, which works but is very tedious. Typically takes me 3 hours, which is about 2 hours too many. And to make matters worse, today i discovered that one stencil must be warped, because as soon as I apply heat, 1/3 of the stencil lifts away from the chip and all the solder balls run together. Unfortunately that's the only stencil I have in that size, atm. You know... we've all had weeks like that. ...
                            10-14-2021, 03:59 AM
                          • petemanuk
                            BGA solder balls not connecting - help pls
                            by petemanuk
                            So I though in my spare time I’d set myself up repairing motherboards mainly pin damaged lga1151 sockets types.
                            I’m using an achi ir sc pro rework station (gave up on my Achie ir6500 - don’t recommend)
                            I’ve managed to get my rework profile somewhere in the correct region (after a lot of trial and error) to get the old sockets off and reflow new ones back on again, the problems I’m getting is not all of the solder balls are re-attaching when re-flow occurs. I know this because when socket is removed pads still look clean and have no solder...
                            11-16-2022, 05:21 AM
